Question about Arris Wireless G Broadband Router (wr850g)
I would like to activate the securiy settings on my wireless router. I do not have the manual.
    Genius:
  • 1,061 Answers
Its here>http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts.Just download.Was this solution helpful? Show your Appreciation by rating it.RICHARDM69
Posted on Dec 14, 2008
How can I desactive of MAC address on my wireless router?
Reset your wireless router to factory settings.
On the back or bottom of your router, you will find a small hole perfect for a paperclip to be inserted.
While it is plugged into power, press an unbent end of a paperclip into the hole firmly for 30 seconds then release it.
Your router should now be at the factory settings.
You will need to set up the router very quickly to change the factory Admin password so that nobody else can get into it.
Get your setup instructions online by going to the router's manufacturer page to find the manual for your specific router.
Feb 07, 2018 | 2wire (2701HG-B) Wireless Router
I am unsure if the following was activated when the d-link was first installedHow do I verify that wep,wpa or wpa2 is activated on my already installed D-link dir615
Log in via http://192.168.0.1 (default "username: Admin and no pass" CHANGE IT IF IT IS SO !!)
Go to setup tab ----> wireless settings ---->Manual Wireless Network Setup __>Wireless Security Mode
Jul 26, 2011 | D-Link DIR-615 Wireless Router
I forgot my securiy code phone?
is it phone password or router password. do you mean wep or wpa passwork? you can access these security key by accessing your GUI in you router. just open your internet browser and type in in the url 192.168.1.1 for "linksys" router or 192.168.0.1 for other router. then go wireless and wireless security. you can find there if your are using wep or wpa access key.
In case that you dont know the password of your router. reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router. On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Apr 09, 2011 | Computers & Internet
Can a router be setup without an active lan connection to the internet
Yes, but it won't do much other than connect your PC's together in a network. You will probably have to set it up manually in this case, which can be tricky if you don't know the right settings.
The best thing to do is to google the make and model of your router along with manual setup and you should find some help.
Mar 09, 2011 | Computers & Internet
Can't connect a wireless printer to a Thomson tg585v7. how do I check if DHCP function is active
That will depend on the printer and the router. Check the printer manual for ensuring the printer is set for DHCP already then if you don't have the router manual you will need to access the router settings and double check to make sure it is set for DHCP and that you have the correct Access key your using to access the wireless network.
Jun 17, 2010 | Computers & Internet
Setting up security for the wireless netword
All of the settings and information will be available on the manual, which can also be found here:
http://cache-www.belkin.com/support/dl/p74880-d_f5d9230-4_manual.pdf
You can login to the router by going to the address: http://192.168.2.1
If you are going to be using wireless connections, you should try enabling WPA. Or if you are not going to be using wireless connections, it's best to lock the network itself. Once again, you can find much more valuable information in the manual.
Mar 08, 2010 | Belkin Wireless-G Plus MIMO Router with...
Wireless issue with router
Wireless connection issue
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Jan 30, 2010 | Intellinet Active Networking Intellinet...
Authentication failure
hia,
you need a network key for wireless connection to get authorized and allow your PC to connect.
make sure you have right key if security is enabled on wireless router.
now if you are entering right key then need to make sure which type of encryption router is using by going into router settings as an emaple WEP,WAP,TES etc...and make sure your computer wireless settings are same as this type.
let me know if you need more info in detail or step by step.
Thanks.
Apurva
Aug 19, 2009 | ASUS Eee 4G Notebook
HELP... unlock my router
1. From the "Setup" page, click Advanced
2. When the "Filters" page opens, click on the Wireless tab
3. Make sure all wireless computers are setup to the router, and are currently able to access the internet. Once this is done, click on the Active MAC Table button.
4. Move the "Wireless Active MAC Table" window and click on Edit MAC Filter Settings on the main window.
5. When the "Wireless Group MAC Table" opens, go to the task bar and click on the Wireless Active MAC Table so that window appears.
6. With the two windows side by side enter the MAC Addresses from the "Wireless Active MAC Table" window into the Wireless Group MAC Table.
Note: When you enter the MAC Addresses do not include the dashes/semi-colon, and do not click "Filter"
7. Click Apply then Continue in the "Wireless Group MAC Table" window.
8. Close the "Wireless Group MAC Table" window and the "Wireless Active MAC Table" window
9. On the Main window Enable the Station MAC Filter setting.
Apr 12, 2008 | Linksys Wireless-G WRT54G Router
Arris Wireless G Broadband Router (wr850g) Logo
74 people viewed this question
Top Arris Computers & Internet Experts
jimmy Leo
Jerry
Jerry
Greg Ulan
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
