HEWLETT-PACKARD Probook 4530S Logo
Jack M Peyton Posted on Jun 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Probook4530s not recharging. powercord or recharging device problem
Anonymous
Level 3:
  • HEWLETT-PACKARD Master 32,281 Answers
  • Posted on Jun 15, 2012
Anonymous
Level 3:
Answers
32281
Questions
Helped
7905952
Points
102259
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Hardrive connected green light on powercord only blinking and not powering external hardive
Replace the power cable and data cable. If still no help, the drive is dead and needs to be replaced.
Laptop monitor
Nikki, it's a hardware issue and you should seek hp's help. Chances are you may not get but look for similar unit on craigslist or kijiji etc. You might get lucky. Meantime make sure wires are secure. One thing I would do is this. If the pieces are there, glue them with Crazy glue or similar strong adhissive.
1helpful
Need to replace powercord on nuwave oven
I would contact the maker OR Google the model number with "power cord" to find one.
Is a power cord available?
well if you have the power cord it came with you can get a volts adapter to plug your powercord into one side and then find the plug adapter they useing
On screen saying re attach power source, no function.
Does it have the battery in it? If so, plug the powercord in to charge. If not, put the battery in it. If it still doesn't work with battery and power cord: I would think either the battery or the powercord is not working properly. Most likely the powercord.
Nuvi 775 will not recharge using the cradle and powercord whilke in the car. Will recharge using a PC USB.
check fuse in the car charger then contacts on the mount as lead should be fitted to mount not gps unit
Can't get power to my laptop.don't know if it's the laptop, or the powercord
Look for a friend around and trouble shoot swapping the power cords. But I believe it must be your power cord that should be replaced.
Do the trouble shooting before replacing.
Rate this, please.
2answers
Which powercord to use?
In the bottom of the laptop you can find the input required, make sure the voltage matches the requirement and the connection is the right way.
from what you said I can't tell if its too stong, can you adjust the voltage? look in the bottom it is documented there on a label.
2answers
Garmin nuvi 680
Take the universal cord back to radio shack and get the correct cord from Garmin
Top HEWLETT-PACKARD Computers & Internet Experts
Paul Bade
Grand Canyon Tech
Grand Canyon Tech
Are you a HEWLETT-PACKARD Computer and Internet Expert? Answer questions, earn points and help others
