Question about Brother MFC-8440 All-In-One Laser Printer
Paper Jam Hello, I am getting paper jam error message on Brother MFC 8440.I checked all places and there is no paper jamCould you please advise on how to resolve my problem. Thank you, Margaret
    Sergeant:
  • 291 Answers
Sometimes the paper gets jam internally if the small piece of paper is just not letting the gears to move fluently this problem cad occur.for resolving this the whole printer needs to be opened and cleaned part by part.
but sometimes unplugging the printer from the main power outlet for sometime the replugging it again resolves the problem.
Posted on Dec 01, 2008
Paper jam on screen will not reset
To clear the error message Paper Jam after you removed the jammed paper, open and close the scanner cover.
If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Refer the below link for the steps to remove any ripped paper remaining inside your Brother machine:
still receive the error message Paper Jam after removed the jammed paper...
Apr 22, 2014 | Brother International Brother MFC-J4510DW
Hello, I have a Brother MFC-640CW that show a paper jam error message, but no paper jam in the printer. I have inspected the printer and can't find anything, how can I clear the error message, or repair...
You may encounter a paper jam while working with your Brother printer. You need to be cautious while feeding the paper to your printer. Paper jams are often obvious, but you might come across a situation when you do not get any indication that the paper has jammed up the printer. In such cases, you need to open your printer and visually inspect it to search for the jammed paper. If the rollers of your printer are leaving marks on the printouts, then there is a need to clean them. Using chemical cleaners such as benzine, thinner, or alcohol to clean the rollers might prove hazardous to your printer.
Nov 10, 2010 | Brother MFC-640CW All-In-One InkJet...
Hello, I have Brother printer MFC 8440.I keep getting mesaage that i have paper jam. I checked all places and there is no paper jam.How can I fix that problem?
It's possible there is still a very small scrap of paper left. If you have a can of air blow it in and try to dislodge it. If that doesn't work try to unplug it wait a minute and plug back it.
Dec 01, 2008 | Brother MFC-8440 All-In-One Laser Printer
I have a brother MFC 8440
Have you checked the back paper door?, the paper tray?, and the drum/toner unit? If a paper was torn out of the machine, you may not be able to see the piece that is still triggering the jam signal. You can also pull down the paper guide around the orange fuser roller through the back door by pulling it gently to the left.
Sep 11, 2008 | Brother MFC-8440 All-In-One Laser Printer
Error message "paper jam"
u need to remove the fuser and remove the paper in it, put fuser back in the reverse
Jun 04, 2008 | Brother MFC-8440 All-In-One Laser Printer
How do I get that message removed?
Most likely their is paper in it yet you can'lt see it, usually I noticed problems like this
My suggesting is call a Service Tech and Have him remove the Fuser unit and check for paper in that area.
your welcome to contact us if no techs are in the area.
Http://www.copierspluwwllc.com
Mar 26, 2008 | Brother MFC-8840D All-In-One Laser Printer
Paper jam
Very frustrating ... checked all over for remaining jams - but the message "paper jam" just won't go away after clearing a paper jam. Eventually, it goes away but no way to predict how long it will take!
Feb 10, 2008 | Brother MFC-8440 All-In-One Laser Printer
Paper jam on my brother mfc 8440
It is possible that a small piece of paper is stuck in the paper path above the primary feed roller. It will most likely need to be disassembled.
Jan 16, 2008 | Brother MFC-8840D All-In-One Laser Printer
Brother mfc 8440
Printer thinks its out of paper when its not. Displays messsage "Check Paper - Reload Paper." Have emptied and replaced paper stack several times. No visible jam. Have shut down and restarted. Still not fixed.
Oct 30, 2007 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
245 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
