Question about DeLonghi RT400 Retro 4-Slice Toaster
Toaster Loading handle wont staY down
Toast keeps popping up immediately after pushing the loading handle down. I opened up the toaster and both sides of the loading mechanism appears to look the same. they look well lubricated, no crumbs stuck on the mechanism. what else can I look for to solve this problem? Thanks
  • casa91 Jan 11, 2009
    Same problem here. It seem that there is a magnetic mechanism that is not operating properly. The magnet makes contact with the metal plate on the handle, but it does not catch. Obviously an electro magnet so there is no power getting to it. No wires appear to be loose so that is where I am stumped.
  • 944 Answers
I have researched this toaster quite extensively, without any success as to actual solutions. Usually these machines have either a solenoid activated lever that holds the toast down, although magnetic systems are not uncommon. These may be avtivated by a thermostat, an optical "brownness" meter or a timer. Usually the cost of replacing this would be as much as a new toaster due to labour costs, however it may possibly be fixable - could you add a photo of the internal workings - this might help. Unfortunately many other purchasers appear to have similar problems and claim to have had little success with either dealer or manufacturer. The number of toasters of this model offered for sale second-hand as new at ridiculously low prices makes me suspect that there is a fundamental problem with the model. Use any warranty you have, but unless you wish to write a lot of letters/mails then i suspect a new toaster might be your best bet. Availability of spares for this toaster is another issue - I have been unable to find anyone who claims to supply these, although individual components are almost certainly from different manufacturers and could be sourced. If you can arrange a photo of the toaster when open (reasonably close up and general view) then I may be able to help more. Apologies for no actual "Solution" yet.
Posted on Feb 17, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Feb 17, 2007
    P.S.
    Something possibly worth trying is plugging it into a different power socket - just on the off chance that the supply voltage on that particular socket or circuit is lower than necessary to activate the solenoid - try one on a different floor if possible. This is a long shot but for the sake of two minutes probably worth it.
Fix sunbeam 3806 toaster that won't stay down and therefore heat bread.
Just a guess since I have had the same happen to my Proctor Sillex - When you push down the lever, you are actually completing the transformer frame that then magnetically keeps the toast down until it's setting lets the toaster pop up.
In my case, a piece of toast was wedged and I could not get the handle down so that the hardware was in place to magnetically hold. Have you tried to give your toaster a good thorough shaking upside down, unplugged over the garbage can or the sink?
Good luck Eric
Oct 04, 2017 | Sunbeam Kitchen Appliances - Others
The lever won't stay depressed
mcdevito75 here, The lever mechanism could be worn OR the setting for darker / Lighter toast is set to Light, swtch to darker see if that helps.
Jun 22, 2010 | Breville CT40 Retro Classic 4-Slice...
Toast won't stay down when handle pushed down handle comes up immediately as if not plugged in. Plug definitely in. Used only 3 times.
take it back. sounds like the magnetic coil that holds the handle down when it is plugged in is not functioning.
Oct 04, 2009 | West Bend 6220 Slide Thru 2-Slice Toaster
Toaster does not stay held down to toast wct 708
there is a "contact switch" that when there is power in the system, it stays down. If hte contact switch is bad, it releases and will not stay down. COntact switch needs to be replaced, unfortuantely I have the same problem and can't seem to get the part.
Jun 12, 2009 | Waring WCT708 4-Slice Toaster
KitchenAide Toaster
Kitchenaid does not recommend repair on the toasters, as it is not cost effective for the consumer or company to engage in repair.
I would recommend calling Kitchenaid Customer Service. If the unit is within the 1 Year Warranty, they may replace it at no cost. If the unit is outside of warranty, they may provide discounts on the purchase of a new toaster.
Their toll-free telephone number is 1-800-541-6390.
Apr 10, 2009 | KitchenAid KTT261 Ultra Power Plus 2-Slice...
Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Mar 30, 2009 | Sunbeam 3831 2-Slice Toaster
Retro Westinghouse toaster works but toast will not pop out
YES .westinghouse used a clock timer to time all of there toasters in the 40s and 50s . remove the push down knob (there is a set screw under it) and the 4 screws under the toaster . the top will come off inside next to the push down lever there is a little clock timer . a drop of oil on the moveing parts of the timer will get it ticking again .....test your work by pushing down the lever stem (with it unpluged ) it should pop up when it times out . puting back on the top can be a pain but it does go back but at some point you may wonder ! with all toasters put down a towel before working on one to keep from scraching the mirror finish ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
Feb 21, 2009 | Kitchen Appliances - Others
Toaster lever wont stay down
Open the toaster up and look inside by the levers, there should be a little piece that will keep the lever down, if this is missing, then you may need to replace the toaster, if not, then the little piece may be stuck, you can use the following to try and loosen it up,
1. WD-40
Oct 11, 2007 | Waring WCT708 4-Slice Toaster
My toaster doesn't stay in the down (toast) position unless I hold it down
I solved this problem on my Cuisinart CPT-90 Classic Style Toaster twice for two different problems. Of course: make sure it's UNPLUGGED while working on it and WATCH IT several times when testing so you can unplug it first and then extinguish it if it catches on fire.
1st time: There is a small solenoid mounted in the center of the circuit board. When the pop up mechanism is pressed down the circuit energizes and the the solenoid magnetically locks a plastic clip that holds the spring loaded pop up mechanism down until it's done toasting. The plastic mounts for the circuit board broke or weakened until the whole circuit board would tilt up and the solenoid clip would slip under the spring tension. I used a plastic tie-wrap to hold the circuit board firmly in place and that worked to this day.
2nd time : The four copper reed tabs can be miss aligned. If they
do not make contact, the circuit will not energize the solenoid.
The reason they warped was that, over time, the contacts build up carbon and have more resistance. Resistance equals heat. The
plastic base of the copper reed switch melted and misaligned the reeds. The second time I cleaned the reeds and bent them back into position, The third time the the plastic was to badly burned to be reliable. If I had cleaned the contacts once a year, it probably would still work now. I haven't found a place to buy a replacement reed switch so my toaster is toast. If anyone knows where to order them, I'd like to know. If the white plastic base of the reed switch is not melted, then they can be cleaned and aligned.
Note: When aligning the copper contacts, don't just hold down the pop up mechanism. The pop up mechanism will push lower than the position for toasting. Push it down and then hold the solenoid clip instead. Then the two center reeds will be at the correct spread.
Aug 14, 2006 | Cuisinart CPT-90 Classic Style 4-Slice...
DeLonghi RT400 Retro 4-Slice Toaster Logo
1,017 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Bade
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
