Question about Xerox Phaser 7300DN Laser Printer
Phaser 73000 wants to reseat or replace a newly installed toner. When checked toner status is unknown.
  • Anonymous Dec 11, 2008
    We have the same problem with the 7300DN, plus problems printing from Adobe products - letters get run together, or not placed correctly on the page. So far, no solution. I have been looking for how to upgrade the firmware.
    New Friend:
  • 97 Answers
This is a common fault with the 7300 - you can read about it, and some solutions, on my website:
http://michelsplace
Posted on Mar 07, 2011
  • 37 Answers
Is the Toner OEM (new from xerox) or remanufactured? Make sure that the tab that you have to push down on the toner is firmly in the locked position. Reboot the machine and see if that fixes your problem. If it doesnt put the old carridge back in see if the error persists. If it doesnt then you could have a defective toner cartridge.
Posted on Dec 04, 2008
I have a Xerox phaser 7300 that keeps telling me to install or reseat the black cartridge
It is slightly unusual for it to be the black toner cartridge (usually cyan or magenta) but this issue is quite common on the 7300. You can find a lot of information about this here.
Dec 15, 2010 | Xerox Phaser 7300DN Laser Printer
We have a Phaser 7300N that will intermittently run jobs without fusing. as you can imagine this makes one heck of a mess. we had this problem once before so we replaced the fuser, that only worked for a...
These are 2 different problems. The fusing issue is that the fuser roller is controlled by the "ATC Anvil calibration". This requires Transparencies (PN 42527801) to be run through the Manual feeder. You may need a technician for that, or buy a manual
The "reseat message" is probably a warping "top cover inner frame" 116-1548-00. You might need to replace that whole top.
Whit
Item, Inc.
May 24, 2010 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 7400 replaced yellow toner, but still getting replace toner error. I've reseated it twice, reseated the imagining unit and tried turning it off.
You can try do a NVRAM reset. If after that you still have the error message then I would tell you to contact the Xerox team as you might have a wrong consumable (defected/wrong CRUM) information.
NVRAM reset: http://www.support.xerox.com/SRVS/CGI-BIN/WEBCGI.EXE?St=36,E=0000000002092637520,K=9394,Sxi=5,Case=obj(3085)
May 16, 2010 | Xerox Phaser 7400/N Printer
Reseat imaging unit notice won't go away
The Phaser 6250 has a known flaw in the design of the gear slide assembly associated with the door over the imaging unit. One of the teeth has skipped and will require a service tech to "realign Rack-V". It's an easy fix if pictures/diagrams could be posted, but I'm not recommending a novice to attempt this fix without them. "Reseat Imaging Unit" error is a common fix for Xerox printer techs familiar with the 6250.
Jan 06, 2009 | Xerox Phaser 6250 Laser Printer
False reading of toner cart status
Sounds to me like you actually have the wrong part number. There are more than one cartridge for the Xerox printers, They have different chips on them. One is for billable accounts, one or more than one for accounts that pay for prints. There also was as i remember a spring type clip they left off some cartridges.
So with what you have tried and the old cartridges work fine, strongly suspect bad carridges.
Dec 01, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox phaser 7300 toner cartridge problems
Sometimes on this machine as there is a lot of loose toner around it can cover over the sensors in the machine, what I would advise is to remove all the toner cartridges and check for the copper contacts on both the machine and under the imagining unit (which the toner is placed in). Once you have cleaned that away slowly close the lid and reboot the machine and it should return to normal. Its just toner getting caught up in the sensors. Follow the instructions below, when you remove the unit, lift it over your head to find the copper contacts and clean them, be careful not to spill toner everywhere. Good luck!
Reseating the imaging unit
    Remove the toner cartridge:
  1. Open the top cover.
    caution_image88x30.gif The imaging units are sensitive to light. Do not expose the imaging units to light any longer than necessary to remove it and cover it. Failure to follow these instructions may damage the imaging units.
  2. Identify the color of the toner cartridge to be replaced (Cyan, Magenta, Yellow or Black).
  3. Move the orange lever on the toner cartridge to the right so that it unlocks.
  4. Lift on the back side of the toner cartridge first, then guide the cartridge out of the printer.
  5. Set the toner cartridge on paper to avoid any toner spilling.
    Reseat the imaging unit:
  6. Lift the imaging unit straight up out of the printer.
  7. Line up the guide pins with the printer's frame and lower the imaging unit back into the printer.
    Reinstall the toner cartridge:
  8. Install the toner cartridge by guiding the front onto the new imaging unit first then lowering the back.
  9. Move the orange lever on the toner cartridge to the left so it locks.
  10. Clean the LEDs with the supplied wipe.
  11. Close the top cover.
Sep 06, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7750 code 35
Somehow you jarred the fuser. Turn the machine off and reseat the fuser. Open the left side door, there will be 2 thumb screws.
Remove and reseat the fuser, if that doesnt work you have to replace the fuser.
Apr 05, 2008 | Xerox Phaser 7750DN Laser Printer
Xerox Phaser 6110 - what does continuous red light mean ?
Lemmor, without being rude it sounds like you know nothing about this machine at all.
The printer version of this machine has 5 lights in total. 4 of them refer to the toner carts (flashing means toner low, on solid means run out) the other light (the status light) can mean many things. The most common problem people overlook with red status light is that the waste toner bottle is full and needs replacing. It can mean lots of other things depending what colour it is and whether it is flashing or not. These can all be found in the user manual, or if the status monitor has been installed (usb connection) it should show on the PC screen. With a network install, you can browse to the machine using it's IP address to see the error message.
Feb 02, 2008 | Xerox Phaser 6110 Laser Printer
Xerox phaser 6250 NVRAM Failure
Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
283 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
