Question about Kenmore Elite 45986 Front Load Washer
F35 Message on Brand New Washer
Help - we just had our Kenmore Elite HE5t Steam Washer delivered.  Did the express wash - which went fine.  Then went to do a load of whites and within 2 minutes go a Suds message blinking - after another 3 minutes it turns to a F35 message.  I am using the correct detergent, have stopped the machine and tried a "drain and rinse" cycle, and have tried re-setting it by unplugging the washer for an hour - I don't understand - this is brand new!
  • tcunningham Dec 03, 2008
    Thank you - a repair person came out - it was some pressure switch that was defective with the washer.  It needs to be replaced.
  • Swenlin Dec 05, 2008
    Just got back from an 8 day holiday - we have a ton of laundry.  Our Kenmore washer is less than a year old.  Trying to do our first load and we get the F35.  Tried again and we get the SUDS error... then it eventually switches back to the F35.  What annoys me most about this is that only a handful of "F" errors are explained in the Sears manual - F35 isn't one of them.  It is obviously a specific error that means a specific thing - why not actually DEFINE it so the owners know too.  :o/
  • 240 Answers
Suds is determined using the level sw located on top right rear side. remove top cover to see. most letter codes do convert to a f code. most common reason for suds error is use of standard detergent or too much detergent. running a empty load of fabric softener can clean the system. or rinse/spin with nothing. other common problem is this is a whirlpool product.
Posted on Dec 03, 2008
I have a Kenmore He5t steam washer. I got the F35 code again, so I automatically ordered and replace the pressure switch again. did not fix the problem. I have checked and cleaned the drain basket and
Unfortunately you spent money unnecessarily, and before making any additional errors; it would be best to have a trained technician with knowledge of the washer, service the system.
Jan 18, 2015 | Kenmore Washing Machines
I have Kenmore ELite HE5t Model 110. I keep getting an "F35" code and washer does nothing....even pushing the "Stop" button doesn't work..door will not unlock...I have to turn off breaker to open door.
Hi, we also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Oct 05, 2010 | Kenmore Elite HE5t Washer
My Kenmore Elite he5t steam washer gets F35 error code
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 21, 2010 | Kenmore Elite 45986 Front Load Washer
Sud and f35 error in my kenmore elite h5 steam washer. The washer do not wash the cloth and flash F35.
I got the f35 and suds code repeatedly and my clothes weren't washed, I ordered from Sears the analog pressure switch that regulates the water coming into the washer and the codes went away, the part is esitmately $125.00 including shipping but you have to order from the Sears parts department.If you print a diagram of the washer it is #38 in the diagram and is easy to replace. You can install it yourself and as a female I did not call service to do it.
Jan 17, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he5t steam is locked & display says f35. What does that mean?
Sep 06, 2009 | Kenmore Elite HE5t Washer
F35 and Suds error on Kenmore Elite HE5t
I also got the SUDS error followed by F35 many times. I replaced the analog water level switch, Wirlpool part number W10156252, and the problem went away. The part is located against the back right corner of the top of the washer after removing the top cover. The part cost $62.99 + $12.95 express shipping from ApplianceZone.net. I have the Kenmore HE3t Steam Washer, model number 110.46752 700 front loader. I was able to run about 6 loads of laundry by unplugging the washer, waiting about 5 minutes, the re-plugging and re-starting the washer. Thereafter, the problem became permanent. I always used HE detergent. The washer was purchased new in December 2007, and the I made the repair in September 2009. I spent about $1300 for the Kenmore H3t Steam Washer, and I am disappointed that it required repair after less than 2 years. My mothers old Maytag washer lasted more than 15 years, and was not susceptible to soap SUDS.
Jul 20, 2009 | Kenmore Elite 45986 Front Load Washer
F35 code appears, even after changing the steam chamber.
IT IS THE ANALOG PRESSURE SENSOR NOT THE STEAM CHAMBER.
May 27, 2009 | Kenmore Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
550 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
