Question about Carrier 38CKC060 Air Conditioner
Heater will not come on - confirmed the control panel needs
Replacing -- what is the cost of it, could I replace it myself -- seems like reconnecting the wires to the old one -- quote is $ 800.00 for replacement ??
  • jimguidos Dec 01, 2008
    it is a 5 ton unit but the control unit is in the attic - it connect to the attic unit and the power baffel units in the vents.
  • 61 Answers
That is a 5 ton unit I believe and you have to be licensed to work with freon.
Post me back if I could be of more help.
Posted on Dec 01, 2008
  • Joseph Lillie
    Joseph Lillie Dec 01, 2008
    Not to bad of a bid to change it. Remember the contractor has to warranty the work. I am not sure what you are asking. Please post back and let me know
Problem with my '97 Chev Astro Cargo van. I need to reconnect the two vacuum lines running from the heater into the engine compartment. I found the larger one disconnected and in poor shape. When I...
One line supplies vacuum from the intake manifold to the control panel. The other line runs back from the control panel to the heater water control valve, which is along the heater hose. The vacuum port on the valve is at the top of the cylindrical actuator.
Sep 24, 2017 | 1997 Chevrolet Astro
I've been told I need to replace the control head to fix my AC problems. What's involved? Can I do it myself or do I need to get a mechanic?
Hi, in most cars it's much easier than in yours. I have pasted the procedure below from Please let me know if you have questions. Also, I would be happy to confirm for you that you need a new panel if you can tell me the symptoms you are having.
Removal & Installation
  1. Disconnect battery negative cable from remote negative terminal on shock tower and properly isolate to prevent accidental reconnection.
  2. Remove or disconnect the following:
    NOTE When the control panel assembly is out, it will have to be disconnected from the wire harness and control cables.
    Center panel assembly Front driver's side under cover Front passenger's side under cover Radio/tape/CD player Floor console Instrument panel center reinforcement Foot duct (LH) Control panel assembly
    Light bulb harness Defroster switch Air mix damper control cable Air outlet changeover control cable
To install:
  1. Attach control cables to control panel
    1. Set the air outlet changeover control knob on the heater control assembly to the defroster position.
    2. Set the air outlet changeover damper link of the heater/cooler unit to the defroster position as shown in the illustration, and then connect the cable to the link pin.
    3. Push the outer cable in the direction so that there is no looseness, and then secure it with the clip.
  2. Install or connect the following:
    Defroster switch Light bulb harness Control panel assembly Foot duct (LH) Instrument panel center reinforcement Floor console Radio/tape/CD player Front passenger's side under cover Front driver's side under cover Center panel assembly
Mar 24, 2011 | 2002 Chrysler Sebring
Laptop Hickups
Your LCD panel is bad, replacing yourself will cost over $100 depending on the quality of the replacement panel.
Jul 20, 2010 | ASUS Laptop
H-series Electronic Gas Pool Heater H400: I have an H400 with digital temp control panel, th...
It is likely the keypad that has gone bad. Not difficult to replace. But you want to be sure thats what it is, as it is an electronic part, that is usually not returnable. The part number would depend on the model of the heater. Likely it is a h400idxl2 heater.
May 16, 2010 | Hayward H-series Electronic Gas Pool...
I have a 42" lg 42pc56 tv with perfect sound but no picture can you help?
Most common problems with no picture on plasma TVs are the 2 Y-buffers boards and the Y-SUS main board. Not being 100% sure without being there to check it out myself, I would have a TV repair confirm the diagnoses. Normally, they would charge a small fee to come to your home and check it out.
The cost of the replacement parts are not cheap. The new Y-buffer boards cost about $125 each. The new Y-SUS main cost about $200 - $350. That's why confirming the diagnoses would be a good idea because of how much money is involved for parts.
Feb 25, 2010 | LG 42PX5D 42 in. Plasma HDTV
Lightning Strike - Master Temp 250
I have dealt with similarly damaged boards, I can testify that while they can be repaired, the cost of labor is the most significant factor and some parts may be tough to get. I would have never undertaken it but the company which manufactured the control board (this was a sophisticated electric security gate) couldn't ship us the board in the time we could afford to wait so I repaired it. Once. The second time lightning hit it, I replaced the board and ordered the installation of a 'whole house' surge arrester.
Aug 29, 2009 | Pentair Mastertemp Pool & Spa Heater Dual...
Control panel for GE microwave
The control panel module is different from the membrane. Unfortunately these modules themselves are usually very expensive, perhaps 1/2 the cost of a new microwave.
Oct 06, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Heater/AC control non-functional
The tan wire should be the fan speed control, as you change the speed of the fan the voltage will increase. If it is at zero the programer is faulty or the fan speed is turned all the way down.
Feb 23, 2009 | 1991 Chevrolet S-10
VIZIO VW32L HDTV20A Cracked screen.
I have checked with my distributor of Vizio parts and the panel isnot offered as a replacement part. It may be available to authorized service centers. Call an authorized service center and inquire. Be prepared to find that the replacement panel cost may be close to a replacement set cost.
Dec 04, 2008 | Vizio L32 32 in. LCD HDTV
Can't print
is this connected with a usb cable? did you try checking the printer status under control panel? try to download a HP Printing Diagnostic utility from
Jul 30, 2008 | HP PSC 2110 Color Printer
Carrier 38CKC060 Air Conditioner Logo
48 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
