Question about Brother Office Equipment & Supplies
I have Model # HL-7050 Brother The toner display red lite will not shut off when I try to put in a new toner cartridge.
  • 1 more comment
  • jimmusic Dec 01, 2008
    The red Toner Life End notice refuses to go out
    no matter how many times I put in diffirent cartridges.It seems to be stuck in that position.HL-7050 Model
    The Last advice did not work Need Help.
    The advise I received did not help the problem
    Even after trying to clear with the 4 second button relace message still comes back.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
For a Brother HL-7050, it is required that a fuse need to be replaced each time the the TN700 toner cartridge is replaced. This is so that laser printing system will reset the toner cartridge page counter.
The technically correct procedure would be to follow the steps as outline in the repair manual. Therefore, it would be to your advantage access to a service manual. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
    Master:
  • 505 Answers
1. Make sure you have opened the seal
2. Make sure the new toner you are connecting is properly connected, Until the toner is detected the red light will not go off.
Thanks.
  • 162 Answers
Nasty toner end of life error
brother will tell you to send the unit for service a lot of people that use brother printers have that same error
you have to replace the fuse for the toner.
  • 1,879 Answers
Toner Cartridge Fuse for Use in Brother® HL-7050
Static Control now offers a fuse for the Brother® TN-700 toner cartridge, used in the Brother HL-7050 printer. A “killer" fuse that blows when the toner cartridge is inserted in the printer, the fuse must be replaced when “Toner Life End" is reached. SCC’s fuse allows the toner cartridge to function properly and clears the “Toner Life End" message so that the printer can resume printing.
more info - click here
    Genius:
  • 1,011 Answers
Dear Sir,
for more information click this link
http://welcome.solutions.brother.com/bsc/Public/CountryTop.aspx?reg=us&c=us&lang=en
thanks
good luck
    Sergeant:
  • 237 Answers
You need to have the printer turned off before inserting the new toner cartridge. If you have done this, unplug the printer, wait a few minutes and plug it back in. Then turn the printer on again. This should resolve the issue.
    Sergeant:
  • 217 Answers
Again remove the toner cartridge and reinsert.it properly the printer is not detecting the toner in it.
  • llincon Dec 01, 2008
    ok.unplug the printer from main power outlet.remove the cartridge.then after sometime on the printer.then install the cartridge again.if it still shows the red lite.then
    1)either the paper is jammed in it somewhere ,may be a small piece it could be.
    or the
    2)printer door not being closed properly.
    or
    3)the sensor which detects the toner in the printer is moved from its orignal position,just tap on all the sides of the printer even on --top and bottom so if its moved it gets adjusted automatically due to tapping.
    thanks.
Have a problem with HL-5370DW Status LED is red &
Hi, if you status led become red and only that light is on must be 1 of the following problems:
1.- Front Cover is opened
2.- Memory Full
3.- Option Tray is installed too much
4.- Print Overun
Sep 13, 2013 | Brother HL-5370DWT Laser Printer
Product is Brother HL-4150CDN laser printer. The LCD display is saying Replace Toner (Back) I have 2 black toner carts available. One that I slightly used previously before swapping it out with a new one...
Had this same problem on the same printer. Here is the solution.
Open the front cover of the printer and press "Cancel" & "Secure". This will access a secret menu that will let you reset the toner counter. There are 12 settings in all (3 per color).
Two thumbs up going out to TonerHacker007 on the fixyourownprinter.com forums for this one.
Jul 30, 2011 | Brother HL4150CDN Laser Printer
How do I access and change out the toner cartridge? (brother HL-2140 printer)
1 Turn your Brother HL-2140 laser printer on.
2 Open the front cover by pulling the top latch toward you.
3 Pull the printer drum unit toward you. Put it on the clean, blank sheet of paper.
4 Push the green lever on the drum assembly down.
5 Remove the empty toner cartridge from the drum unit.
6 Shake your replacement toner cartridge gently to evenly distribute the toner inside.
7 Put the new toner into the drum unit and slide the unit back into your Brother HL-2140 printer. Close the top cover.
See also Brother user manual for this model at: http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_2140_2170W_EN_1160.PDF
Feb 25, 2011 | Office Equipment & Supplies
Brother HL-4070 printing out black whole page. Is this drum problem?
Try swapping the black and the magenta (red) cartridge.
This will not damage the printer and you can see if the toner or the drum is defective.
If you get a red page, drum
Black page, toner cartridge
Mar 26, 2010 | Brother HL-4070CDW Printer
My HL-2140 brother laser printer is flashing a red error
1>If the toner lite is blinking , it's mean the toner life near to end. In these case please replace the toner cartridge.
2>f the drum lite is blinking , it's mean the drum life near to end. In these case please replace the drum.
I hope it will help to solve your printer problem.
Feb 09, 2010 | Brother HL 2140 Laser Printer
HL-5140 Brother laser printer red status light remains on.
The red lite indicates one of the following needs to be looked at:
Cover open (Front cover) Close the front cover.
Cover open (Jam clear cover) Close the jam clear cover of the fuser unit.
Memory full - Press the go button.
Print overrun - Press the go button.
Clean drum unit - Clean the corona wire.
Jan 15, 2009 | Brother HL 5140 Laser Printer
I have a brother HL-2070 laser printer and have just inserted a new toner cartridge. When I turn on the lase printer it is coming up orange light toner & will not print. Its as if its not recognising...
Have you tried shutting down and restarting after the cartridge was in?
Also at Brother there is a new driver download for your model, and other info.
http://www.brother-usa.com/SiteSearch.aspx?sk=hl-2070%20manual
May 01, 2008 | Brother HL-2040 Laser Printer
Toner lite will not go out or print
A couple of suggestions
1) Open door and remove drum and toner. Hold Go button down until all lights are on. Put drum and toner back in and shut door.
Another is.
1. Switch off printer
2. Switch on printer
3. Open front door
4. Remove toner/drum unit
5. With the door still open hold down the go button for 1 second
6. Put the toner/drum unit back in
7. With the door still open hold down the go button for 1 second
8. Close the door and press go to test
Apr 25, 2008 | Brother HL-5240 Laser Printer
Toner End Life
Ther is a small viewport (about 1/4" dia) on each end of the cartridge that a photo sensor apparently shines through. The port is not near the bottom, so there's room for plenty of toner below it. Put a small piece of electrical tape over one of them and it will print fine..
Just a thought it worked for soe of my frnds..its worth a try..
Oct 24, 2007 | Brother HL-6050DN Laser Printer
117 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
