Question about Siemens Gigaset 2420 Phone
System pin # reset
I have siemens gigaset 2420 desk station w/3 cordless handsets + bases. i had never changed factory system pin but someone, somehow must have because the default pin "0000" no longer works. i get "invalid system pin" message. could a power surge have caused this, although there doesnt seem to be any other problems w/ststem. however, we did have a big storm that fried my panasonic cordless phone.
  • 4 Answers
There is a way to override and reset... I think you need to press *67# when in the system pin area via menu. Confirm this first though. There is a way to do this though- then you reset it to 0000- google it and you will find the answer-
Posted on Apr 22, 2009
What is the factory reset code?
You shouldn't need a code to reset the handset, but the base requires a PIN (Default PIN is "0000"). I have typed the instructions below, but here is a link to the online PDF: http://dl.owneriq.net/5/5d7cdc19-660a-8934-7d52-e5205df74c27.pdf
Handset:
  1. Menu -> Settings ->Handset -> Reset Handset
  2. OK - press the control key to confirm
  3. End Call Button - Long Press (Idle Status)
This will reset individual settings & changes made by you. It will not affect the directory, calls list, SMS lists, the handset registration to the base and stored pictures or ringer melodies.
Base:
  1. Menu -> Settings -> Base -> Base Reset
  2. Enter the system PIN (Default PIN "0000" or the PIN you created)
  3. OK - Press the control key to confirm
If you already changed the system PIN to one of your own you will need to contact the Siemens Hotline for "expert intervention" (their words, not mine).Online: http://www.gigaset.com/en_US/support/contact.htmlWarranty Number: 1-866-247-8758 / Toll FreeOpening Hours: Sun. 6 pm - Fri. 6 pm continuously (EST)
Jul 10, 2013 | Siemens Gigaset C340 Cordless Phone
I had switched off my Gigaset C200 for one week and when I switched it on again so still flashes "base 1" on the phone's display. I tried manually connect to the base with PIN 0000 but still...
YOU SHOULD HARD RESET THE UNIT
When restoring factory settings:
u Handsets are de-registered
- When resetting via the menu:
all Gigaset handsets
- When resetting using the key on the
base station: also all handsets of
other GAP capable devices
u Individual settings are reset
u All lists are deleted
u The system PIN is reset to the original
code 0000
u Eco Mode+ is deactivated
Only the date and time are retained.
Resetting the base station via the
menu
₪ Settings ₪ Base ₪ Base Reset
§Menu§
§OK§
Press the display key to confirm
SIEMENS Gigaset C380 User Giude Restoring The Base Station To The Factory...
Dec 27, 2017 | Siemens Gigaset C200 Cordless Phone
PURCHASED USED SIEMANS 8800 HAND SET ,REPLACED BATTERY,AND RESET PIN TO DEFALT 0000, PHONE FLASHING "SEARCHING" .HOW DO I GET THE HAND SET TO SYNK UP TO THE BASE STATION?
You need to register the handset to your base to get the phone to work to do this follow the steps in the manual. If you do not have the manual go to the link below and scroll down to product detail then click on the blue product manual.
Gigaset-Accessory-Cordless/dp/B00005UFDR">http://www.amazon.com/Siemens-8800-Gigaset-Accessory-Cordless/dp/B00005UFDR
Or look below to learn how.
Jun 03, 2011 | Siemens Gigaset 8800 Cordless Expansion...
Siemens gigaset 2420. how do i reset pin on desktop base corded station?
  1. I forgot the PIN number on my Gigaset 2XXX system base station. What can I do?
    Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
  • Press MENU.
  • Scroll to SYSTEM SETTINGS but do not press SELECT.
  • On the keypad, enter *65# (Star, 6, 5, Pound).
  • It will display "SYSTEM PIN RESET" and return to the idle screen.
  • Note: The base station system PIN will be reset to 0000
  1. I forgot the PIN number on my Gigaset 2XXX cordless handset. What can I do?
    Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
  • Press MENU.
  • Scroll to MOBILE SETTINGS and press SELECT.
  • Scroll to LOCAL SETTINGS and press SELECT.
  • Scroll to CHANGE PIN and press SELECT.
  • Note: The handset PIN will be reset to 0000
Jan 05, 2010 | Siemens Gigaset 2420 Cordless Phone
My siemens 4010 cordless phone is saying "Base Search" recently
"Base Search" will display for several reasons.
  1. The base station is turned off or not working properly.
  2. The handset is not registered.
  3. The handset may be registered somewhere else, de-register it.
  4. The units (both base and handset/s) may need to be reset to factory default.
You may have already tried this.
Jan 15, 2009 | Siemens Gigaset 4010 Cordless Phone
System pin reset
try using all zeros usually 5 zeros
Dec 01, 2008 | Siemens Gigaset 2420 Phone
Gigaset 8825 cordless phone pin reset
The default PIN for base and handsets is 0000 - if it has not been changed
  • Press Menu on Handset
  • Scroll to Mobile Settings - press ok
  • Scroll to Local Settings - press ok
  • Scroll to Chang Pin - press ok
  • Enter Current handset PIN - press ok
  • Enter New PIN - press ok
  • Display will show Confirm - Reenter PIN - press ok
Sep 15, 2008 | Siemens Gigaset 8825 Cordless Phone
Registering a base station of Siemens Gigaset 2415 Cordless Phone
To register your handset to that base station, you must put the base station in registration mode at the same time you put the handset in registration mode. This is how you do it. At the handset you push OK when it asks you to register. If it asks you for the pin enter 0000 (factory pin) and push OK. The handset should say "registering base 1". Then at the base press the page/reg key down until it flashes (its to the immediate right of the cradle where you rest the handset for charging). That puts the base in registration mode and now its looking for the handset and vise versa. Now watch your handsets display. If it asks to to select an intercom number, then push ok and your done. If it says "invalid pin" then you need to reset your pin on your base (thats a different problem see below). If the handset times out and never registers, you need to repeat the process a couple times, you may have a bad base or it needs to be defaulted. If you need more help you can download a manual for free or get free technical help at the link below.
http://www.barclayent.com/manuals/Gigaset%202415%20User%20Guide.pdf
If you need to default your pin, you can do so but it will default the base station to factory settings. To do so remove the power from your base, hold your page/registration key down, and apply power back to the base. Count to 15, then let off the key. Turn off the power, count to five, then apply power again and follow the steps again to register the handset and you will need to reregister every handset that was previously running on it.
Feb 02, 2008 | Siemens Gigaset 2415 Cordless Phone
System pin unknown
I will email you steps to restore factory default PIN...send me a note
Nov 20, 2007 | Siemens Gigaset 8825 Cordless Phone
Gigaset 2420 system
I saw a battery for this phone,GH5812 on Ebay for under $5.00 !
Nov 08, 2007 | Siemens Gigaset2420 Cordless Phone
Open Questions:
See all Siemens Gigaset 2420 Phone Questions
Siemens Gigaset 2420 Phone Logo
648 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
