Question about Zebra 105SL Thermal Label Printer
Ribbon out error
Probelm is self descriptive. How to fix it? Thank you
Alvaro
  • MisterQED Dec 08, 2008
    Again needs no details. Printer worked fine, now keeps saying the ribbon is out evn though it isn't.
  • Anonymous Dec 10, 2008
    No, it won't even make it thru the calibration, it errors in the middle. Previous passes it did make it thru then it will work for a label and then error again. I think the sensor is malfunctioning.
  • 17 Answers
Go through the Media Calibration Steps in the user manual here:
http://www.ausense.com/pdf/105SLusersguide.pdf
This fixed it when I had the same error.
Posted on Dec 10, 2008
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Aug 27, 2015 | Ovens
I got a F9-4 code for self cleaning
Hi szambarano,
The F9:-4 error code description is Latch Unlock Lower. Check for obstruction in door lock mechanism.
Hope it helps.
Thank you for using FixYa.
(Positive feedback will be greatly appreciated.)
Apr 14, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Oven seems to have some sort of electrical problem
I just solved a similar probelm with my Kenmore oven, gave error code f7, among others. The control panel is manufactured by General Electric. Turned out that the control panel has a electrical ribbon that goes to the relay panel. The ribbon is actually two ribbons pressed together. They should easily pull apart. They are not insulated properly, and the ribbon leads short together or cross. Just put a piece of paper between them to act a an insulator. Good luck!
Nov 08, 2009 | Ovens
Kenmore wall oven (model 911.41065690). Works fine for days then give error code of F7. I can reset with breaker but it will return.
The F7 error code on your oven indicates the touch pad has failed. To repair it you will need to replace the touch pad which is listed as a control panel w/keypad in the parts diagram.
If you do the repair yourself, disconnect the power to the oven. Take the 3 screws out above the door that hold the control panel on to the oven. Pull the control panel out at the bottom and lift it up, then pull out the top and drop it down so you can see the back side of the control panel, and you will see a ribbon connector going from the touchpad to the electronic oven control (ERC).
There is a latch holding the ribbon connector to the ERC, raise the latch to release and pull the ribbon out of the ERC.
Replace the part and reverse these instructions to replace the control panel.
good luck
Sep 30, 2009 | Kenmore Ovens
My Kennmore double oven is beeping with an F7 code
There is a probelm with the control panel. You can fix it for about a penny. The panel has a printed ribbon cable that plugs into the relay board. The ribbon cable is actually two cables pressed together, which can be seperated by simply lifting them apart. The ribbon cable has a defect in that the plasic insulation is defective, causing the leads between the two ribbons to cross, or short circuit. Simply place a thin sheet of paper between them, and make sure you push the paper down all of the way to the plastic housing, fold over the edges around the cable, you are done.
Jul 28, 2009 | Kenmore Ovens
Error code f7 on Kenmore wall oven 911.41165791
May 27, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Error Code F-9
You can fix this problem by just cleaning the ribbon cable.Never use the self clean.
May 27, 2009 | Maytag MER5770 Electric Kitchen Range
Laptop probelm
I'm also facing the same problem... But I've fixed display...
How did u fixed the sound card?
Jul 07, 2008 | Fujitsu AMILO D-8830 Notebook
Kenmore oven
May 24, 2008 | Kenmore 41389 Electric Double Oven
Kenmore electric built-in oven control panel beeping
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Zebra 105SL Thermal Label Printer Logo
645 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
