Question about Hotpoint Aquarius WF000 Front Load Washer
Ihave had flashing lights on a hotpoint wt540p
I need to know how to gain access to the pump chamber to see if it is blocked the manual says at the front at the bottom but there seems no way of screwing this piece off any help out there i cant afford an engineer so close to christmas
  • luluboo Mar 17, 2009
    I had the same problem and just want to say thank you, this site is amazing. The steps given were clear and easy to follow even for a novice like me. Saved me the price of a plumber!
  • Hotpoint Master
  • 3,463 Answers
The pump is actually a self cleaning pump, but there is a filter located behind the bottom kick strip at the front bottom of the washer.
To access it you should see 2 screws in the panel, unscrew these and remove the panel, then you will see the filter,unscew it anti clockwise and remove the filter, clean as neccessary, see if you can see anything in the filter chamber. and refit it. This should solve your problem.
Plz leave feedback.
Ta.
Posted on Dec 09, 2008
  • Barry Coates
    Barry Coates Dec 09, 2008
    Not all models have this feature.
    If no luck, come back to me.
Hotpoint dishwasher 4th & 6th lights flashing
You will need to provide the model number of the dishwasher. However, the likely causes of the lights flashing are many, including water inlet failure, blocked drain filter, leaking seals causing flood switch to trip. You may want to go to the Hotpoint site and find the manual for your model.
Nov 05, 2012 | Dishwashers
My problem same as Kelly. Stops at spin lights flash - no coins blocking - have checked. What next
there maybe a small coin that has entered the outlet chamber of the pump housing, check this.
Jan 28, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Wd 640
Error code F05 indicates that the water level switch is stuck in the closed position, this is probablly due to a blocked filter or pump.
To gain access to the pump and filter, remove the lower rear panel of washer, locate and remove large black hose fastened to the bottom of tub.
Remove filter inside hose and clean, check inside pump for any blockage or restriction, and make sure the plastic chamber is clean where the small plastic hose is fastened to, as this goes up to the water level switch, and can sometimes get blocked.
Refit filter and hose, making sure it is securely on and fastened, and test, if fault still persists, then you will probably neeed to fit a new water level switch, or preesure switch as it is usually called.
Please rate my solution to your problem.
Thankyou.
Jan 27, 2009 | Hotpoint Aquarius WD640 Front Load...
Water wont drain from Machine or go onto spin cycle
either the level control switch has become blocked or faulty or the drain pump has become stuck.
disconnect from the mains and gain access to the rear look for a circular unit with two or three electrical connections and a plastic tube. this is the level control.follow the tube to its start and you will find a plastic connection that goes into the wash drum, remove the plastic tube from the switch end and blow into it. if there is no restistance then the system is OK at the drum end. next reconnect the tube to the switch and remove the opposite end, very gently blow down the tube and you should hear the switch operate. Test wether the switch is working by putting a meter across the switch and blow into the tube. if all of this is OK then the drain pump is at fault. locate the drain pump. it is connected to the outlet tube, try turning by hand. if it does not rotate smoothly remove the clips holding the pump body together and clear the obstruction.
Dec 27, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Flashing on/off switch flashing energy saver light
I had the same problem with our hotpoint aquarius WT540P , I contacted EMW electronics who told me it was most likley the Computer board. They supply reworked replacedment boards on an exchange basis. I installed the replacement and the machine's been washing away merrily since. Here's a link to there web site. http://www.emwelec.co.uk/ .
Regards.
Nigel
Apr 22, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Dishwasher error codes please help
I too had this problen today. Printed off a manual from the Hotpoint website. Very helpful troubleshoot section. Anyway, flashing eco and fast lights and beeping sound indicates 'water feed pipe blocked' You need to check the water inlet connections on your tap.However, when we pulled it out we noticed the blue water inlet pipe was slightly kinked. Straightened this out and hey presto! It works fine again. How this happens when its worked ok for 18 months will never know but still. Try it! hope this was helpful...shewoo
Apr 26, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Hotpoint Aquarius WF000 Front Load Washer Logo
349 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
