Question about AudioBahn AW1206T Car Subwoofer
Lights dimming i have 2 audiobahn aw1206T subwoofers wired up to a hifonics bxi2008D amplifier and have it hooked up with a lanzar VBRCP10 Capacitor, do u suggest i had a extra battery on the back or what u suggest
  • kingsleepy69 Dec 06, 2008
    so you suggesting i add a extra battery , and do you think changing my battery to a optima battery would make a difference cuz i have a yr old battery but it aint a optima battery and i heard they are good fo audio but not sure if its good enough to be used for my car and audio or just adding a extra battery would b better
    Problem Solver:
  • 11 Answers
You may also want to put a power regulator on it, they are the things that look like tubes with wires comming off them and a little display, it helps from dimming becouse it holds power and when the subs use more than battery this thing will give it the extra boost so that you arnt draining your battery, you can get them for all diffent watages, battery is also one of the best ways to fix this problem
Posted on Apr 13, 2009
  • 3 Answers
Do the big 3 upgrade. Yellow top optima, H/O altnernator, all 0 gauge power wire. And you dont need anything after that. Make sure to get around 200amp or more alternator.
Posted on Apr 12, 2009
    Problem Solver:
  • 22 Answers
It doesn't hurt to have a separate battery for your system but not necessary. You're pulling enough power to do it if you want to save the beating your alternator takes evan with a power cap
Posted on Dec 04, 2008
I have two audiobahn aw1206t 12in. subs in a box hooked to a 100.1 american bass amp its 1000 watt mono block. i also ran a capacitor due to my lights dimming. but for some reason my amp keeps kicking over...
This could be caused due to the impedance load being to low. Your amp is stable to 2 ohm load however its very possible that you have your subs wired to a 1 ohm load that would cause the amp to go into protect mode. The subs you have are dual 4 ohm voice coils and would need to be wired in series/parallel. I've included a link that will show you how the subs should be wired.
http://a248.e.akamai.net/pix.crutchfield.com/ca/learningcenter/car/subwoofer_wiring/2-DVC-4-ohm-mono-low-imp.jpg
May 16, 2011 | AudioBahn AW1206T Car Subwoofer
No sound through speakers i want to have my aw1206t audiobahn fixxed
Are you hooking it up to an appropriate power source? Are you hooking up the power to the power and the ground to the ground, Is the speaker in a box or car panel, if so you may need to take it out to look at the outlets built onto the outside of the speaker to make sure they are not damaged or broken. Other then that the only other thing you can really check is if the bottom of the speaker is still magnetic. If there are any cracks on the actual speaker and when you lightly push it in do you get an audible bump sound.
Feb 07, 2011 | AudioBahn AW1206T Car Subwoofer
I got 8 terminals on a my 15 audiobahn sub how do i hook at 2ohm load
Yes audiobahn do make a QUAD coil, and some people get confused with the - - + + on the terminal, This is called a dual lug, Check out Audiobahn.com and go to tech suport. Thier you can look up the wiring diagram for this sub... TRUST ME hope this was helpful positive feed back be nice lol
Apr 08, 2010 | AudioBahn AW1206T Car Subwoofer
I need help hooking up a 12" alum audiobahn
check out audiobahn.com and click on the tech support. then you while see some diagrams for subs, for different ways check it out it helped me out with my aw1508x being pushed by two a2300hcx
Mar 01, 2010 | AudioBahn AW1206T Car Subwoofer
How i connect the light of my sub?
If you have a subwoofer that illuminates - there will be an extra set of terminals on the basket.
This requires a seperate set of power and ground wires along with a toggle switch.
If you want to - you can put the ground on the amplifier's ground, power off the amplifier's power (to a spdt relay) and have the relay activated with the remote wire terminal on the amplifier.
This way it will turn on and off with your stereo system and you wont come out in the morning to a drained battery from forgetting to turn it off.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Jul 31, 2009 | AudioBahn AW1206T Car Subwoofer
Audiobahn AW1206T manual
i was just in AUDIOBAHN.COM website yes it's still thier check it out agian
Apr 11, 2009 | AudioBahn AW1206T Car Subwoofer
HELP
hi there, do you have an amplifier to hook it upto mate? if you do its best to go into your local halfords etc and ask for a wiring kit for you car audio, or search on ebay, theyre normally around 20pounds. then it will come with instructions on where certain wires go etc, the 8 outputs are probably so you can connect two subs together. they should have a pos and neg on them somewhere. if you dont have an amp you probably need to buy one. if you have any further queries just ask mate
Nov 13, 2007 | AudioBahn AW1206T Car Subwoofer
AudioBahn AW1206T Car Subwoofer Logo
104 people viewed this question
Top AudioBahn Car Audio & Video Experts
Colin Stickland
Colin Stickland
Jerry Naidoo
Robert Rankin
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
