Question about Sony Mavica MVC-CD350 Digital Camera
Code e:61:00 appears on screen when turned on.
When first turned on shows record folder then goes right to E:61;00 code, viewfinder very fuzzy, will take picture but picture out of focus, tried reset per manual no go, happened once before, put in a drawer and pulled out six months later and was fine for a couple of months.
  • tjames369 Dec 02, 2008
    additional symptons, with 61 code flashing on screen it will take fuzzy pictures but will only review and delete one, like it's the only picture that was taken. Your first expert refered to page 51 in manual which in my manual is Shooting in Multi Burst Mode and has nothing to with set up.
    Enjoy the $9.95 and I'll take two aspiran and call you in the morning!
    Tried tapping the camera sides gently no luck same code 61.
  • 153 Answers
Try this:turn off the cam, remove memory card, remove the battery , and place everything again into the cam. and test.
Posted on Dec 02, 2008
  • 10,594 Answers
Below is exploded view of Lens section of MVC-CD350 model and it has 2 small stepping motors (marked with red arrow), one of them got jammed so you get E-61-00 error.
If you know camera repair, apart it and take out lens with care. open 2 screws at top of stepping motor face plate , pull up slightly and rotate it with finger and place it back. do the same with second motor and done.
Good luck.
code e:61:00 appears on screen when turned on. - b5d7445.jpg
  • Sony Master
  • 1,800 Answers
Do not perform any act of fixing to the camera. u will damage the flex cable cuz the ZOOM is stucked plz
just try to take it apart and see if u can find the zoom part its esay to replace juts a small electronic connector!!
    Sergeant:
  • 237 Answers
Error code E:61 means a service issue has been detected and requires service (haha), but you need to take it to a sony dealer repair shop...click on the link to find one near you.  if you need any more info, let me know
http://eservice.sony.com/webrma/web/index.do
    Sergeant:
  • 217 Answers
The error what u r getting is due to faulty or dirty lens of the camera.try to tap on the sides of the camera if this error is due to any part got shaked or moved from its position this will help u.just tap all the sides of the camera with your hands gently.
    Sergeant:
  • 306 Answers
Press the reset button on the bottom of the camera. Then power the camera off, and power it back on again.
E 61 00 means  Difficult to adjust focus Inspect the lens block focus reset sensor
  • 1 more comment
  • AbdulRahiman S Dec 02, 2008
     hitting or shaking the camera seems to work..
    else try turning the camera on and give it a big whack on a hard surface.Turn off and see . 3-4 for times should work. A stuck lense problem
    else try tis>>Try resetting your camera to factory defaults: Turn off the camera.,Ensure the camera is not connected to an AC power adapter.,Remove the battery from the camera for 15 seconds.,Reinsert the battery. , Turn on the camera.
  • 734 Answers
Error code E:61:00 means the camera has encountered a malfunction, and you should try initializing the camera back to the factory settings. Instructions on how to do this are on page 51 of your user manual, and I have included a link to a PDF download of your manual if you no longer have it. If this doesn't work I would have the camera looked at by an authorized service technician. I hope this helps!
http://esupport.sony.com/US/perl/model-documents.pl?mdl=DSCT7
Sincerely,
  • Sony Master
  • 19,396 Answers
Code e:61:00 on a Sony camera, means lens error.
  • Ginko
    Ginko Dec 02, 2008
    code e:61:00 on a Sony camera, means lens error.
    This usually happens because the lens mechanism is stuck or damaged.
    If lens extract and retract regularly, code e:61:00 means that the camera focus mechanism is faulty.
    Toi fix it the lens assembly must be taken apart and re-assembled, this job can only be done by an expert technician, unless you want to risk transforming your camera in a bunch of bits and screws.
Hello my question is about what I think is a mirror issue on my n75 Nikon camera. When I look through the viewfinder the picture appears fuzzy. I looked closely at the lens and it does not look like it...
First off, with no lens attached, it will always be fuzzy, there is nothing to focus the light. Second, if you're looking at the mirror, you should be able to tell if it's dirty - if it is, glass cleaner and a soft rag are all that are required.
I'd suspect however that neither are your issue. Either your focusing screen is out of place or damaged, or your camera's diopter correction (if it has it) has been moved, Look for a small dial right next to your viewfinder with a +/- on it, and with the lens attached, and focused, turn the dial until everything is in focus. If your camera has this dial, it'll be usually on the right side of the viewfinder window.
If it does not have it you'll need to seek a repair shop to check your focusing screen since the mirror is 99% not going to be the cause of your problem. If there are no shops locally, google KEH Camera. It'll run you $35 for an estimate, waived if you decide to have any needed repairs done.
Sep 08, 2011 | Nikon N75 35mm SLR Camera
The problem i m having with my camcorder is when i want to record film screen goes blank but i can watch my previous recorded videos
Look in the view finder when recording instead of the screen. if you see the image there then the unit is probably set to look through there. Many of the new units dont' have a full view finder to lens item they actually have a small lcd screen inside the view finder. Check your options for recording.
Also if the view finder is tilted you need to close that before usign the lcd.
The image will not appear simultaneously on the LCD
monitor and the viewfinder. It will appear in the
viewfinder when the LCD monitor is in the lock position,
and it will appear on the LCD monitor when fully
extended.
Mar 02, 2011 | JVC GR-DVL820U Mini DV Digital Camcorder
Viewfinder and LCD screen only show black and record black
If camcorder shows old recorded tapes picture with correct colors in LCD but does not show live view in camera mode to record new movie then its ccd imager chip failure.
And if camcoder shows live view and old recorded tapes in its eye piece view finder but does not show any thing in LCD the its problem of broekn/ cracked flexible wire between lcd board and main board of camcorder.
Let me know your finding with bit detail to provide you solution/ helpful info.
Nov 18, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Will not record nor replay.
I Had The Same Problem I Just Turned The Screen A Different Way And It Worked Again
Jan 07, 2009 | Video Cameras
Shooting mode shows nothing.
I just had this issue with my camera (my 15 year old son solved it for me ;-) ).
The viewfinder was active in "record" mode and the LCD was "active" because you could see a little back light but no image. The "playback" mode would let me review pictures in the LCD though so I know it is capable of showing information.
If you push the display key/button a couple of times you can see the picture move from the viewfinder to the LCD and have just a picture and or a picture and information.
So try setting the camera to "record" mode (lens comes out) and then push the "display button" which is on the back of the camera just to the right of the LCD on the lower right side several times and see if the LCD starts to work.
It could be that somehow the display button was pushed by mistake.
Bill
Dec 07, 2008 | Canon PowerShot S3 IS Digital Camera
TOSHIBA SATELLITE L40 SCREEN SHOWS A FUZZY TOSHIBA LOGO AND GOES BLACK
change your flexible wire (vga) connected from board to the screen, also change your module, the module is at the rear of the screen.
Jun 02, 2008 | Toshiba Satellite A135-S2276 Notebook
Fuzzy vertical lines on display, viewfinder on recording
This problem may be due to a malfunction of the CCD image sensor in the camera. It is defective in this model and canon will repair it for you at no charge. Here is the link to their service notice. You can call the 1800 no in the article and they will send you a form along with a ups label to send the camera to them.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=818&id=29819&keycode=2112&modelid=9739
Hope this helps:)
May 31, 2008 | Canon ZR85 Mini DV Digital Camcorder
Recording problem
Knowledge Article C116445
There is no picture or a black screen appears in the viewfinder or LCD when attempting to record. Follow this procedure to troubleshoot if there is no picture or a black screen appears in the viewfinder or LCD when attempting to record. NOTES:
  • Because each of these steps represents a possible solution to this issue, check the viewfinder or LCD status after completing each step.
  • It may be necessary to refer to the operating instructions provided with the camcorder for information on how to perform a task on your specific model.
  1. Ensure the lens cap on the front of the camcorder has been removed.
  2. Ensure a fully-charged battery is inserted in the camcorder.
  3. Ensure the STANDBY/LOCK switch is set to the STANDBY position.
  4. Turn on the camcorder and set it to the CAMERA mode.
  5. Look to see if an image can be seen in the viewfinder or LCD.
  6. IMPORTANT: Some camcorders have both a viewfinder and LCD. To conserve power, the viewfinder and LCD will not display at the same time. To use the viewfinder, the LCD must be closed.
  7. If the issue is not resolved, reset the camcorder to factory specifications.
NOTE: If the issue is still unresolved after completing the troubleshootin
Nov 30, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Won't record/No picture thru the LCD screen or viewfinder in Record or Standby Mode
it is a common problem with them. sony has a recall on ccd imager for this model. call sony and they will fix it for free
May 29, 2007 | Sony Handycam DCR-TRV22 Mini DV Digital...
Viewfinder screwing up play back
Is it only in the Viewfinder, or also on the LCD, or also transfers to the recording?
Jun 22, 2006 | Sony Handycam DCR-TRV740 Digital Camcorder
Sony Mavica MVC-CD350 Digital Camera Logo
172 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
