Question about GE (PSS26MSRSS) Side by Side Refrigerator
DRAIN PIPE IS THE DRAIN PIPE LOCATED INSIDE THE BOTTOM COMPARTMENT OF THE FREZZER IN THE SIDE BY SIDE GE PROFILE REFERIGERATOR.
    Scholar:
  • 81 Answers
Usually no you can look on the companies website for more detailed specs is there a specific reason for asking?
Posted on Dec 01, 2008
I keep seeing a puddle of water at the bottom of my GE Profile refrigerator. I traced the water line, and it is not coming out of that. I cannot locate any drain pan. However, I can see a 14 x 16 sheet...
the drain is stopped it is just under the evaporator a hole in the center pull out draw you will see it. blow it out .may have to chip some ice away or use hair dryer to melt
Oct 03, 2010 | Hotpoint HSS25GFT 25.0 Cu. Ft....
Ge profile leaking water from bottom of appliance
if you have ice on freezer floor, then you likely have a clogged defrost drain. the meltwater from the evaporator can no longer reach the condensate pan under the unit. Unfortunately, the only way I know how to unclog it, after removing all the ice, is to blow compressed air from the freezer into the drian, to force out the debris.
if you have no ice on freezer floor, then from my experience, the problem is due to a dried, brittle and cracked water line for the water dispenser. Pull the fridge out from the wall carefully, you will see a machine compartment cover at the bottom. If this cover is only half as wide as the unit itself, then due to the proximity of the water valve to the compressor, the water line is very well known to crack. You will have to replace the 5/16" water line from the valve solenoid to the water tank located inside the refrigerated compartment.
If neither of these scenarios cover your problem, i would advise seeking a competent repairman. If you are in chicagoland, I can help, otherwise no.
Mar 01, 2010 | GE Profile PSI23NCR Side by Side...
My side by side for some reason has water coming out from under it..i check the water feed line and its good!I then checked the drain plug in the frezzer and noticed the whole bottom of the frezzer had...
What is a "drain plug"??? Never seen one on a fridge ;)
Clean the drain pan and drain line in the back of the freezer section underneath the evaporator coil. Make sure water drains when you pour it in.
Good luck! :)
Vlad
First Choice Appliance
Dec 21, 2009 | GE GSS20IEP Side by Side Refrigerator
WHERE IS THE DRAIN PAN LOCATED???
The bottom of the refrigerator and near compressor is where the condensate drains to. The condensate begins in freezer during defrost and collects in a collection tray behind rear wall of freezer and with a drain hole and pipe that feeds through the cabinet and down to drain pan where it is warmed by the compressor heat and returned to the air inside your home. The only way to really get a good look at pan is to pull the refrigerator away from wall and remove cover over the compressor are. I recommend unplugging first before placing hands inside.Thanks, Sea Breeze
Dec 14, 2009 | GE Profile¿ Arctica® Energy...
We have a GE profile that we bought in 2007. We
Hi Sandy, I can assist you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
Jun 19, 2009 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Bosch Frost Free Frdge Freezer Icing Up
Switch off fridge. Put a pedistal fan in front blowing into the cabinet and leave until all ice has defrosted. Locate the drain hole in the back of the freezer compartment, try to defrost ice which blockes up about the first inch or two of this pipe. If water does not run through you need to force it through with a turkey baster. This should sort your problem. ratemeplease
Mar 12, 2009 | Freezers
TOO MUCH ICE
just switch off and melt the ice away with a hairdryer.
drain is behind the back panel inside the freezer
Dec 02, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Where is the drain pipe located in the side by side profile ge
in the back at bottom in freezer there is a drain hole which may not be seen due to ice but remove the ice and clear with hair dryer or hot water / larry
Dec 01, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
GE (PSS26MSRSS) Side by Side Refrigerator Logo
62 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
