Question about Car Audio & Video
2002 Ford Galaxy - Dashboard lights won't come on
The dashboard lights on our Ford Galaxy (2002) have gone off completely. Windscreen wipers come on and won't go off unless I switch off engine. There appears to be a fuse problem but not sure how to what to do. The rear wiper came on today and wouldn't go off. Can you help??
I am quite handy with cars so if you can tell me which fuse to replace, I will have a go?? If thats the problem of course??
Cheers mate!!
Chris :)
SOURCE: Dashboard lights
You need to remove th whole inst. cluster to replace the bulbs that are located on the BACK side in bulb carriers. Usually turning a 1/4 turn to the left reomves the carries in order to replace the bulbs. Some manufactuers, you have to replace the bulb carrier/socket and bulb as a unit , others just pull the bulb and replace with the SAME type bulb as removed. Most instrument carriers will have on the back what the particular bulb in a specific position is used for by a symbal and the wattage for the also ie: 2.5, which is 2.5 watts. In remove ing the cluster be very careful removeing the connectors from the back. There are certain ways each has to be released to come off but usally can only go in a certain location in the cluster, just make a mental note to yourself has you disconnect them and you will be fine. Alan
Posted on Mar 01, 2008
SOURCE: Windscreen wiper not working
check the switch on the steering usualy it becomes faulty after a while and also your window washers could be blocked but try turning it on if you do not hear a buzzing sound the motors needs to be replaced.
Posted on May 21, 2008
  • 20 Answers
SOURCE: car cd player
do you have a amp connected
Posted on Jul 12, 2008
SOURCE: stereo powers on, but no audio
Thank you so much for responding, its a cd player/radio/cassette player that was factory installed. The face plate does not come off.
Kimsu
Posted on Sep 10, 2008
dj x
  • 61 Answers
SOURCE: tail and dashboard fuse keeps blowning
unhook black wire from harness and the ground from pioneer unit install the ground wire from pioneer unit to frame of car (you may need extra wire to do this) make sure the black wire from pioneer unit is bolted to frame of car not to the harness black wire........fuses will no longer blow and you will have your lights.
hope this helped
Posted on Mar 04, 2009
Ford Focus CL 2003, Door open light keeps flashing, indicators either trip out or go double speed when door open light on.
At the door jam,check the condition of the pin switch. The switch may be cover with a boot.
Compare the condition of this pin switch to the working side.
Clean the general area and re-test.
Jan 19, 2014 | Ford Cars & Trucks
The mounting bracket does not adhere to the slightly pebbled vinyl surface of my dashboard. Does the clear plastic cover, with the tab, come off or stay on? Also, there is a round black disk that...
The mounting bracket is meant for mounting on the windscreen. It won't stick to the pebbled vinyl surface of the dashboard as the surface allows air in. You take off the thin clear plastic cover. The black disk that came with the satnav can be stuck to your dashboard if you want to mount the satnav there. Clean the dashboard and peel off the plastic cover off the disk to stick it to the dashboard. Be sure not to put it where there's an airbag. You can then attach the satnav to the other side of the disk the same as to the windscreen.
To attach the satnav to the windscreen press the suction mount against the screen and press the lever towards the screen. To remove it pull back the lever and lift the tab on the suction pad.
Jun 25, 2011 | GPS
Hi, my car, a toyota caldina, has three buttons on the dashboard that i don't understand. One button has a sign of a windscreen with a wiper and current going through it with an ON light indicator. Another...
on a 1997-2002 caldina G, GT, GTT..
One is the rear demister (front demister is in the center console with the heater). But it could also be the windscreen cleaner pump, if you mean on the stalk. (up, front window, down, reap window).
One is the fog lamps if fitted
The last is an inverter buit into the car so you can run 100Volt domestic devices (like laptops/shavers and stuff). I think the japanese have 100 volt domestic power. You'll find the *** power socket on the back of the centre console under a little hatch, easiest to see from the back seat. Mostly you want it turned off.
Ray.
Mar 18, 2011 | Toyota 4Runner Cars & Trucks
2002 ford taurus dashboard lights out
make sure the dimmer is turned all the way up.If it is and still no lights,the dimmer is bad.
Jul 28, 2009 | 2002 Ford Taurus
Citreon Xsara turned on engine dashboard went crazy car not start
yes its the comms unit, its behind the steering wheel, your car must be a 99 onwards to have this prob, if it is a estate the wires rub on body work, rear doors only, it blows your comms unit, its expensive as needs programming.
Jul 16, 2009 | 2007 Ford F
Dashboard lights and back lights have gone out!!
This, without a doubt, is the main light switch. It comes complete with the wiper switch. Beware of using second hand ones.
Apr 12, 2009 | 1999 Ford Escort
I have a 2003 ford ranger p/u. The wipers stopped
The multi-function switch is a known problem. Hard to say if it will fix all of the problems. Check the fuses too.
Mar 26, 2009 | 2002 Ford Ranger Regular Cab
Dashboard Light gone, handbreak light flickers sometimes.
i have notice taht my handbrake sing turn on when the brake fluid level is low....
Jun 26, 2008 | 1995 Ford Escort
Car Audio & Video Logo
466 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
