Question about Dryers
Maytag dryer model lde312 runs but no heat, where is the heating element located
  • Anonymous Mar 15, 2014
    Maytag centennial dryer. Runs but is not heating
  • Anonymous Mar 16, 2014
    Runs but won't heat up
  • 1,543 Answers
Remove the two phillips screws in the dryer front at ankle hight. Pull front toward you and unhook from top. Leave wires connected. Heating element visible at lower right.
Posted on Dec 01, 2008
Our maytag does not open in the front, how do we locate from the back?
Posted on Jan 22, 2014
Electric dryer runs but no heat. all thermal and motor and heater element have continuity.
Dryer Diagnostic - Not Heating up - Repair ... - YouTube
? 11:16
https://www.youtube.com/watch?v=3Vns05qIjGs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your trusty Maytag Electric Dryer suffering from some of the ... However, in REGULAR mode, it runs normal too, but theheat stops ...
Maytag Dryer Not Heating - How to Test the Heater and ...
? 4:12
https://www.youtube.com/watch?v=_zjiZ0sbCgI
Oct 12, 2013 - Uploaded by Bill Newberry
How to test the heating element on a Maytag Dryer. If you Maytagdryer is running but not heating these are what you need to check. ... The dryer runs but does not heat. .... Not heating Maytag electric dryer - Duration: 19:38.
Not heating Maytag electric dryer - YouTube
Jan 13, 2016 | Maytag Dryers
Tip
How to Replace Heating Element from a Maytag Dryer?
The procedure is as follows:--- 1) First of all unplug the dryer from electric outlet for safety reasons.
2) Locate the vent hose on the rear of the dryer and disconnect this hose from dryer unit.
3) The hose is mostly fixed in a metal clamp and the metal clamp is fixed by the screw. Loosen the screw and remove the clamp and remove the hose.
4) The heating element is located in the cabinet.
5) In some models the cabinet is located at the rear of the dryer. And in some model its located in the front of the dryer.
6) Locate the heating element cabinet and remove the screws holding the cabinet.
7) You will see the heating element now. There are wires connecting on the sides of the heating element terminals. The wires are connected by removable connector.
8) Remove the connector carefully from heating element with the help of needle nose plier.
9) After the wires are removed from heating element’s terminals. Remove the screws holding the heating element.
10) The heating will have to be moved a bit to come out easily. Before removing the heating element out. Please note down the position of old heating element. So while placing the new heating element you don’t face any problem.
11) Remove the old heating element and insert the new heating element.
12) Connect all the wires as it were connected before.
13) Refit all the parts which you removed while removing the old heating element in reverse method. Take care you don’t miss any part fitting.
This will help. Thanks.
on Mar 20, 2010 | Dryers
How do i get to the heating element in a Maytag Intellidry model Medx500xl0
Well believe it or not just go to YouTube and type in Maytag Intellidry! You will see a lot of videos on various problems.
Nov 30, 2015 | Maytag Dryers
Dryer spins but won't get hot. Bad heating element? If so , where is it located?
Check your circuit breaker. It may not be your dryer at all. 220 dryers run on two separate circuits one to run the motor the other to run heating element.
Sep 03, 2011 | Maytag SDE4606A Electric Dryer
The dryer runs but there is no heat coming out of it
lllThis is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. seth765.jpgseth765_0.jpg
Jan 18, 2011 | Maytag Atlantis MDG6400AW Gas Dryer
I have an old Maytag dryer and its model # is LDE8800 and the serial # is 201878 DU and there is no heat in the dryer cycle anymore. It runs but doesn't dry anything--any help? thanks! Ali
Need a new heating element. had a look around cant find one for yours, maytag did recall a lot of heating elements due to severe problems. they are not a very good brand. i think the model is too old for a new element. Time for a new dryer i think. try Hotpoint or LG
Dec 01, 2010 | Maytag Dryers
My Maytag model LDE312 dryer heats up but doesn't seem to get hot enough. It takes 2 hours or more to dry. Is this a thermostat or heating element problem?
Could be a blockage in the exhaust. If the clothes are coming out hot but still damp after the first cycle then there is a blockage in the exhaust in the dryer. This blockage could be where the lint filter is or in the exhaust vent to the outside of the unit. The best thing to do is pull the unit from the wall and access the back panel. Remove the back panel and with a wet/dry vac clear out the inside of the unit. Then check for a lint blockage in the hose that is connected to the back of the dryer. That should have corrected your problem If an element goes out there is no heat at all and I doubt the thermostat would go out like that Maytags are rare to have a thermostat just go out
Hope this helped
Dave
Mar 21, 2010 | Dryers
My maytag dryer heating element gets hot but motor will not run
Sounds like you have something shorted out.
The element issue could be a contact fused shut.
With both problems I would be looking for wires melted together, or a relay/sequencer welded shut melted etc.
You do have a potential fire hazzard here. If after removing the panel you cannot locate the problem, do not run the unit.
Oct 20, 2009 | Maytag PYE2300AY Electric Dryer
Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Aug 08, 2009 | Dryers
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Dryers Logo
694 people viewed this question
Top Dryers Experts
