Question about Bausch and Lomb Master 68-4010 Tripod
Parts We would like to get an extra camera mount for the tripod and can't seem to find any source.
Does the company that makes this tripod sell the small square part that screws into the camera?
Tripod quick mount plates (the part that is secured to the camera) are specific to tripod manufacturer. A tripod without a mating mounting plate is pretty much worthless as there is no way to mount the camera to it.
You will need to contact the manufacturer (or a reputable camera store) and provide the model of your tripod and the size of the threaded mount in you camera - most are either 1/4" or 3/8".
Apr 16, 2015 | Photography
How adjust the vertical viewing
are you just mounting a camera to the tripod itself? - you need to purchase a head as well - the head screws onto the top of the tripod, and then the camera fixes to the head, usually with a qr plate.
May 05, 2014 | Manfrotto Photography
Sunpak 5800d tripod quick release plate. What is the correct position to mount it on the camera and the tripod? Also what is the push button on the plate and how is it used? Thank you
Go to this site and look at the plate mounted onto the tripod, do it that way, so the bubble level is on your side, and the second little push button opposite of you. The second button is there for larger cameras, many video cameras mostly, that have two holes on the bottom, to keep them from swiveling side to side on the plate. Also, makes it easy to ensure you put it on right in the dark, the extra button should go toward the lens. :o)
Apr 12, 2011 | Sunpak 5800D Tripod
NEED AN EXTRA CAMERA MOUNT FOR VELBON CX686. THE PIECE THAT SCREWS TO THE CAMERA
Try www.TripodQuickRelease.com for that part. There is listed the widest selection of quick releases and support more brands than any other web site I’ve seen.
Mar 20, 2010 | Velbon VideoMate Deluxe Heavy-Duty...
Screwing camera onto tripod quick release
Usually the camcorder has a hole next to the mounting screwhole. The plastic nub fit into the unthreaded hole, the mounting screw screws into the threaded hole. The nub is to help prevent the camcorder from rotating while you are using it on the tripod.
Feb 08, 2009 | Sakar TR-60 Tripod
Need parts list VPT 360SE tripod
'camera mounting scrwe'..any good camera store or online... samy's camera for example
Dec 02, 2008 | Vivitar VPT-360 PROFESSIONAL FLUID-ACTION...
I need the camera mount to use with my Ambico V-0540 tripod
T-mount is the correct term.  Ebay, if you go that direction has some.  The other alternative is B & H Photo Video.
Nov 03, 2008 | AmbiCom V0552 Tripod
Sunpak 6464 tripod parts needed
I found a source for replacement parts at http://www.sunpak.com/service.html
(My monopod lost its ruber foot)
Nov 24, 2007 | Photography
Tripods
The Tripod mount is universal. But if you are unsure take the camera with you to the store.
Aug 30, 2007 | Olympus Camedia C-760 Digital Camera
Extra lights with sony cyber shots
any camera that has a flash, can trigger a "slave" flash. I have one that came with a little bracket that hooks into the tripod mount point. Work great, it also came with a little tripod so that you could use it for backlighting, etc.
Sep 08, 2005 | Sony Cyber-Shot DSC-W7 Digital Camera
Bausch and Lomb Master 68-4010 Tripod Logo
41 people viewed this question
Top Bausch and Lomb Photography Experts
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Bausch and Lomb Photography Expert? Answer questions, earn points and help others
