Question about AOpen DVD Player (AOPDUW1608CG) Burner
I did something in setup mode now I hve no picture
I have an arrgo add 210. I cant get a screen to come up on tv
  • Anonymous Jan 02, 2009
    I hooked up an older (7 YRS) Classic surround system and used component cables in setup I switched the video to RBG and the picture went blank is there any way to reset this?
Press and hold the off button on the unit for five seconds and it will reset itself to default satting.
Posted on Dec 02, 2008
Scaleo p fitted new graphics card asus geforce 210 wont start up
Hi , i suggest try running the driver setup in "custom mode" checking option : clean install , to remove previous possibly corrupt installed settings
Also access BIOS setup and change "first seek peg" or some such, so BIOS communicates to Windows to first seek video device expansion card rather than onboard
(ps , if changed from onboard to expansion card ensure the onboard control applet for onboard video has been uninstalled via add/remove)
Jan 26, 2013 | ASUS GeForce 210 Silent - 512 MB GDDR3 -...
Before while watching TV a message comes up saying it will go into sleep mode, now it doesnt have a picture screen at all
depending on the model number set is not making it full on--something is causing the set to shutdown for protection.
Apr 09, 2012 | Televison & Video
The screen went big so we cant see the whole picture
hello!
looks like your TV picture in a "zoom" mode. Find "screen format" button on your remote control and set desired size. It, also could be named "format". Some models require to use customer setup menu.
Set format on "auto" mode, if possible.
Good luck,
Alex.
Dec 26, 2011 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I have a Dynex TV thats about two years old. Model DX-L150A11 It does not repeat the picture size when channels are switched. I have to use the zoom feature to get the correct size picture. I tried all...
Do one thing Go to the menu of the tv. Select Picture setting and then select Advanced video and select Zoom mode. In zoom mode select Wide. If you hve already done this ,
Then select the Overscan option in the same menu page and select it as ON .
Next one select Auto zoom in the same menu page and select it as OFF.
OK
Sep 04, 2011 | Televison & Video
I have an Arrgo ADD-210 DVD player and I cannot find a code for this universal remote.
An applicable code would be in the remote, if compatible. You can use code search to find out. If a search through all codes stored in the remote fails, you my have to try a different universal remote. All universal remotes do not contain all possible codes.
Aug 30, 2010 | Philips Magnavox Learning Universal Remote
Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Apr 06, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
CANT USE DIGITAL TV OR HDMI MODE - SCREEN NOT SIZED
Give FUNAI a call they can walk you through the problem. There info is...
FUNAI CORPORATION Customer Service
Tel :1-800-605-8453
http://www.funai-corp.com
Feb 15, 2009 | iLO IWT3206 TV
Cuts off picture at top of screen and bottom of screen
good luck tryin to find a universal remote i cant...but if you do there should be a button that might say something like pip, pix, screen mode something like that and it will make the picture streach to fit the screen however not all channles will be set on the same screen settings.
Dec 27, 2008 | Emerson EWL3706 37 in. LCD Television
Picture & Color Distorted
Convergance IC replace.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 11, 2007 | Toshiba 50HX70 50" Rear Projection...
Computers & Internet Logo
162 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
