Question about JVC MX-J70 Shelf System
Opening up Speakers
One of the tweeters on a main speaker has blown and 'buzzes'. I want to take it out to replace it, but I have no idea how to open up the speaker 'cabinet' on this system. There are no screws to be found anywhere. I can get the front grill off, but that doesn't help me at all. How do you open up the speaker box?
  • 3 Answers
I it wood or plastic? if you cant easily pry the 'screen' in front off and there are no screws, your best bet is just to find a new speaker box to put new speakers in... only way to open it is to tear it apart, unfortunatly.. if you do decide to open it, CAREFULLY cut the screen off with a razor or exacto knife, once inside you'll know better what your dwaling wiht...good luck
Posted on Jan 27, 2007
Tweeters will not work
might be a problem with the crossovers inside the speaker box.take them to a technition
Nov 10, 2013 | Definitive BP7004 Main / Stereo Speaker
Blown tweeters
replacements available from missionparts@hotmail.com
Aug 10, 2012 | Mission 782 Main / Stereo Speaker
Polk rti6 tweers blown...4 speakers.....can these tweeters be repaired
It may be possible to have the tweeters repaired by Polk however if you have the skills your least expensive route would be to replace the tweeters and install them your self. I would recommend using the internet to find replacement tweeters either through Polk or possibly Ebay, or Amazon. Each tweeter has 2 wires that must be removed before uninstalling. Note the polarity and where they connect. red is + POSITIVE , BLACK IS - NEGATIVE
Apr 15, 2011 | Polk Audio RTi6 Main / Stereo Speaker
How do i tell if my problem if the high freq diaphram or the cross over
The crossovers in professional speakers don't fail that easily. It could be a blown tweeter. To confirm remove the metal grille-- remove the screws of the Horn Tweeter -- remove the cable connectors on the tweeter terminals ( Red and Black wire ). Now if you have a multimeter put it in Ohms range and touch the probes on the tweeter terminals-- It should show a reading betwwen 4 to 8 Ohms depending what is written on the back of the tweeter magnet. If you do not have a Multimeter you can take an ordinary cell/battery ( 1.5v ) from a TV remote and touch the terminals of the Horn Tweeter with the battery. + to the tweeter + ( a small red dot or mark will be there on the tweeter ) and -- to the tweeter -- . When you touch the terminals or give 1.5 volt supply the tweeter will make a scratching noise.
If you do not hear the scratching noise - it indicates a blown tweeter coil and will need replacement.See link below for spares:-
http://legacysoundservice.com/catalog1/product_info.php?products_id=1417
But if it does, you are in trouble and will need professional help from a electronic technician.
Could be blown HF Amplifier, suspect the crossover last. They seldom fail.
Revert back for more help
Apr 02, 2011 | JBL PRX515 Speaker
Will not produce sound through the top end of my speakers,
While this may sound strange, it is not likely the receiver that is the probem, at least at this point. Remove the "tweeters" from the speakers and measure across the two leads. You should read continuity. If not, then the tweeters need to be replaced. I believe that you may have blown the tweeters.
Dan
Feb 06, 2009 | Sherwood RV-7050R Receiver
The tweeters in my yamaha NS-515F have blown. Any ideas where i can purchase suitable replacements?
http://www.partsexpress.com is a popular source for loudspeaker components.
Also, are you sure the tweeter's blown, and not a crossover component?
www.mouser.com carries many electronic components that could be used in crossovers.
Dec 02, 2008 | Yamaha NS-515F Speaker
Amplifier
Yes. Most likely your factory speakers are blown as I've seen this many times. They are co-axials (2 ways) and the woofer part of the speaker is blown or the surround is rotted and only the tweeters are playing. I also believe that the front door speakers are low frequenct. Are they playing or buzzing?? Let me know and I can confirm this as the solution. You need new speakers.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Jul 01, 2008 | Car Audio & Video
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Tweeters & Midrange Speakers
If you have a Ohm Meter, check the resistance to the speakers. If it is very high, the speakers are burned, (or the crossover is (just capacitors, and resisters...cheap)). If it is close to 4 ohms check the wiring and connectors..to and at the speakers, most likly the receiver/amp is not blown.
Apr 20, 2008 | KLH 1230SB Main / Stereo Speaker
JVC MX-J70 Shelf System Logo
401 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
shaun taylor
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
