Question about Dishwashers
My Kenmore Elite UtraWash Dishwasher won't drain completely. We have checked the hoses (water supply and drain connected to the disposal) - both are free of obstructions. We have taken the whole thing apart but can't get the plastic cover off to access the motor or "garbage disposal thingy" inside the dishwasher. All of the bolts were taken out, but it was still firmly attached. Didn't want to force it and potentially make the problem worse. Any suggestions before I call Sears Repair people?
  • bntjones1125 Dec 31, 2008
    Thanks! We eventually figured it out - I asked a dishwasher repair guy I met in the supermarket (hey- desperate times call for desperate measures!). He said it was the drain pump/motor - about $50 to replace the part. You're right - you access that from the bottom of the washer. Took about 10 minutes to replace once we got the washer out from under the counter. Has worked great since!
I have the same problem. The part you're talking about can be released from under the dishwasher to clean it. www.searspartsdirect.com has useful diagrams. I cleaned everything but still have the problem which is caused either by the "check balls", the "check valve" or the "pressure check" thing. I still have to figure it out. A good way to know if the system is obstructed is to press the drain button when there is some water left in the bottom.
Posted on Dec 31, 2008
  • Dave1980 Dec 31, 2008
    I forgot to clean my "check valve" which was obstructed. This is the white plastic part where the drain tube plugs onto. This resolved my problem.
Why kenmore elite dishwasher will not drain?
If it is connected to a disposal remove the drain hose and check for a restricted area in the hose or disposal this is common also check the drain hose for kinks be sure to elevate the hose before the drain area. If the drain hose is clear and the drain is clear then you could have a bad drain pump in the dishwasher.Most problems are a restricted drain or hose
Jul 22, 2014 | Kenmore 24" Built-In Dishwasher with...
Jenn air dishwasher won't fully drain
Your garbage disposal is clogged . Or your hose from your garbage disposal is flowing in the down position
Oct 22, 2012 | Kenmore Elite 45986 Front Load Washer
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
MY GE DISHWASHER IS CONNECTED AND RUNNING, UNIT HA...
hi just try this Is the door open or unlatched?
Make sure the door is completely closed and latched.
Was the selected cycle interrupted before completing?
The Clean light will come on when the cycle is complete. Wait until the Clean light comes on before trying to manually drain dishwasher. Press Cancel/Drain to try and drain the standing water.
Is the water level just covering the pump module?
This is normal. A small amount of water will be seen in the bottom of the sump area at the base of the pump. This is to ensure that the pump seal does not dry out.
Is the dishwasher drain hose connected to a garbage disposal?
For many dishwashers, the drain hose is connected to the disposal and the knockout plug must be removed from the disposer inlet.
Is the drain system blocked?
Run the disposer to clear the drain system.
Do you have an air gap at your sink?
Check to see if the air gap is blocked by foreign material. To clean the drain air gap, follow the cleaning instructions provided by the manufacturer. With most types, you lift off the chrome cover, unscrew the plastic cap, and then check for any soil buildup. Clean if necessary.
Is there a loop in the drain hose less than 20" (50.8 cm) above the floor?
Make sure the drain hose is looped up so that it touches the underside of the counter before connecting to the sink drain or disposer.
Is there a kink in the drain hose?
Replace a kinked drain hose.
Did you reuse an existing drain hose?
Make sure to use the new drain hose that came with the dishwasher.
Is the sink drain clogged?
If the sink is not draining well, a plumber may need to be contacted. Most dishwashers connect to the sink drain. If the sink drain is clogged, the dishwasher can't pump out water.
Is the drain hose too long?
If the supplied drain hose was replaced with a longer one it must be shorter than 12' (3.7m).
May 17, 2010 | Dishwashers
My kenmore ultra wash plus is not draining
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter.
Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore ultra wash dishwasher model 15752000 is not draining completely after cycle has finished
Hi
Thanks
Rylee
Oct 21, 2009 | Kenmore Dishwashers
Runs the cycle but doesn't drain completely
Hi
Thanks
Rylee
Oct 12, 2009 | Kenmore Dishwashers
Kenmore Elite Not Draining Water Completely
Check this link. Multiple causes are possible yet most is how drain is hooked up to disposal and back pressure built up. Hose must be installed correctly.
http://www.partselect.com/repair.aspx?appliance=dishwasher&part=water-wont-drain
Jul 22, 2009 | Siemens 24 in. SE64A630GB Built-In...
Dishwasher doesn't drain fully
Hello. Are you using liquid or powdered soap? In some models liquid soap will foam up and the drain motor can't pump out bubbles. Foaming can also happen if you pre-clean your dishes with liquid soap used for washing by hand. If it is foaming, you can poor non-dairy creamer or cooking oil into the bottom of the unit while it is in the wash cycle.
If foaming isn't a problem then the water level switch may be bad, the pump may be not pumping out as quickly as it should or you may need to take the hose off completely to make double sure that there isn't anything in it.
Did you check the air-gap next to your kitchen sink faucet. If you don't have an air-gap it may be hooked up to the garbage disposal and if you don't have a high loop in your drain hose the water can run back into the dishwasher especially if the disposal backs up.
Dec 03, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Dishwashers Logo
186 people viewed this question
Top Dishwashers Experts
