Question about Creative Labs Nomad MuVo2 FM MP3 Player
Stuck in recovery mode and i don't know what to do
Well, here's the problem: I recently purchased a used Creative Nomad MuVo^2 and it was playing songs and all, but when i tried hooking it up through the sb port, it wasn't recognized by the computer. So, I went to the Creative website and dowloaded all the firmware needed for the player. But my plpayer was still not recognized by the computer. I have posted many questions on the Creative support labs, but noone seems to want to help. I tried the recovery mode and I finally figured out how to get it and all, but when i plug in my player via the usb port, the player's screen changes to looking like it is transferring data to the player, but it's not. I want to know if maybe the usb cable is bad or has some else had this problem and what they did to fix it. Thanks, Libertydork
  • safii Jun 10, 2008
    my MuVo2 FM MP3 Player is stuck on recovery mode. when i format it, it gets hot and operate slowly. what should i do?
I recently had a similar problem, and nothing I did helped; what I eventually did sounds pretty simple and possibly won't help ( I have a feeling that it might have been a USB port issue, more than anything). I have added the description of my problem below my 'solution'.
I disconnected the player from my PC, restarted the PC, disconnected & reconnected the battery from the Muvo2, turned the player on (just to check if it was reading the music) then turned the player off. Then (with the Muvo2 powered off) I reconnected the player to the USB cable; the darn thing was recognised immediately and was working fine...
My problem:
The player was working fine, Windows (XP Pro) recognised the device as a Muvo2 & I could transfer files no problem; I clicked on 'Safely remove hardware' and removed the player. However, when I now try to reconnect the payer Windows gives me an error message, that one of my USB devices failed to connect and that it doesn't recognise the device. It suggests reconnecting, which does nothing...
The Muvo2 screen displays the 'connected to computer' image. If I disconnect using the 'Safely remove hardware' and unplug the cable, the player display says I need to connect to my PC and run scandisk. I can't get the computer to recognise the device, so I can't run scandisk. Removing and reinserting the player's battery got rid of the 'Scandisk' message & the player worked again, but it's still not connecting to the PC.
Posted on Jan 24, 2008
Only have 50 songs on my muvo tx fm mp3 player and it is full
This is the file system problem. Use the below tool to solve it.
http://ccfiles.creative.com/ManualDn/Applications/PDE/11124/0x46D235F9/CT-RT_PCAPP_2_01_03.exe
BEFORE YOU START
  • Check that the MP3 Player Recovery Tool supports your player.
  • Ensure that you are using Windows XP® Service Pack 2 32-bit, Windows XP Professional x64 Edition or Windows Vista™ (32-bit or 64-bit version).
  • Back up the contents of your player, if possible, as recovering your player may require it to be re-formatted, erasing all content.
  • Make sure your player battery is at least 50% charged.
  • Detailed usage instructions are available in our Knowledge Base.
Sep 22, 2010 | Creative Labs Nomad MuVo TX MP3 Player
Hello... i have a problem with my muvo 5gb.. i don't know what happened but when i turn it on its entered in the recovery mode.. i have already tried every option in that mode but nothings happened and its...
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Oct 28, 2009 | Creative Labs Nomad MuVo2 FM MP3 Player
When I conect My Creative MuVo Tx Fm to my pc it will reconize it but not download.
# To install this firmware upgrade, do the following:
1. Download the MuVoV200_PCFW_LF_1_05_02.exe file into your local hard disk.
2. Connect your player to your computer.
3. Double-click the firmware upgrade file.
4. When prompted to set your player in Recovery mode, disconnect your player from your computer.
5. Press and hold the Play button while connecting your player to your computer's USB port.
6. Continue to hold the Play button for about ten seconds after connecting your player to your computer.
7. Release the Play button when the Find New Hardware dialog box appears on the computer screen.
8. Follow the instructions on the screen to install recovery drivers for your player.
9. Double-click the firmware upgrade file and follow the instructions on the screen.
Saludos...
Apr 15, 2008 | Creative Labs Nomad MuVo TX MP3 Player
What do i have to do.?? i/o error
you have a bad drive
http://repair4player.org/disassembly_creative.html
Jan 08, 2008 | Creative Labs Nomad MuVo TX MP3 Player
Shuts Down
My MuVO TX was having problems until I installed the latest firmware. The last firmware release was in March 2007. If you haven't updated the player's firmware since then, try downloading it and installing Creative MuVo TX FM Firmware 1.24.02.
Nov 01, 2007 | Creative Labs Nomad MuVo TX MP3 Player
Reset
how do i reset my muvo2 Fm mp3 player
NEEED HELPP
Oct 20, 2007 | Creative Labs Nomad MuVo2 FM MP3 Player
Help please
Oct 09, 2007 | Creative Labs Nomad MuVo TX MP3 Player
No sound
When you buy a new Creative NOMAD MuVo, the flash drive comes with some files, if you have the original installation disk, I think tha you can restore that files and the player will works.
I have the same problem, but I lost the instalation Files and my Muvo does not have the files on it.
Sep 12, 2007 | Creative Labs Nomad MuVo MP3 Player
Firmware problem
i have a muvo2 fm and reloaded the firmware off the creative website..
Jan 24, 2007 | Creative Labs Nomad MuVo2 FM MP3 Player
Fuzzy noise
Jul 16, 2006 | Creative Labs Nomad MuVo TX MP3 Player
Creative Labs Nomad MuVo2 FM MP3 Player Logo
465 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Mohamed Ismail
Mohamed Ismail
Marvin
Marvin
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
