Question about Palm TX Handheld
Palm TX travel charger problem
My palm TX will charge when I use the hot sync cable hooked to my pc, but when I need to use the travel charger it doesn't. The hot sync cable has a wide plug that goes into the bottom of the TX, but the travel charger only has a small plug that fits into the right side at the bottom of the TX. If I wiggle the plug, I can see the lightning bolt on the battery, but as soon as I lay the TX down, the lightning bolt goes away and it stops charging. There seems to be a lot of play or wiggle room in the place the travel charge plugs into. I have even replaced the travel charger, but have the same problem.
  • frustratedpa Jan 10, 2009
    Same problem -- can wiggle cord to get it to charge, but has been getting worse and can get no charge at all now and can't get it to turn on.
    Problem Solver:
  • 14 Answers
It is an issue with the slot on the device, however you can charge the device using the Sync cable, it is the safest way to charge the device.
Posted on Dec 25, 2008
Unable to connect
Palm TX - Bluetooth Synch with Windows 8 - HP Support ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
... and configured the Bluetooth on the Palm TX Handheld and everything looks like ...I get an error message saying "Unable to initiate HotSync operation because the .... o At bottom of drop-down menu, click "New" [or select a existing connect ...
db:: 4.35::Unable to sync Palm TX Handheld in Windows 7 ...
www.hivmr.com/db/1dxpd1fc31admksspczm98j7fp979x1p
I am unable to hot sync my T/X palm handheld since getting windows 7. I have done ... onto 64-bit desktop. USB doesn't connect to update Palm from handheld.
Setting Up Your Palm Device's Internet Connection - For ...
www.dummies.com/.../setting-up-your-palm-devices-internet-connection...
Check with your ISP to see whether you can connect your Palm device to the Internet... Preferences screen, tell your Palm device how to connect to the Internet.
Bluetooth syncing problem ' Apple Support Communities
discussions.apple.com > Support > Apple Support Communities Apple Inc.
Jan 03, 2016 | Palm TX Handheld
Can we charge Z22 handheld through PC??
Sometimes if you plug them in to the hot sync cable they will charge. This works for my TX however I am not sure about the Z22. I am including a link to the palm free chat service. Normal 0 Scroll to the bottom of the page and you will see a Palm Chat. From there click on the link that says Chat Now and follow the online prompts. Best wishes...I hope this will help you.
They can answer that questions for you there. I have used the free chat service and it worked great for me. Best wishes.
http://kb.palm.com/wps/portal/kb/na/zire/z22/unlocked/supportservices/page_en.html
Nov 13, 2009 | Palm Z22 Handheld
Palm TX handheld
First you need to reset the TX:
hold the reset button on the back of the unit, then turn the power on. Hold the power button while releasing the reset button. The TX will power up to the screen where it will ask you if you want to reset it to factory default.
Afterwards go to this link,
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=1568,E=0000000000263321976,K=3877,Sxi=4,case=obj(32859)
and download the Palm Desktop/Sync software and install it onto your PC. After installing the the Palm Destop software, connect the sync cable to the PC via the USB, then connect the cable to the TX and push the sync button.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 29, 2009 | Palm TX Handheld
By typing hot Sync my palm makes a restart
Try this, uninstall your current version of Palm Desktop, then go to this link on the Palm support website http://kb.palm.com/wps/portal/kb/na/tungsten/tx/unlocked/home/page_en.html this will give you the link to the download for the TX version of Palm Desktop, this may or may not fix your particular problem but it is worth a try.
Mar 24, 2009 | Palm TX Handheld
I broke my old Palm TX. Now I have another one
Great!
Thanks, Joe
Mar 14, 2009 | Palm TX Handheld
Thank you in Advance!
I had the same problem with my TX.  When I moved, I lost the CD.  I think what you have to do is contact Palm to get a replacement CD.  It might be a small charge for it, but the drivers are on that CD and that will make it work.
Are you using Vista at all?
Sep 13, 2008 | Palm TX Handheld
Touchscreen
I had a similar same problem. It occured when pluging or unpluging in the USB cable into the bottom of the Palm TX when the other end of the cable was already pluged into a live USB port on my PC.
The solution was to make sure the cable is unpluged first from your PC before you plug or unplug the cable into the bottom of your Palm TX.
Sep 09, 2008 | Palm TX Handheld
Palm TX not turn on
It may be a faulty charger. You may have checked this already, but here is the link to the palm website http://us.store.gc.palm.com/?cp=TX&i=1&t1=Chargers%2C+Cables+%26+Cradles&u1=cp&u2=t1
I have a palm TX as well I just hope its a bad charger and not the TX. Sometimes I my TX dosnt charge from the usb sync cable.
Mar 27, 2008 | Palm TX Handheld
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Manual Hot Sync
If u need to make connectivity between computer and Palm mobie then u need to install hot sync software on ur Pc and activate hotsync option from ur mobile then with cable u can transfer the data . if u  not have proper software of hotsync then download it from palm Site.
Gizmo1
Oct 22, 2007 | Palm LifeDrive Handheld
Palm TX Handheld Logo
73 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
