Question about Nintendo Game Boy Color Console
My game boy color doesn't turn on
I've opened it and everything looks good, nothing is damaged inside or outside... I'm using brand-new batteries, but neither the LED nor the display responds. What can I do?
  • 1 more comment
  • lasot_44 Dec 02, 2008
    Thanks, I've tried shorting the switch but nothing happened... btw, there are 2 fuses inside (F1 and F2) but they don't seem to be blown. How do I check where extactly the connection is broken?
  • lasot_44 Dec 03, 2008
    That's useful. But 0 ohm means that a fuse is or isn't blown? I'll check them later, thanks.
  • lasot_44 Dec 06, 2008
    Ok, here is the situation: The F2 fuse is ok, the multimeter shows 0,3 ohm and beeps. When I test the F1 fuse, the multimeter doesn't respond (1 on the display and no beep), so I thought it was blown first. Howewer, when I maneuver with prongs a little bit, the multimeter sometimes shows ~0,3-0,5 ohm and beeps, but it happens only after some maneuvering. Should I consider F1 blown or working?
    I've also tested the on/off switch with the multimeter and I don't know wheter it's ok or not. It looks like this:
    .      [3] [2] [C]      [1]
    ON IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII OFF
    When I turn it to ON the multimeter beeps only when I touch [3] and [C].
    On the OFF position, it beeps only with [C] and [1].
    Should it be like this? What about [2]?
  • 36 Answers
Theres a broken connection somewhere if even the LED doesn't even come on. I doubt theres even an internal fuse on the gameboy.
The only thing you might be able to fix was a faulty on/off switch - have you tried shorting the switch contacts with something metal?
Posted on Dec 02, 2008
  • timclarke Dec 02, 2008
    when you say "dont seem" to be blown are you testing them with a multimeter? I would not assume theyre not blown unless you have tested the resistance (should be 0 ohm), theres usually no other sign.
    Thats pretty much how you test continuity too - but you wont have much luck doing that I dont think. If its not a fuse then it's a long shot! Good luck!
  • timclarke Dec 03, 2008
    When you have the multimeter set to "resistance" or "ohms" set it to the smallest amount (usually 100ohm or something) and test ACROSS the fuse ie one prong either side of it.
    0 ohm (or near enough, most multimeters are not that good, will say 0.027 or something) means the fuse is WORKING.
    when the fuse isnt working, you would expect to see a "1" on the multimeter I think depending on the multimeter. It means infinite resistance, ie a non completed circuit.
    some multimeters have a beeper setting (looks like a speaker symbol) which will beep if you have a completed circuit (ie will beep if the fuse works or if you touch the prongs together) - this is a lot easier to get your head round when you're in a hurry or stressed :)
    hope that helps
Soft sound
Well it sounds like the speaker is not working properly so it's the speaker that's doing this not the console it's self then. 2 double AA batteries I use energizer and duracell for mine and do not use re chargerAble batteries either
May 09, 2012 | Nintendo Game Boy Color Console
I have the game boy color game Pokemon Crystal version. It works completely fine but one Major Issue. IT DOESN'T SAVE MY PROGRESS. I could save a game. Turn off my game boy & When the game menu...
Lately, many GBC games have hit their age limit. there is a small battery inside each cartridge that allows your game to be saved. follow the instructions below to replace it.
http://www.instructables.com/id/How-To-Replace-A-GBC-Cartridge-Battery/
Jul 16, 2011 | Nintendo Pokemon Crystal
Battery is brand new, connection is good at the battery. All fuses are good. Turn key on and nothing happens. We ran a wire from the postitive side screw on the fuse box to the pos lead off the battery and...
You've checked the connection from the fuse to the batterie but have you tried to bypass the keyswitch, it could be the switch doesn't connect inside or the key doesn't turn the switch inside.
Jun 11, 2011 | 1987 Suzuki GV 1400 Cavalcade GT
The game won't save anymore. It used to for years but now it won't work.
Unfortnatley, Game Boy color games had a internal battery inside the Game Case to keep save files on them. You could open the case up and install a new battery, otherwise you cannot save. Sorry!
Good luck and do not forget to rate me :)
Jan 15, 2011 | Nintendo Pokemon Gold
My Game Boy Color game: Pokemon Gold has recently stopped working. By this I mean it does not save anymore and always resets itself whenever the game is turned off, despite "saving." I'm not...
There is no easy fix. Well, there is, but you have to open the game cartridge
all gameboy game cartridges have a battery inside. this battery powers the save module. Pokemon gold is such an old game that the battery has likely died; open the game, replace the battery, and it should work. images?q=tbn:ln15bafqcr5fzm: Leave me good feedback please.
Jan 13, 2011 | Nintendo Pokemon Gold
When i save on Pokemon gold, silver, and crystal (for GBA) then turn if off then back on to load my game it says "the saved file is corrupted" of there is no "continue" button to push....
Well its because the battery inside of the gamepack is dead now. The battery inside of the gamepack allows you to save the game data is dead now so buy a new one then.
  • How To Replace the Save Battery In Pokemon Gold/Silver/Crystal ... 2q== play_c.gif www.youtube.com/watch?v=IJ_h6P1tF7010 min - 16 Apr 2010 - Uploaded by KMCMATT1
    How To Replace the Save Battery In Pokemon Gold/Silver/Crystal ... Warning: Replacing the battery can damage your game cartridge and ...
    More videos for game save replacement batteries pokemon ... »
  • Nov 15, 2010 | Nintendo Pokemon Crystal
    Pokemon Silver for Game Boy Color: my pokemon silver game for game boy color keeps sa...
    Well its because the battery inside of the gamepack that allows you to save the game data is dead now or its a bad gamepack then.
    Can your Pokemon game still hold a save?
    If your Game Boy game is no longer able to hold a save, yet can still be played fine, that most likely means that the battery in the game cartridge has run out of energy.
    You can easily replace this battery, restoring the cartridge's ability to store save data. This replacement can be performed for much less than the cost of buying a new game. You just need to purchase a new battery.
    **Basic soldering skills required**
    Materials:
    Soldering iron
    New 3 Volt Coin Cell Battery - CR2025 (165mAh) or CR2032 (220mAh)
    Adhesive tape
    Fine tipped hemostat or needle-nosed pliers
    Flip over your cartridge.
    Locate Screw
    Using a hemostat, needle-nosed pliers, or anything else that you can grip it with, unscrew this little screw by turning counter-clockwise.
    Once the screw has been removed, turn cartridge over, slide the front cover downwards, and pull it off.
    Now you can see the circuit board, and the battery that allows one of the chips to retain the game save data.
    You can see that both Pokemon Red and Silver cartridges look very similar, except that the Silver circuit board has a crystal oscillator in the upper left-hand corner to control the passing of time in the game.
    Coming next: Removal and replacement of the battery
    May 18, 2010 | Nintendo Pokemon Silver
    I need info on how to switch the case out
    There is no written instructions. I looked online but there isn't any.
    Follow this instructions
    1)with the game-boy screen facing you, there are 5 round things there.
    3 up and 2 down the screen.
    2) put your screw driver inside there and remove it. Do it to all of them.
    3) there are screw(nuts) inside those round things. so remove the screws(5) with the screw driver.
    4)Don't open the LCD yet. Turn to the back of your gameboy, there you see 6 srews(nuts). 2 up one middle(for the battery) and 3 down. Remove the screws.
    5) after you remove all 6 screws, the middle screw is for the battery. open the cover now the screw is gone and remove the battery.
    (please remove any screw you see where the was before)
    6) Open your game-boy with knife or with anything possible for you then the screen.
    remove any screw on the board inside of the game-boy.
    slowly and carefully disconnect a cable that is connected to the motherboard( LCD cable)
    7) remove the speaker and then transfer it to the new skin, remove all the buttons and transfer then, now put the motherboard to the new skin, remove the Screen(LCD) then transfer it to the new skin. put the LCD cable you disconnect from the motherboard back. put the motherboard screw back. put the LCD screw back.
    8) Turn to the back of the game-boy and put the battery back and all crews back. Now you are set enjoy!!!. feel free to ask me any question.
    Jan 24, 2010 | Nintendo Game Boy Advance SP Console
    Battery inside the game card?
    If you're referring to a battery that is part of a Game Boy Color game, there is no way to re-charge it.
    Oct 19, 2005 | Nintendo Game Boy Color Console
    Nintendo Game Boy Color Console Logo
    530 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
