Question about Whirlpool WGD9200S Gas Dryer
Igniter on my gas dryer glows but does not ignite
I have a Kenmore stack laundry center (model 417-99395100).
  • 172 Answers
If the ignitor is infact getting hot enough the next step is for the coils to open the valve to release the gas. Most of the time the ignitor is not drawing the proper amperage to open the coils. One or more of the following parts would be bad.
ignitor # 5303937186 $50.00 shipped to you.
coil # 5303931775 $40.00 shipped to you
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
Kenmore series 500 gas dryer not heating up. model # 77542600 Other than the ignitor what could be the problem?
Check the coils on gas valve. If igniter glows bright & no CLICK sound heard after a few seconds of igniter glowing, coils are bad, or flame sensor if so equiped
Feb 13, 2011 | Kenmore 500 6952 Dryer
The gas dryer does not get warm?
to have it get warm there are 3 things have to be working together:
1- Ignition needs to be on to start the burning.
2- Gas valve needs to be opened after ignition is on.
3- Gas continues jetting in until a thermal switch turns the valve off.
You can open the rear panel to observe if the ignition is glowing or not. If it is not then that the culprit. If it is on then glows off after a while since the gas valve is not open, then you can just replace the thermo sensor if it is separate from the gas controller. Some controller has it integrated then you have to replace that. Good luck.
Apr 21, 2010 | Kenmore 98702 Stacked Washer/Dryer
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
Kenmore 80 series Gas Dryer
HI. you are correct. this dryer, although gas, is using a Glow igniter system. most older models used the snap igniter that clicks over and over to spark the burner but, this dryer is only 2 years old so, it should be outfitted with a glow igniter system. This igniter is powered by electricity.
It works in conjunction with a Flame sensor.
Jun 02, 2009 | Kenmore Dryers
Gas ignites but goes out after 15 or 20 seconds
Hello gdurawa
Welcome to Fixya
My name is Huum,
You said, upon starting my Kenmore gas dryer the igniter glows and the gas ignites, but the gas goes out after 15 or 20 seconds - clothes don't dry.
This means either the igniter is bad and not getting hot enough to make the gas continue to release completely and stay open, so it shut off.
or you have a bad gas module.
Or a bad gas valve without enough pressure.
Needs to be diagnosed hands on at your location .
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Jan 22, 2009 | Kenmore 63942 Dryer
Kenmore Dryer only lights gas sporaticly
replace the igniter. The ignitor is the most comon problem with gas appliances checking continuity does not tell you if it is bad or not it has to draw a certain amount of amps to open the gas safty valve and the is no safe way to check this on most gas dryers
Jan 19, 2009 | Kenmore Dryers
No heat to dryer
it mean it dont have a gas pilot and it has a ignitor instead ,,,, if you turn on the dryer and dont see a glow then it may have a bad ignitor ,,, on a kenmore it should not have a door to open unless it is a old unit and the newer ones has a peep hole to see into.
Dec 04, 2008 | Kenmore 72602 Gas Dryer
Kenmore gas dryer model # 87566100
BAD SOLENIODS OR THERMAL SAFETY
Jan 29, 2008 | Kenmore 73952 Gas Dryer
Dryer spins but does not heat
It sounds like to have a bad igniter. In order for your dryer's gas valve to open,the igniter has to be functioning properly. This is a built in safety feature to prevent gas from flowing without ignition. The igniter is located inside the machine usually under the drum near the gas valve. If you can access the inside look for a glow after you push the start button. If there's no glow, your igniter is bad. I hope this helps.
Mar 30, 2007 | Frigidaire FullFGX831C Size Stack Gas...
Whirlpool WGD9200S Gas Dryer Logo
320 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
