Your pump is more than likely shot!
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Defective Water Pump
If the motor is running
and water is not pumping it could be a defective water pump. Ensure the
tub to pump water hose is clear. If so, replace the pump.
Defective Motor
If
the motor is not running, the pump will not work. Most washing machine
use a reversible motor and it is possible for the machine to agitate
and not spin or drain.
Please leave a goo rating
the last spin cycle won't spin or drain
My washer is not yet 3 years old.
It spins but doesn't drain fully. I have to run two extra drain/spin cycles to get enough water out before loading into dryer.
VERY DISAPPOINTED IN THIS MACHINE!
