Question about Dell OptiPlex GX280 PC Desktop
Tried it i removed the piece you told me to and put it back three mins later and started it back up and it said invalid config and it said to press F1 to continue and it just did the same thing, what can i do
    Master:
  • 474 Answers
Yes, the F1 message you get is the system wanting you to go into the bios and reset the clock, You can go past that, its not critical.
I would remove the Video card and try using the onboard video ( if it has it). If it boots and you can get into windows, then try re-installing the drivers.
Since its not working, try removing anything you have in the PCI slots and booting with just the video card, if it works, than it means your system board is having port conflicts and you will most likely have to try and update the bios and chipset from the manufacturers website. try this and get back to me.
Oh, if you could, copy and past your problem as FIXYA only shows your recent reply but not the original post and i do alot of these and forget what i told you earlier.
Posted on Dec 02, 2008
The washing stops 3 times when you first start it with the codes F1 on display then 3 more times with 19 min. left with the codes F1. What is F1? Everytime it stops I press the stop button then start...
This F1 Code is a Communication disconnection problem between the Control Unit and the Electronic Curcuit Box. First Check the Connection and reply me with the make and model no.
Sep 21, 2009 | Washing Machines
The buttons on my phone aren't working.
1 ) remove battery and then 2 min later put back in. try again.
2) mine did that when it got wet. Remove battery, allow to dry in a warm well vented (over and under) area, Put battery back in 6 to 12 hrs later, try again. Worked for me!
Aug 05, 2009 | LG RUMOR Cellular Phone
Problem starting my computer
sound like the internal bettery need to be replace.
do yo have dula boot machine? if not, then change the internal bettery.
Mar 17, 2009 | Microsoft Windows 98 for PC
HP Pavilion 700 boots but stops @ press f1 for setup then stops
Hi there hey have you tried to unplug the pc cord from the power supply and opening up the case and making sure that all of the power cords are connected correctly and you can also try to unplug the power supply connector to the motherboard and press the power button than remove the battery that is on the motherboard for 2 min this will reset the cmos, than put the battery back and plug in the power supply connector back in the motherboard and reboot you will have to re input the time and date but other than that you should be able to resume setup from here. please let me know how this works out for you , i can go further into detail if needed best regards mike
Feb 16, 2009 | HP Pavilion (PN153AAR) PC Desktop
Not starting up Compaq V2000
may be
but you try this methods
remove the cpu cover and remove the cmos battery then ,remove the hdd cable and replug ,make sure all input devices like keyboard,cd rom drive conneced properly,then run the pc,F1 appears -click F1,after os load ,turn off the computer and insert the cmos battery ,again F1 is appears u press F10 and again press F10 or save buttens ,
it is a possible solution not sure,but try it
thanks
Feb 28, 2008 | Computers & Internet
Invalid DNS Support for Lg Prada
dns server on rought modem not configed right try unpluging all them and back in after few min
Jan 24, 2008 | LG Prada KE850 Cellular Phone
No washing
Hi, mine was getting to this point. After cleaning the filter all went back to normal. If you have not tried it, remove the three phillips head screws on the front bottom panel. You will see a plastic piece on the right hand side. You can unscrew it with your hand (drain water into shallow cake pan). Once water stops coming out, remove filter all the way and clean the pens, pencils, change, lots of lint, etc... out and put it back in. All should work well after this. Thanks, Greg
Dec 16, 2007 | GE Energy Star WCVH6260F Front Load Washer
Tray Error - Invalid Config
Unplug the power cord well the printer is on. and it should reset it worked for me. Hope that helps.
Apr 25, 2007 | Dell 3100cn Laser Printer
BIG problem. PLZ help!!! :(
The Samsung YP-F1 has a reset button located under the black Samsung cover plate. It can be gently removed via a finger nail or mini flat blade screwdriver. Once plate is removed a hole labeled reset will be seen. Use something like a paper clip and press in. MP3 will power down/reset. MP3 data is also retained after reset.
Apr 03, 2007 | Samsung Yepp YP-F1X MP3 Player
Dell OptiPlex GX280 PC Desktop Logo
Alun Cox
