Question about Air Tools & Compressors
Bostitch T31 air leak thru small head hole
I had this rebuilt by a shop, then put a kit in it myself after it fired one brad and re-leaked. I only opened the head portion, not the handle section.
The leak is through the small hole in the head and only occurs when the trigger is not pulled, plus the gun does not fire. The plastic trigger does not appear bent and the gun has only seen light home use.
The new small O-ring seems to bind, unlike the old one and none of the old rings or seals seemed to be worn or leaking.
    President:
  • 1,388 Answers
I have repaired hundreds of nailers, however not a t31. I can offer you a few tips on general nail gun repair pertaining to leaks. It is important to check each oring separately if you can to check for proper fit/contact. Do not just replace all orings and then hope for the best. Each oring must fit snugly not too tight not too loose. The surface where the oring contacts must not have fine scratches. Inspect all surfaces with magnify lens for scratches and remove with fine sandpaper. Check each oring for nicks Make sure that gaskets do not block small ports that direct air to headalve. Use silicone grease instead of oil on orings and metal/plastic parts. Lowes sells a small container of silicone grease in the plumbing department. It is used to lube faucet parts. Oil will wash away too fast and sometimes it will swell the orings causing gun to jamb. Finally do not use too much pressure on small nailguns. Try using 70 to 90 lbs. Good luck
Posted on Dec 02, 2008
I have already changed trigger valve assembly, O rings and all. Still leaks when I try to fire. Will not shoot brads just leaks lots of air around trigger assembly.
Most likely problem is the head valve orings not making perfect seal. Remove the head and pull out the headvalve piston. Apply plenty of white grease to orings and test fire. If gun fires, will need oring kit soon. Good luck
Aug 14, 2015 | Stanley Bostitch SB1850BN 18Gauge Brad...
Air leaking from trigger Bostitch SB1850BN
Most likely the orings or seals in the headvalve are not making perfect seal. Remove the head and pull out the headvalve. Apply plenty of white grease to orings and test again. If the gun fires, then will need oring kit soon, or just keep using plenty of grease. If the gun still does not fire, check that the safety foot is depressing the trigger valve all the way in. Good luck
Aug 13, 2015 | Stanley Bostitch SB1850BN 18Gauge Brad...
Nailer is shooting air out of trigger, is not releasing brad
Sounds like the head valve. Remove the head cap take out the head valve, clean, re-fit and give it a few drops of air line oil. Then give it a try. Good luck.
Oct 19, 2014 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Air leaks through cap vent
I had the exact same problem after doing a complete rebuild. If you are using the Stanley bostitch rebuild kit, check to see if you accidently swapped o-rings 6 and 63. They look the same but o-ring #6 is 1.925x.103 and o-ring #63 is 1.862x.103. Use plenty of lubricant. Hope this helps.
Apr 07, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
I put a new o ring rebuild kit in my Bostitch N80 sb framing nailer. I replaced every o-ring (including the trigger valve assembly
If the new trigger valve leaks air when you connect the air supply, most likely defective valve or air is leaking past outer trigger valve orings due to debris in the slot or new orings were cut when the valve was pushed in. If air leaks when you depress safety to fire gun then most likely problem is in the head valve or safety foot is not pushing the firing pin all the way in. Easy test, remove nails and remove the trigger to expose the firing pin. Connect air and very quickly depress the firing pin all the way in. If the gun fires, adjust the safety foot as needed. If the gun does not fire, remove the head and check headvalve orings for good snug fit against the cylinder within the head. The surface were orings make contact must be very smooth and not too deeply worn. If you notice fine scratches remove with fine sandpaper. Reinstall head using plenty of white grease on all the orings within the head and retest. Good luck
Feb 10, 2013 | Stanley Bostitch N80CB Coil Framing Nailer
Parts for Bostitch N80
Easy test, Remove the nails and remove the trigger retainer pin and trigger to expose the trigger valve (tva6 valve). With air connected and nails removed, quickly depress the trigger firing pin all the way in. Gun should fire (if gun fires, adjust safety foot to make better contact with tva6), if no joy air is leaking past orings in the head valve or head gasket vent hole and/or trigger valve. Remove head and check gasket around vent hold (small hole in the head gasket). If the gasket good remove head valve and examine surface where orings make contact for fine scratches. If scratched or worn, orings are not sealing. To check if orings are leaking, apply lots of white grease to orings in the head valve, replace the head and test fire. If the gun fires, sand contact areas with fine sandpaper and or use oversize orings or wind teflon tape under the external orings. The metal ring or washer that you are wondering about is sometimes used to space up the bumper to control depth of nail. Other nailers use a metal fitting under the bumper to help guide the driver and to seal the lower chamber helping to prevent too much air leaking past the driver. If too much air leaks past the driver, guide, the piston may not return to top. Good luck
Nov 17, 2012 | Air Tools & Compressors
I have a pancake compressor that won't hold air pressure, leaks out of the small hole in the head. I have replaced the head gasket and air pressure valuve and still leaks out of the hole in the top head.
If you replaced the head gasket then its probably the valve plate and gasket.
See here:
http://www.chasdayco.com/mm5/breaks/PorterCable/20041110144417_A08610-E.pdf
Jan 08, 2011 | Porter Cable Cable Brad Nailer and...
I have a Bostitch BT200 that is dry firing. It seems that the "hammer" is not retracting after it fires a nail. I have to push it back manually and even then it seems to dry fire a few times before a nail...
The check seal is what causes the piston to retract. Remove cylinder and examine check seal. It is a small band that covers a series of holes and should fit snuggly around cylinder. Other factors that have effect on piston retraction are, split/cracked cylinder, bent driver and lack of lubrication. This gun is tricky to rebuild. Make shure that all the parts in the head are placed correctly. The kit does contain all the parts that you need. Good luck
Sep 07, 2010 | Stanley Bostitch Bt200 Brad Nailer Rebuild...
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
Air Tools & Compressors Logo
1,460 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
