Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Hello, I have a Fisher Paykel Double dishwasher (DD-603) - about five years old and then top unit is literally going nuts. It turns itself off and on, beeps constantly, and will not run through a cycle. What is causing this issue and how can I go about fixing this problem?. What parts do I need to buy? How do I remove the front panel of the dishdrawer to fix this problem? Do it yourself repair instructions would be terrific.
  • 76 Answers
It sounds like it needs a new computer board (the whole thing) so you cant do it yourself it needs to be orded in.
If you have any questions please dont hesitate to ask
Posted on Dec 02, 2008
My top drawer of the fp dd 603 is stuck! what do i do?
Ours just did that. Turn the power off at powerpoint, leave off for a minute, turn back on, turn machine off on the drawer. Turn the powerpoint off for another minute, turn back on, then turn on at drawer. The drawer should now open. Its a problem with the top seal of the unit, the unit needs to be fully reset for it to be fixed.
Jan 09, 2011 | Fisher and Paykel 23 in. DD-603 Built-in...
Flood switch activated, intermittent beeping, motor will not turn off
Please confirm if it is a single or a double drawer.
How do you know the flood switch is activated? Do you have a display on your dishwasher and what is it showing? If no display then which lights if any on the panel are on?
Motor will not run if flood switch is activated in the fisher paykel drawer dishwwasher.
Nov 20, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher Paykel double drawer built in top drawer stops mid cycle.
It would help to know which LEDS are on when it stops. Are you able to open the lid etc. Does this happen with the short rinse cycle as well?
Oct 17, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel DD603 top drawer jammed and will not opem/close properly without brute force!! Please help!
Hey, I had this problem before!!!! Just unplug the unit off and wait about 10sec and plug it back on.....that usually does the trick.
Oct 25, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Sep 10, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher & paykel double dish drwer
The code is a water leak problem.That is the warning
May 15, 2008 | Fisher and Paykel 23 in. DD603H SS...
Fisher paykel DD 603 SS double dish drawers
Post your email i will send you the manual on the breakdown of the unit
Jan 26, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
308 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
