Question about Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
Saeco Talea Ring, code 4, out of order.
I have a Saeco Talea Ring machine. When I just started the machine the display said: out of order, code 4, turn machine off.
I did this and waited but the code is still coming back.I tried this several times. I cleaned the central unit but nothing works. What can be the problem?
dutchman05
  • 487 Answers
SOURCE: Saeco Talea Ring Plus
ok with a machine you have already for a while :
Putt descaling solution in the machine. unplu the machine and open the watere valve. Aftre about 2 days it should have desolved.
BUT>>>>>>>>>> what also can be is that the valve on the bottom of the water tank is not working.
Fill it a little and wiggle the valve until water comes out and than try again.
Priming normally goes.
Water in tank. push water button and open valve.
Posted on Jun 03, 2008
SOURCE: Saeco Espresso machine - Empty drip tray (all the time)
Clarification: It complains constantly. Even when I empty the drip tray, which is already empty, put it back in (empty) - it still wants me to "empty the drip tray" again. Sometimes - if I'm lucky - I can brew 1 espresso before it wants me to empty the drip tray.
Thank you for your assistance!
Posted on Jul 11, 2008
  • 74 Answers
aye that is true if you click the coffe making button directly after you have had it out you will be able to make a cup, as the machine has a 2 second response time.
Ok here is what i think:
As it registers the driptray I dont think its the sensor to it.
More i would think that its the CPU card that is not responding to that its clean.
I am sry but I have to ask this:
When it says emptie the driptray are you actually taking out the container that is located under the brewing unit, and not the "drip tray" were you put the coffe mugs?
Also when i think i have a sensor problem I allways take out everything. Brewing unit, dripwater container, dregbox, and the watercontainer. and have it out for atleast 2 minutes ( clean it under the mean time) and put it back again.
As I dont have the machine infront of me i cant be certain:)
Posted on Jul 15, 2008
SOURCE: Saeco talea ring coffee machine reurning error code
Thanks Johnny,
the machine wont make coffee at all as it stands. Justn returns code 1 as soon as you push the button for coffee. Is the sensor optical or a microswitch? Can you tell me where the sensor is located so that we can have a go at cleaning it?
Posted on Nov 18, 2008
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
My saeco talea touch wont steam out of the wand, it makes the noise like it is steaming but the steam is coming out of the bean hopper and the grind tray area
Your delivery pipe has been disturbed at some point and has dislodged or blown out the O-ring seal, or maybe careless assembly of said pipe seal, if under warranty, take it back.
Oct 19, 2014 | Saeco Hot Buy Talea Touch Plus Automatic...
Saeco talea grinder is starting when you start the machine
this sounds like the machine simply needs a good cleaning due to grounds jamming the switch in place
Sep 05, 2014 | Saeco Talea Ring Plus Espresso Maker with...
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Out of service [4] out of service [87] restart to solve the problem SAECO TALEA RING PLUS
Hi...itis not self testing..in otherword the motor in the gearbox is not working, either itis jammed with rust cuz' of leakage or motor is bad.
Dec 04, 2009 | Saeco Talea Giro Espresso Machine
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Error Code 4 on Saeco Talea Ring
I need to know what error code 4 means as well.
Has anyone helped you yet?
Apr 05, 2009 | Saeco Talea Ring Plus Espresso Maker with...
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
May 22, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
61 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
