Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
C250 does not restart at same point after it is turn off and on.
When I am listening to a book and stop in the middle of a chapter the audio begins back at the begining of the chapter when I restart the C250.
If I fast forward the progress line extends but the audio does not fast forward it still begins at the begining of the chapter.
I am at firm ware level v03.02.05A
Regards,
tom
  • 8 more comments
  • tom1395 Dec 02, 2008
    The proposed fix did not help.
    I do pause but it then turns off and when it comes back on it restarts at the beginning. Also, why can't I FF back to where I left off?
    I will try this tonight. According to the Sansa web site I have the latest firmware but I will try a reload just to make sure it is not corrupted.
    I don't understand your message. I don't have a phone?
    The buttons are not stuck. I'm assuming the circuit is OK seeing as this is a new device.
    Thanks Ginko I'll try the pause. Any idea why ff does not work?
  • tom1395 Dec 03, 2008
    Need more guidance. I don't see a menu option that lists the INtro to Repeat All option
  • tom1395 Dec 11, 2008
    Thanks sybabe. I finally got through to Sansa support. They tell me that their MP3 only works on audio books in aa format. They don't book mark or hold position on MP3 or WMA.
    Tom
    Sorry Johny I have tried that. I just found out that Sansa only supports aa audio files. Not mp3 or wma
    President:
  • 2,110 Answers
Try to reset by doing following steps
Turn the player on
Engage the hold switch (slide it over so that you see the orange under the switch)
Hold the Rewind button
Plug the player in to the computer
If the player is detected by the computer after doing this then format the device.
Posted on Dec 11, 2008
    Master:
  • 479 Answers
U try to convert your audio into to AA format and then try . hope this helps.
  • 395 Answers
All audio books should be in an aa file format , if it's in something else that might be why it can find where it left off
  • 4,806 Answers
Hi there
When you spoke to Sansa did they tell you if a firware update could resolve the problem for you or are you stuck with the format you are using?
what you can do is convert the MP3 file to AA format by using an audio converter (if you us a torrent client like UTorrent etc download Total Video Converter) this can convert all you audio to AA so it will be compatable with the sansa.
In my experience with MP3 players i have never been able to fast forward exept skip to the next tune.
Kind regards
  • 796 Answers
The file which you are hearing must been corrupted...
please delete the current file nad reload it with a new file
Posted on Dec 03, 2008
    Sergeant:
  • 237 Answers
This "problem" may have to do with the publisher of the audio book versus your hardware. Try different books...I find that some audios will pause and start in the same place and some will begin from the very beginning. It is frustrating at times, but just learn to know fast forward to the place where I stopped. Also, when you fast forward, do you hold the button or just punch it once and let go?
Posted on Dec 02, 2008
  • SanDisk Master
  • 1,800 Answers
Look u r not in a need of a firmware
whilst u r listening press menu and chek the repeat settings and change it from INtro to Repeat All
okay??
plz do rate
    Genius:
  • 1,239 Answers
Hi if you have firmware to your compability phone.please install and see it.this may work
  • 734 Answers
Try updating the firmware of your player. Switch the player to recovery mode (enable hold switch and press and hold the record and power button until you see on the screen welcome to recovery mode) download the sansa firmware updater on the sandisk website and install it to your computer. When it ask to connect the device connect the player and check if there are updates on the player. Also try to format the player it may be the songs on the player is causing the problem.
  • futureloginn
    futureloginn Dec 10, 2008
  • SanDisk Master
  • 19,396 Answers
You need to use the pause button, and not the stop button.
If you pause instead of stopping it will restart from the same point.
  • 2 more comments
  • Ginko
    Ginko Dec 02, 2008
    If you turn it off, it will always restart from the beginning, this player has a file, not a tape inside.
    What you need to do is putting the unit on pause and not turning off. The unit will go on standby and restart where you left when you press play again, this is the only way to do it.
  • Ginko
    Ginko Dec 02, 2008
    You do nbot need to re install any firmware, this is not a firmware issue is the way the unit is designed.
    Firmware installation is a procedure that if not done correctly can damage the unit, and in this case is useless.
    The guy posted just whatever, he does not have a clue, trust me.
  • Ginko
    Ginko Dec 02, 2008
    Regarding the FF issue, to FF you need to hold down the button, if you press it just once, it will go to next file.
    The stop and restarting from beginning of file is normal.
    The unit does not seem being faulty, probably is the file compression format that you are using that does not allow ff.
  • Ginko
    Ginko Dec 02, 2008
    That is strange, I still think it is possible that you are not using the command in the right way, as this player controls are a bit tricky:.
    Here is FF usage from user manual:
    - Press the Left (|<<) button to go back to the beginning of the song
    - Press the Left (|<<) button twice to go back to the previous song
    - Press and hold the Left (|<<) button to fast rewind
    If it is not that , it may be the file format, sometimes player cannot go FF and rewinfd on certain compression formats, sure is uncommon on an audio file, it happens usually with videos.
    Regarding the stop/pause, you should use the pause without turning the sansa off.
    The manual says To play and sesume:
    Play/Pause/Up Press to move up one item, pause, or resume.
    Here is the manual for C200 series (including C250) in PDF.
    Sergeant:
  • 217 Answers
Remove the battery for sometime.and also reset the device.
  • llincon Dec 02, 2008
    first check out if all the buttons r working properly when you press .may be any of the button got stuck up or may be that circuit behind that button has gone faulty.as the F.F button should work from where u left out/off.
Memorex portable cd player will not hold place on the cd when turned off
Audio books may be different but with a music CD if you press STOP once you can pick up where you left off. Pressing STOP twice reverts to the beginning.
Jul 15, 2016 | Memorex MD6451R Personal CD Player
How do I rewind the Samsung Q3 Mp3 player when playing an audio book?
Whilst listening to the audiobook in question, hold down the left arrow on the control pad (the area with buttons down the bottom. After holding this down for long enough, the audiobook should rewind.
Mar 02, 2011 | Audio Players & Recorders
Audio books skip around on ipod touch 64g
Did you figure this out because I am having the same problem?
Mar 26, 2010 | Apple iPod Touch 8GB 32GB 64GB 3rd...
How can i fast forward on an audio book
there's no function for this on mp3 players.if you know you're going to want to do this frequently when you're reading the book it would be better to download it in chapters and then you could at least jump from one chapter to another without listening to the whole thing each time.You could record chapters or the whole thing onto Audacity ( A free sound recording program) and break it up into smaller sections.This is a lot of messing about and you'd probably be better off trying to find the book as an ebook and just search out the relevant bit that you'd missed and read it instead. I think it would be a great step forward if mp3 players were able to do this.The only equipment I know of that can do this(other than a media player on a pc) is on some digital radios where you can pause and do a rewind to the bit you want but this is usually only over a short period (5 mins for example on the Roberts digital radio.
Sep 10, 2009 | Audio Players & Recorders
Sanza. Audio book chapters load in crazy order
hi katie.
before you load your audio books onto you device try renaming each chapter to get them in order. your device should order them like your hard drive will
May 22, 2009 | i-Bulldog IMP-90 MP3 Player
Fast forwarding for listening to books
I use a Creative Zen V Plus, but have a similar problem.
First, an explanation: the issue is probably with the timecode in the audio track. This can happen when the audio file is created on a computer. The audiobook was likely "ripped" to a file from the original audiobook CD, and your player may not like the format the file is in. The best solution in this case is to recreate the audio files yourself. First remove all of the files from your Sansa for that particular book. Then use CD-burning software on your computer to create an audio CD (not a data CD!) from the files you got from the library. Finally, use the software that came with your Sansa to transfer the audio CD back to your Sansa. This way you know you are getting a correct format on your player.
If you have an additional issue (like me) where the tracks are too long and go back to the beginning every time you turn your player off, you may have to use an audio editor such as Audacity to chop the long tracks up into smaller tracks, but this is quite time consuming. It is best to acquire audiobooks in smaller tracks in the first place. This is the problem I have been faced with while using Audible.com to listen to audiobooks.
Jan 21, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Playback of audio files does not resume where I left off when powering back on
I have an e260. I use it for audiobooks a lot. I just press pause (centre top of the dial), and the track will resume from there next time (unless I go back to the main menu for radio of course.)
Aug 16, 2008 | SanDisk Sansa e250 MP3 Player
Fast Forward
http://serviceman.site88.net/index_files/MP3Players.htm
Jul 31, 2008 | Creative Labs Zen Touch MP3 Player
Sansa m250 doesn't continue playing from the same spot after power up
This player will only recognize Audible audiobook files
There is not a fix for the pause/resume issue - it is a major problem for just about every mp3 player that claims audiobook compatibility
Here are some help files:
Audible
1) Adding audible books to your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-book.wmv
2) Adding books from an online library to your computer using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-books-from-online-library.wmv
3) Adding your MP3 player as a mobile device in Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-add-mobile-device.wmv
4) Deleting an audible book in your MP3 player using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book.wmv
5) Deleting a book from your library using Audible Manager (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-delete-book-library.wmv
6) Purchasing an audible book from Audible.com (Windows XP)
Windows - http://mp3support.sandisk.com/audible/xp-audible-purchase-book.wmv
May 13, 2008 | SanDisk Sansa m250 MP3 Player
Resume where stopped listening
Review the pages in the manual regarding organizing your tracks into folders, and select "Repeat folder" in the folder view menu.
http://www.p4c.philips.com/files/s/sa178_17/sa178_17_dfu_aen.pdf
There is no bookmark option per se with this GoGear, even though other GoGears have the feature. You cannot stop where you left off - just note the time on the track when you stopped, and fast forward to that time when you next turn on the goGear.
-Tha Mp3 Doctor
Aug 14, 2007 | Philips GoGear SA178 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
