Digital audio port (optical) do not work since updated the bios
I updated with the wrong bips
they provided me the right bios to update my bios to the right one.
thanks a lot.
Posted on Dec 04, 2008
    Champion:
  • 253 Answers
Install all drivers again
from the driver cd...
Posted on Dec 02, 2008
In what port do I use to install an ONN digital optical audio cable? I have a Seiki Model SE322FS
Based on the specs from CNET, the Seiki SE322FS does not have an optical digital audio port. There is a coaxial digital audio port which looks like a standard RCA jack. The main difference is that it will be a single output jack, instead of the groups of RCA input jacks (component and composite audio/video ports). See https://www.cnet.com/products/seiki-se322fs/specs/ . See https://www.lifewire.com/coaxial-vs-optical-digital-cable-3134605 for some of the pros and cons for each type of digital audio cable.
Since the TV will be your audio source, you'll need a coaxial to optical digital audio converter. This is one example: https://www.cablestogo.com/product/40018/coaxial-to-toslink-optical-digital-audio-converter-taa-compliant . Note: usually the cables are not included with the converter. Thus, you'll need to get a coaxial digital audio cable separately. A different converter is needed to go from an optical digital audio output to a coaxial digital audio input.
I hope this helps.
Jul 25, 2018 | Seiki Televison & Video
Conrad johnson converter connection
Hi sherring, have you cheked that your cable isnt damaged? the connecton at either end might be loose.
Dec 31, 2007 | Technics SA-AX530 Receiver
How do I change the audio setting to use a digital optical audio cable on model 42LG30
bout 7,180,000 results (0.54 seconds) Search Results
    Xbox Audio Settings ' Connect And Configure Digital Audio ...
    https://support.xbox.com/en-US/xbox.../configure-audio-settings
    XboxConnect your Xbox 360 E console to your HD TV using the HDMI cable. Connect one end of a cable (not included) to the digital audio output port on the television. Connect the other end to the digital audio input port your stereo or home entertainment system.
    PS3™ ' Audio Output Settings
    manuals.playstation.net > Settings > Sound Settings
    These settings are mainly used when the system is connected to audio ... and theaudio device using a digital optical cable and switch to [Optical Digital] under ...
    Enabling the optical digital input for an audio source - Bose
    worldwide.bose.com/.../en_us/...optical.../page.html
    Bose CorporationWhen you use optical cable to connect digital audio from another device to your system, the optical input needs to have the correct source assigned.
    HDMI vs. optical: Which digital-audio connection to use ...
    www.cnet.com > Home Entertainment
    CNETMar 13, 2014 - Both HDMI and optical pass digital audio from one device to another. Both are better ... The cables are cheap, and having just one wire simplifies setup. If you can't, ..... Try changing the decoding on your ps3. You have the ...
    Selecting Audio Settings for a Non-Contour DVR Cable Box
Jan 19, 2016 | LG Televison & Video
How to plug my external speakers to my viera tv
This television only outputs digital audio called PCM / Dolby Digital, Fiber Optic so you may need an amplifier that has a digital in port (if the speakers are rca red and white cable plugs then the amplifier needs rca output ports). Then you would need to connect the amplifier to the speakers
. Unless the speakers have a digital in port which I am unsure on ,. The digital out audio port on your tv uses a fibre optic digital audio cable..
page 13 of the user manual shows this digital output port.
http://service.us.panasonic.com/OPERMANPDF/TCL42E50.PDF
Oct 28, 2014 | Panasonic Smart Viera E50 Series Tc-l47e50...
Whats maximum RAM in HP6620f PC?
Technical Details
  • AMD Phenom II 820 Quad-Core Processor (2.8 GHz, 2MB L2 + 4MB Shared L3 Cache, 4000MHz System Bus); 6GB PC3-10600 DDR3 SDRAM memory (3x2GB) (expandable to 8GB); 1TB (7200 RPM) Serial ATA hard drive; Genuine Windows 7 Home Premium 64-bit
  • ATI Radeon HD 4200 integrated graphics; SuperMulti DVD Burner with LightScribe Technology; High Definition Audio with up to 7.1 surround sound capabilities
  • External Ports: Headphone & Microphone (Front), 2 USB 2.0 ports (Front), 4 USB 2.0 ports (Back), VGA-out & DVI-D, Microphone/Line-in/Line-out; Rear speaker-out; Side speaker out; Subwoofer (Back), Coaxial Digital Audio Out (SP-DIF)
  • 10/100Base-T network interface, Wireless LAN 802.11b/g/n
  • HP USB keyboard and optical mouse, Front panel 15-in-1 memory card reader
Feb 29, 2012 | Computers & Internet
Ok so the issue is that after i have ran a hdmi cable from reciever to monitor, and 2 hdmi inputs (dvd and video2) into the reciever where im running a ps3 into the video2 port and foxtel/satellite tuner...
Try this, although recivers have video pass through, it is not the best option for video to your monitor. Depending on what you have for input/output on your TV/monitor, and, if you can, you should run all your video components directly to TV via(best)HDMI(video and sound) or, component and digital optical(best) or RCA, Then run digital optical out from you TV out to receiver in. You can use your monitors menu to chosse what you view and only have the onr input to you reciever. ASll you have to do then is go through you recievers menu to get the audio. Less connections less hassle. In other words, you would run your sat tuner to tv inputsat or cable, then dvd to dvd, PS3 to video 1 etc., on TV/monitor, then the single audio output to reciever.
Dave
Jul 03, 2011 | Audio Players & Recorders
I got a new SATA 500gb HDD but the motherboard wont detect it.
Access to your Bios Setup & configure the Bios settings.
Features Setup Page : This page sets up some parameters for peripheral devices connected to the system.
CMOS SETUP UTILITY - Copyright (C) 1985-2003, American Megatrends, Inc.
Features Setup
OnBoard Floppy Controller : Enabled
Serial Port1 Address 3F8/IRQ4 : Enabled
OnBoard IR Port : Disabled
Parallel Port Address : 378
Parrllel Port Mode : ECP
ECP Mode DMA Chnnel : DMA3
Parallel Port IRQ : IRQ7
OnBoard PCI IDE Controller : Both
OnBoard SATA-IDE
: Enabled *(Make sure This is enabled)
Audio Device : Enabled
Modem Device : Auto
Ethernet Device : Enabled
If you have got a SATA III HDD, ie if it is a Western Digital Sata III you need to configure the jumpers to work with your older Sata interface port.(Only Sata 1 & 2 ports on your Mainboard Socket 478). As for Seagate Sata III HDD, the configuration is automatic.
If your 500GD HDD is not detected, try updating the BIOS!
A word of caution "Updating the Bios is not for the Novice" Do it at your own risk. Failure in updating the Bios may render your Mainboard useless.
Hope it helps.
May 14, 2011 | PC Chips M955G Motherboard
Digital Optical port to 8-pin din
Optical digital cables can't be magically wired to copper inputs. NO digital signal can be magically connected to an analog interface and work.
Even if you could do what you propose, how would you control volume?
Why don't you just connect the BluRay to the JVC system and let IT handle the audio to the sub and satellites?
Run an optical cable to the JVC TH-C60's Optical In port. Make sure there are no tight bends in the optical cable as that will degrade its ability to transmit a signal.
Jan 30, 2010 | Audio Players & Recorders
Airport extreme
Try this in this order:
  1. Verify your aux on the DE675 is working with another analog audio source.
  2. Unplug the G5 -> optical -> DE675 and try playing itunes through the Extreme only into the DE675's aux.
  3. Optical digital audio output on the Mac is VERY fussy, so I'd stay off of the optical unless it's absolutely necessary.
  4. If you're finding that the Extreme is not putting out any sound at all, try this: Reset and update the firmware on the Extreme. Also, make sure your Mac is very updated with the latest iTunes, operating system updates, etc.
Mar 19, 2009 | Sony Audio Players & Recorders
Optical sound
I think what I might do is use an optical splitter: http://www.amazon.com/Digital-Bi-Directional-Optical-Toslink-Splitter/dp/B0002MQGR2, does anyone have any experience with this?
Dec 05, 2007 | Onkyo TX-SR501 Receiver
Computers & Internet Logo
Alun Cox
David Payne
David Payne
