Question about Krups Gusto 880-42 Espresso Machine
Gusto- water leaks over the grounds instead of filtering through
My Gusto espresso maker has worked very well for a few years......all of a sudden one day the waeter started to leak out / over the groundsinstead of filtering through. Seems like a problem with proper seal.....can you help
  • Anonymous Dec 20, 2008
    same thing is happening to me
  • 3 Answers
The holes in the metal coffee ground holder/filter are probably clogged. I have had this happen and it has cleared when I cleaned the holes in the coffee holder. I used the cut off head of a toothbrush and pushed the bristles through the holes. If you hold the filter to the light before and after cleaning, you can see the change in the proportion of closed holes.
Posted on Jan 18, 2009
My Dolce Gusto coffee maker suddenly stopped working power will not turn on
Most coffee makers have a thermal fuse which prevents the appliance from meltdown or fire in case of an electrical short.
Thermal fuses are made for various temperature limits. Open your appliance find the fuse which looks like a resistor or diode with a metal shell. Note the part no. or temperature. Look online and purchase a replacement fuse. They are inexpensive. The fuse needs to be soldered or crimped on connectors in place of the blown fuse. The fuse can be checked with a multimeter for continuity using the ohms setting.
Jun 17, 2015 | Krups Dolce Gusto KP 1006 Espresso Machine...
Why is my dolce gusto is leaking. can it be repaired?
remove the plate which is clipped neat the capsule holder and try again if it works see if you can opening the hole or replace
Oct 05, 2014 | Krups Dolce Gusto KP 2100 Espresso Machine
My Rancilio Silvia won't pump water out of the head all of a sudden. It had worked for years up to this point
It may be that the 'shower screen' which is a perforated metal disk filter that fits inside the head has reached its use by date.
These can be found and bought on E-bay for about $15 each, make sure you buy a genuine Rancilio replacement, while you are at it, replace the rubber 'group seal' - a rubber ring for pressure sealing the head/arm after filling the arm with grounds - these are a similar price. If you get leaks around the head while making a coffee, the seal is worn out.
Jul 31, 2013 | Rancilio Silvia Espresso Machine
How do you descale the machine
my machine has stopped working it sounds like the motor is still running, not sure where to buy the descaler can I just use vinegar?
Jan 28, 2011 | Krups Dolce Gusto KP 2100 Espresso Machine
Dolce gusto
Hi. I work at Nestle on the brand and it sounds like either a fuse issue or a clogged needle. Please call our consumer services number at 1-800-746-3391 for assistance. They are open Mon-Fri 8am to 8pm EST.
Jun 20, 2010 | Krups XP4030 Espresso Machine
My dolce gusto machine has just started to leak from the bottom. I have had it since Dec 2008 and not had any problems with it until this weekend. Can anyone help?
Hi, my name is Katelyn, and I help with the marketing for Dolce Gusto. There is a live chat with a specialist on our Web site (http://www.dolce-gusto.us/Public/Contact-Us.aspx) or feel free to call the consumer services at 800-745-3391.
Feb 08, 2010 | Krups Small Appliances Espresso Machine
I have a Briel MultiPro espresso maker. When I try to make coffee, water/coffee starts running over the edge of the basket and it "spurts" coffee and grounds after a few seconds.
The group head gasket needs to be cleaned or replaced. First get a brush and clean put the head, then insert back wash filter(basket with no holes) in portafilter, make sure that it is seated properly(atleast 90° angle with machine), then run the head if nothing leaks around the portafilter the gasket is fine, if it leaks then replace the gasket. Make sure that you press the stop button before removing the back wash filter.
Jun 23, 2009 | Briel MultiPro Espresso Maker - Brushed...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
No flow
Tamp the coffee a little less - run water through filter basket to make sure it is dripping out before filling with espresso grounds. Dry the filter thoroughly before inserting coffee grounds. I would reccomend using double filter basket only instead of the single.
Aug 11, 2008 | Cuisinart EM-200 Espresso Machine
Krups Gusto 880-42 Espresso Machine Logo
565 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
