Question about Lexmark E210 Laser Printer
LEXMARK E210 Lights are flashing on the front panel. There are 4 lights. the light on the left flashes first then the other 3 lights to the right flash at the same time. Printer will not work. Is there a solution?
Go to pages 2-11 on in
http://www.feedroller.com/Store/Service%20Manual/E210.pdf
and you'll get all the light pattern decoded
good luck,
/JDe
Posted on Feb 23, 2009
Rear turn signal probem
Have you done any mods lately? Are you using the correct replacement bulbs? Make sure the wiring is not crossed.
Feb 02, 2015 | Cars & Trucks
How do you reset the photoconductor counter on the lexmark e260dn? the light is blinking yellow right after i replaced the toner cartridge. Have put this printer through a lot of use over the last 3/4 of...
1.open the front cover. Leave the printer powered on. 2. With the front cover open, press and hold the stop/cancel (X) button. 3. Eventually all of the lights will begin flashing, indicating that the photoconductor page count has reset. When you see this light sequence, let go of the X button.
4. Close the front cover.
NOTE: If you wish to confirm that the photoconductor page count has reset, print a menu settings page.
Jul 09, 2011 | Lexmark E260dn Laser Printer
Toner is changed but toner led flashingr
The flashing toner light indicates that the photoconductor kit needs to be replaced.
Use this Lexmark Part# : 12A8302 to order. After replacing the drum cartridge counter will have to be reset, Use the following steps.
1. Open the front door (press button on left side).
2. Press and hold the cancel button (x button) until all the lights flash in order.
3. Then close the front cover.
This will reset the drum counter to enable continued printing.
Jul 21, 2010 | Lexmark E232 Laser Printer
Light keeps fashing for cartridge
Here is something to try:
1. Make sure the new kit is installed and the printer is turned ON.
2. Open the front panel.
3. Hold the Cancel button in until the front panel LEDs flash.
4. Close the front panel
Sep 29, 2009 | Lexmark E250d Laser Printer
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a yellow blinking toner cartridge light. Neither the continue or cancel lights are lit up. This...
Sounds like your photocoductor is at lifes end. You can reset it by doing the following
1. Turn the printer off.
2. open the front cover
3. hold down the cancel X button while turning on the power and keep holding down until all lights stop flashing. Then let go of the x button and all lights should start to flash, close the front cover...and it should reset. You may have to turn the printer off and then back on once to be sure it is reset.
Jul 07, 2009 | Lexmark E232 Laser Printer
Printer light blinking
Customer Support SUPPORT"; //--> print.jpg Print | email.jpg Email | --> pagelink.jpg Link null.gif KnowledgeBase 433-75x75.gif Product
Product
--> Lexmark Z615 Country / Region:
Country / Region:
--> United States Language:
--> Language:
English Need to download
a driver?
--> Save my information--> Lights Flashing on the Lexmark Z815/ Z816 Color Jetprinter ID: ENUS17112 This document does not apply directly to your Lexmark Z615
  1. First count the number of times the light on the front of your printer flashes.
  2. Then refer to the table below for information about the error condition and recommended recovery procedures.
    Number of Flashes Error Condition Error Recovery 2 Carrier Stall:
    The movement of the print cartridge carrier has been obstructed. Remove any objects blocking the carrier path.
    4 Print Incomplete:
    The print cartridge carrier stopped in the middle of a print job due to obstruction. Remove any objects blocking the carrier path.
    12 Cartridge Short:
    The printer has detected a short circuit in a cartridge.
    2. Open the front cover.
    3. Turn the printer back on.
    4. Remove the color cartridge.
    5. Close the cover. If there are no flashing lights, the color cartridge is short-circuited.
    6. Remove the black cartridge and then reinsert the color cartridge.
    7. If there is no error indicated by flashing lights, the black cartridge is short-circuited.
    8. If you continue to receive an error indicated by flashing lights, both cartridges are short-circuited.
Apr 22, 2009 | Lexmark Z640 InkJet Printer
Electrical problem
Find the ground wire on one of the lights and add another ground wire to a good clean metal surface and see if that fixes the problem. It defently sounds like a ground problem at one of the lights.
Jan 07, 2009 | 1983 Chevrolet Caprice
Airbag lights
the left light yellow stays on . the right light flashes on then quickly 3 or 4 times .some times they go out for a while and then come back on
Nov 17, 2008 | 1999 Mazda 626
CONTROL PANEL
go to pages 2-11 on in
good luck,
/JDe
Apr 13, 2008 | Lexmark E210 Laser Printer
Lexmark E210 Laser Printer Logo
552 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
