Question about Select Brands Elkay LKH190BK The Hot Water Machine Black
Leaking water The elkay hot water machine leaks when filling a cup for hot water. It seems to be coming from the bottom of the machine Does it need to be replaced and who carries the product in the 95819 area code?
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
It probably does need to be replaced IF it is leaking from the bottom. It MAY, however, be leaking at the top and just dripping down to the bottom. If it only leaks when you're filling the cup, then it probably is a top leak. These are generally easily fixed by getting a new slip-on connecter to connect the copper tube connecting the faucet to the nipple on the top of the tank. to remove the connector, push the rings on the ends of the connector (where the tube enter it) towards the other end. Buy the replacement at Home Depot or Lowes before starting to see how it works.
Posted on Apr 11, 2009
Bosch WFVC6450UC Washer leaks at bottom
How about loose fill hose connections?
How about incomplete shutoff of the internal fill control valve between wash cycles?
Sep 22, 2012 | Bosch WFVC6450UC Front Load Stacked Washer...
Keurig b40
We need to determine where the leak is...
Unplug it...
Start by removing the water resevoir...dry out what you can with paper towel...
flip it over on a table with a bath towel. Take off the metal bottom plate
you can then check for water inside the unit.
since you didnt say where the water is coming from... the K-Cup arm or the bottom...
I will assume the bottom is where the water is coming from.
Hoses on these units are fastened with 4 inch "Ty-Wrap" nylon fasteners.
You may have a broken one, and need to replace one... hopefully it is located on the bottom between the water fill and the main water motor... which you shouold be able to see when the bottom metal pan is removed...
If the water is coming out from the top. then I suspect hot water expansion is bypassing one of the valves, or there is a nylon strap/hose combination you cannot see instde the unit...
Hopefully it';s the bottom
May 17, 2010 | Keurig Elite B40 Coffee Maker
Leaking black and decker under counter coffee pot
the 90 degree red elbow has worn away of hot water temps and will leak some but all hot water to the bottom of machine. needs to be replaced or retrofit one
Jan 03, 2010 | Black & Decker SpaceMaker ODC440B 12-Cup...
Water leak
it sounds like the bleach fill line. at the top of the washer is a bleach fill cup, it might attach to it. this black bleach fill line attaches to the bleach fill cup to the bottom of the tub.
Jun 15, 2008 | GE WHRE5260E Top Load Washer
Leak in washing machine
can you tell where the water is hitting the belt from is it in the middle of the wash tub or from the outside of the wash tub please let me know if its from the middle of the tub its probably the seal that keeps the agitator from leaking, and if its from the side the in lines from the water spicket or the valve that controls hot and cold in the machine could be leaking, please look closely and try to see where the wateris dripping down from. thank you, then let me know
Dec 21, 2007 | Washing Machines
I am getting an error message that says VENTILATE
Try draining the machine. Page 37 of the user manual, Drainage. Place cup under the steam/hot water tube, turn knob clockwise around to 9. If the pump is ok, it will start automatically and start filling the cup. Drain about 1/2 cup of hot water and return knob counterclockwise to start position. If the flow meter is not damaged, the Ventilate message should be gone.
Nov 07, 2007 | Saeco Royal Exclusive 30153 Espresso...
Coffee Makers & Espresso Machines Logo
567 people viewed this question
Top Select Brands Coffee Makers & Espresso Machines Experts
Are you a Select Brands Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
