Question about Kodak EasyShare Photo Printer 500
Bluetooth will not set up with Mac OS X
Hi there, Having followed the manufacturer's instructions (from the manual), and having tried to install and re-install this printer to use via Bluetooth, I am having no luck. I can get to a point where it SEES the printer, but will bonk out as it says "Driver Not Installed" -- well, the driver IS installed to use it via USB, but it won't let me add a new driver version via BT. I can even get to a point where I am asked for the PIN to pair the BT device. Still, it won't go further than that. Has anyone experienced this problem? More importantly, does anyone have suggestions for how to either make the wizards work or create a driver manually? I'd really appreciate it. We love the printer and I would like to make it easier for my wife so that she can print without a cable (a luxury, I know). thanks, NEM
  • Anonymous Jan 19, 2009
    This stuff is supposed to "just work".  WTF??
I have the same problems, and I can't seem to get in touch with Kodak. I even was able to update the printer's firmware, but still can't print with it, USB or BT.
Posted on Feb 04, 2007
    Novelist:
    Champion:
  • 202 Answers
NEM, Are you logged in as root or administrator? You may want to start from scratch. Wireless is sensitive. Uninstall the printer and reset the bluetooth settings. Then reinstall. Make sure your speakers aren't to close to the printers...trans/rec window. Tim
Posted on Jan 29, 2007
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf
Set up the printer for Bluetooth communication
The printer allows you to print documents from
Bluetooth devices without a cable connection.
Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer.
Set up a Bluetooth wireless connection
This section describes how to set up and configure the device for a Bluetooth wireless connection.
You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs
(Windows Mobile). For more information, see Printer management tools.
To connect the printer using Bluetooth communication (Windows)
NOTE:
If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter.
1.
If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer.
If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on.
2.
On the Windows taskbar,
click Start
, click Control Panel
, click Hardware and Sound
, and then click Add a printer
- Or -
Click Start
, click Printer
or
Printers and Faxes, and then double-click the Add Printer icon
or click Add a printer
3.
Follow the onscreen instructions to finish the installation.
To connect the printer using Bluetooth communication (Mac OS X)
1.
2.
Click
System Preferences in the Dock, and then click Print & Fax
3.
Click + (Add).
4.
Select the entry for the printer in the list with Bluetooth beside its name, and then click Add
5.
Set Bluetooth security for the printer
You can enable the following printer security settings:
• Require passkey authentication prior to someone printing to the printer from a Bluetooth device.
• Make the printer visible or invisible to Bluetooth printers that are within range.
• To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools.
Set up the printer for Bluetooth communication 93
Use a passkey to authenticate Bluetooth devices
You can set the security level of the printer to either
High or Low
• Low : The printer does not require a passkey. Any Bluetooth device within range can print to it.
NOTE:
The default security setting is Low
. Low level security does not require authentication.
• High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it.
NOTE:
The printer ships with a predefined passkey that is set to six zeroes "000000".
Set the printer to be visible or not visible to Bluetooth devices
You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private).
•Visible : Any Bluetooth device within range can print to the printer.
• Not visible : Only Bluetooth devices that have stor
ed the device address of the printer can print to it.
NOTE:
The printer ships with a default accessibility level of Visible
To reset to factory default settings
NOTE:
Using the following instructions will reset only the device's Bluetooth settings.
1. Press and hold down (Power button).
2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times.
3.Release (Power button).
Sep 11, 2014 | HP Officejet 100 Mobile Inkjet Printer,...
Screen freezes when reloading system disc
Instructions
Back up any important files already on your G4's hard drive. A factory restore completely wipes the system of all files you've created so, if possible, make sure you have another copy of all your files, images, music, etc.
Connect your G4 to its charger. Restoring the computer is a delicate process that erases and reinstalls the most basic and important files of your system. If the computer runs out of battery before the restoration is complete, files may be damaged or left uninstalled. The result of this varies from having to restart the process completely to permanent dysfunction of your computer. Play it safe. Make sure you have plenty of battery left and the computer is plugged into the wall.
Locate your Mac OS X Install CD/DVD. If you have lost the original disc or never received one (a common problem when purchasing used computers), there are a few options to consider. The first is to ask around; if you have friends or family with a Mac computer they may still have their CD. It would be usable on your computer. If this option fails, look online for a download of the installation CD. Some sites offer installation CDs for all kinds of computers, including the G4.
Insert the install disc into your computer's disk drive. Once visible, click the "Install Mac OS X" button. Follow the on-screen prompts to set up your computer preferences and begin installation.
Select a destination disc for the installation. This is typically the "Macintosh HD" icon. Next, click "Options," and follow the rest of the on-screen prompts/instructions. After this, the software is installed. The computer should reset itself or can be manually reset by holding down the power button twice.
Jul 25, 2012 | Apple iMac G4 Desktop
When i turn my calculator on it says "RAM cleared". It is then very slow . . . what is wrong and how can I fix it?
Hi yeager anna,
Since the calculator operates slowly even after the RAM has been cleared, I'd say, "Your OS must be corrupt." You need to re-install the Ti 84 Plus OS, ASAP!!! You can fix this problem by installing the newest Ti 84 Plus 2.55v. MP OS, operating system. Use fresh batteries when installing the new OS. If you need additional instructions your welcome to read my Ti 84 Plus solutions. I pretty much tell how you can install the new OS with another Ti 84 Plus calculator or, connecting the computer to the calculator to install the new OS. You can view my solution to install OS by clicking, "Ti 84 Plus OS installation." Just stroll down to oneplusgh's solution at that posting and, I cover a lot of topics you may need advice on to install the new OS.
If you need instructions to downloading and installing TI Connect on a XP or, Mac computer click, "TI Connect on a XP or Mac computer." I realize this posting was for a later OS but, this link will take you to the latest TI Connect software and, newest OS too. Once you get the TI Connect software installed come back to this posting and, follow the instructions above at "Ti 84 Plus OS installation."
If you need instructions to downloading and installing TI Connect on a Windows 7 computer click, "TI Connect on a Windows 7 computer." Just follow Procedure 3. You can also get instructions at this link on how to install the Ti driver to link computer and calculator. I realize this link instructions were for a Ti 89 calculator but, they will work for a Ti 84 Plus too. Once you get the TI Connect software installed come back to this posting and, follow the instructions above at "Ti 84 Plus OS installation."
My instructions is geared to save you a lot of hardship. No matter if your having to install Ti Connect or, the newest OS for your calculator. I do not use TI OSDownloader because, TI OSDownloader might not give you the newest OS for your calculator. My instructions will. If you have any questions just post a comment and, I'll respond quickly.
Jan 20, 2011 | Texas Instruments TI-84 Plus Silver...
I downloaded adobe digital editions. They ask for an id and password which I don't have. When I click on the register it sends me to this page. How do I register?
Mac OS solutions Uninstall previous versions of Digital Editions for Mac OS
You must have administrator privileges to complete these steps.
  1. From your user directory, locate /Library/Preferences/Macromedia/Flash Player/www.macromedia.com/bin/open.
  2. Drag the digitaleditions1x5 folder to the Trash, and empty the Trash.
Manually install Adobe Digital Editions for Mac OS
  1. Finish installing or uninstalling any other applications.
  2. Uninstall any earlier versions of Adobe Digital Editions.
  3. Download the installer package for your Mac OS X machine:
  1. Click Open in the File Download screen to start the installation.
    Note: If your connection times out, click Save, instead of Open, to save the installer package to your desktop.
  2. If necessary, unzip the .zip file. If you're using Safari as your browser, or if Firefox is set up to unzip files, the file unzips automatically.
  3. Double-click the .pkg file to start the installer, and follow the onscreen instructions.
Note: If your connection times out, save the installer package to your desktop. (Click the link for your Mac OS X machine, and then click Save.) Double-click the file to start the installation.
Dec 11, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Installed mac osx 10.6.1 and my fuji wont print HELP!
Some manufacturers have not caught up and updated their drivers for snow leopard yet.  You gots ta be patient and wait a couple months or call the manufacturer and ask for a comparable driver that will run off snow leopard. Go back to the previous OS if that was working your printer.  Don't fix it if it ain't broke.
Oct 12, 2009 | Apple Mac OS X 10.4 Tiger for Mac
Wireless Printing set up
In order to print via Bluetooth communication with Macintosh, the following system requirements must be satisfied.
Computer
A Macintosh with an internal Apple Bluetooth module or a Macintosh attached D-LINK DBT-120 USB Bluetooth rev.B
OS
Mac OS X v.10.3.3 or later
In order to connect the Bluetooth unit and print via Bluetooth communication, the following steps are required.
STEP 1
Check that the Bluetooth unit is properly attached to the printer.
STEP 2
Install the MP Drivers.
STEP 3
Check the device name of the printer using the LCD.
STEP 4
Register the printer as a Bluetooth device using Bluetooth Setup Assistant.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Apr 23, 2009 | Canon Pixma MP500 All-In-One InkJet...
Macbook, lexmark f4270 driver
Apparently, the drivers for your printer is bundled in with the MAC OS CD. There are no MAC drivers on the Lexmark for your model. And the 4200 series should work.
Follow the instructions below.
Installing the bundled driver
Plug and Play
Steps Action 1 Power on the printer. 2 Plug the USB cable into the printer and into the Mac. 3 The Mac OS will automatically create the printer queue and install the printer.
Manual installation
If you plugged in the USB cable and the print queue was not created, follow these steps:
Steps Action Illustration 1 Plug the USB cable into the printer and into the Mac. ... 2 Launch System Preferences and select Print & Fax. Image 3 Click + to add the printer. Image 4 Select the printer, click Print Using and select your printer from the list. Then click Add to create the printer object. Image 5 Once the printer has been added, close System Preferences. The printer is now ready to print. Image
Troubleshooting
If you installed the driver from the printer·s installation CD or from a web download, uninstall it and follow the instructions below for recovering the driver from the Mac OS 10.5 (Leopard) CD.
Steps Action Illustration 1 Uninstall the installed driver. ... 2 Delete the Lexmark folder found in Library/Printers.
... 3
Insert the Mac OS 10.5 (Leopard) CD to recover the bundled driver and then click Optional Installs. Image 4 Click Optional Installs.mpkg. Image 5 Go through the installation process. ... 6 In the Optional Installs screen, select first Printer Drivers and then Lexmark Printer Drivers. Image 7 Click Continue and complete the installation process. ...
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 05, 2008 | Computers & Internet
Troubleshooting Password Problem OS 10.4.11
Follow these steps -
1. Start up from a Mac OS X Installation CD (one with a version that is closest to the version of Mac OS X installed on your Mac).
You should first disable Open Firmware password protection, if it is enabled. Hold the C key as the computer starts.
2. From the Installer menu Choose "Reset Password" (if you have Mac OS X 10.4 Tiger this will be the "Utilities menu").
Tip: If you don't see this menu or menu choice, you're probably not started from the CD yet.
3. Select your Mac OS X hard disk volume.
4. Set the user name of your original administrator account.
Do not select "System Administrator (root)".
5. Enter new password.
6. Save.
7. Follow these instructions to set Keychain Access -
http://support.apple.com/kb/HT1631
Aug 11, 2008 | Apple Mac OS X 10.4
Regarding Bluetooth
hi there!, about your problem make sure that you visibility is shown to all, remote sim mode if OFF and well yeah the bluetooth is on xD
May 09, 2008 | Nokia 6233 Cellular Phone
Screen turns to sepia
The best thing you can do with a Mac that is having "trouble" is to do an archive and install, one of the install options on the Mac OS X DVD. The instructions and more information are in the following AppleCare tech note. If you have any further questions, please feel free to write back.
 Chris 
May 04, 2008 | Apple Mac OS X 10.4 Tiger for Mac
Kodak EasyShare Photo Printer 500 Logo
180 people viewed this question
Top Kodak Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
