Question about Whirlpool RBD245PD Electric Double Oven
Oven fan The fan to my oven keeps clicking on and off every 2-3 minutes (sometimes even more frequently), all day long. This is when it has not been in use for many hours or even the entire day. The oven is stone cold, yet the fan clicks on, runs for maybe 2 seconds, then clicks off. Twice last week, the display panel showed PF for power failure, and the clock had to be reset. There was no power failure anywhere else in the room or house.
    President:
  • 878 Answers
Helt, there was a service flash on this model having to do with a wire in the wiring harness not made to specifications. Now, Im just going by the model number posted. Depending on your serial number your model could be included. What it sounds like is that your fan limit switch is gone wacky. This is located in the rear of the oven and tests would have to be done to determine if that switch is closing for some reason. There were other service flashes on this model concerning the thermal cut out mounted just below the vent causing it to open during cleaning. You might want to call for service and see if your appliance is covered under these service flashes. Catriver..post back.
Posted on Feb 11, 2007
SOURCE:
Smeg oven: UK 80 MFX: Intermittent fault with circular fan element.
either a bad connection on the element terminals or faulty element
Jul 10, 2018 | Smeg Ovens
The fan runs when power to the cooker is on but the oven itself is not switched on.
Probably the cooling fan. There is a cabinet thermostat on most ovens these days (Especially wall or underbench models) to keep the cooling fan running after the cooking has finished and oven turned off. This fan will run for a few minutes to cool down the outside of the oven so it doesn't burn / discolour the surrounding cabinet or workbench. If the fan stays on all the time, I would say that the thermostat has probably jammed in the run or on position.
Mar 21, 2017 | Ovens
Oven works well some days but occasionally will quit heating intermittently. Sometimes becoming frequently usually.
Dan, try cleaning or just replace the ovens temperature sensor, normally located on back wall, its like a copper wire with a small slim copper tube on the end.
Feb 17, 2016 | Ovens
CANDY F 254
Possibly the fan in the oven has developed a fault. Get an electrician to come and test the fan.
The worker should do tests on the oven to make sure everything is safe to use once any repairs are done.
Mar 16, 2014 | Candy Ovens
I have a MEW6527DDS built in oven. This all happens when the oven is NOT in use: The fan goes on and off, sometimes for a second, sometimes for 10+, ALL.DAY.LONG! The 'click' sound you hear when...
Wow deffinately sounds like the control brd it sounds like a pretty good examination by somebody that is used to electric.It would be a very complicated troubleshoot over a message brd.The temp problem could be calibration issues or a bad thermistor not reading to the oven correctly.but intermittent kicking on off could be more.Maybe some programming issues usually shut the power off and back on to reset but if your turning off the breaker that would rule that out.Maybe turn of power and chek plugs and wire for loose connections.that would be a good start.
Apr 25, 2011 | Maytag MEW6527DDS Electric Single Oven
Hobart convexion oven model CN90 . THE FAN MOTOR CUTS OFF AND ON WHEN IT IS IN USE WHAT CAUSE THIS I THOUGHT IT IS SUPPOSE TO RUN ALL THE TIME
No they usually run 2 minutes one way and 2 minutes in opposite direction to even out the baking.
Unless its erratic then something else is wrong.
Feb 17, 2011 | Ovens
Baumatic oven not heating up. Grill and fan fine.
if it is the b180, the answer (having just fixed this) is really simple.
The coily bit is the oven element - it will have gone. A new one from eBay cost me about 6 quid.
[WHEN IT ARRIVES !]
Turn the power off.
Inside the oven use a philips screwdriver to remove the 4 screws (KEEP THEM !)
You will see a coily thing and a fan.
You unscrew 3 more screws (2 on the left and 1 on the right).
(KEEP THESE TOO!)
now ... bit tricky, have the new one inside the oven and take each wire off one at a time and put it on the new element.
Screw it back on but DONT put the last panel back in.
Turn the oven on maximum for about 2 minutes and see it glow red.
Turn the oven off. Make a cup of tea and have a couple of biscuits while admiring how good you are and waiting for the element to cool down!!!
Put the final panel back in place. Whole thing (including a cup of tea) takes about half an hour.
Jan 27, 2010 | Baumatic B180 Electric Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
3rd blown element
no connection between lights on fan. problem is that bulbs these days are poor quality (but cheap)
it is common for these circular elements to go. usually last about 2 years. worth checking tho that fan is turning at right speed
Jun 21, 2008 | Neff U1721 Double circotherm Electric Oven
Oven fan keeps on clicking
There are two things that you can check. one is your circuit breaker itself and the other is the internal terminal block that the main wires feed into. the terminal block could have loose wires which will cuase an intermittant PF to appear on the oven, disconnect from power before checking. The voltage at the oven will have to be checked with a multimeter to verify the proper levels. Be sure to be extra careful around electrical connections while the oven is connected to power.
Mar 06, 2007 | Whirlpool RBD245PD Electric Double Oven
Whirlpool RBD245PD Electric Double Oven Logo
134 people viewed this question
Top Whirlpool Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
