Question about Dishwashers
My LG dishwasher keeps stopping on the wash cycle ond shows FE on the control pad.
  • 706 Answers
Hello again annasgsds,
An FE error code signifies "excess error" meaning excessive water is supplied ..more than normal.. possible cause are the inlet valve ( which I made reference to in my previous response of the controller itself is damaged or defective. In either case.. LG recommends to replace the inlet valve or the controller once diagnostics are completed and you've identified which of the two components may be at fault. Could be either but before replacing the control card, I would remove and clean the inlet valve to see if that was clogged or dinged up and unable to fully close.
Regards,
Rick
Posted on Dec 02, 2008
LG dishwasher LD1419W2 which would not fill -error code IE. I replaced the inlet hose complete. Now it has the error code FE and the water overflows onto the floor when in wash cycle. Peter
Try resetting by:
turn off dishwasher
trip circuit breaker to remove all power to unit
wait 30 seconds
restore power
start dishwasher
the drain pump should start and drain all water then start a cycle. Good luck
Nov 14, 2017 | LG Dishwashers
Getting FE error saw a answer for this model on fixya said to clean the float module where no plastic float on bottom of washer
The FE error or fault code indicates that the washer is overfilling due to a defective water inlet valve. The valve is not repairable and will need to be replaced. If the error persists even after the water inlet valve has been replaced there may be a problem with the main control circuit board
Oct 25, 2015 | LG LDS5540 Semi-Integrated Dishwasher with...
Dishwasher blockage
there is a removeable filter at the bottom of the wash pan. It is usually a "screw-in" type of ring. See if this website can help..
www.applicancerepair.com -enter your make and model and search
Feb 12, 2015 | LG 24 in. LDF 7811 Stainless Steel...
I have LG WM2487H*M and at begining of wash cycle when the water is filling, the FE code comes on and it keeps filling with water then drains the water when it reaches a level. What is wrong? I then shut...
Check page 17 of manual.
FE: OVERFLOW ERROR; Water is overflowing (water level frequency is over 213).If FE is displayed the drain pump will operate to drain the water automatically
LG WM2487HM series Service Manual Error Display
Oct 26, 2017 | LG WM2487HA Washer
LG dishwasher LDF6920ST - Power button lights up but the cycle buttons stopped working so the unit wont turn on to wash. The Power Scrub cycle button seems to be pressed down farther than the other...
Hi Mark.
Modern LG appliances retain settings even after you disconnect the power cord. The machine is reset opening the door and then pressing and holding the Normal and Delicate buttons at the same time for 3 seconds.
You can also try running the test mode shown at page 12 of the service manual.
If the machine is non responding and there is no code on display, then the problem is likely control module or control pad. Since the control pad looks defective, that is probably the part to replace.
Disassembling is shown in exploded view and service manual available using the links below:
Parts and diagrams are available here.
A copy of the service manual covering several LD models has been uploaded here.
Regards.
Ginko
Dec 01, 2011 | LG LDF6920 24 in. Built-in Dishwasher
When the wash cycle is going it starts to make a tune and then FE starts flashing I need to know what FE means
Hi there Celina the code FE has a few differant meanings depending on the dishwasher model. If you can provide me with the model code I can help you with this problem.
Nov 21, 2011 | LG Dishwashers
I have a whirlpool DU1145 dishwasher that seems to be stuck on the same cycle. It shows it as sensing and washing at the same time and never shuts off. HELP! WHat could becausing this??
Sounds like your Touch Pad on the Control Panel is defective.
You can try and remove the 120 Volt AC power from the Dishwasher by turning it off at your Main Electrical Power Panel with the Circuit Breaker (15 or 20 amp) labeled: Dishwasher .
Leave the Dishwasher turned "Off" for 10 minutes. This will allow the control circuits on the Dishwasher to reset. Turn on the Dishwasher and press Cancel and attempt to Drain the Dishwasher. If this works...then try to enter a Rinse Only cycle and if that works... then attempt to enter a Wash Cycle.
If you still have your original problems then you probably have a defective:
(1) Touch Pad Assembly (or possibly a defective)
(2) Electronic Control Module (ECM)
Mar 24, 2011 | Whirlpool Dishwashers
Touchpad--No Response
The "2H" is an error code indicating the control panel needs to be replaced.
May 08, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwashers Logo
470 people viewed this question
Top Dishwashers Experts
