Question about ASUS A8N-VM Motherboard
Not able to use the microphone
GOt the same motherboard and had been replaced but the problem is that the microphone section of the motherboard does not work.The microphone had been replaced with new one when I plug in it still does not detect any sound from it. Able to hear songs but the does not detech any voice when I checked the sound card software that came with the motherboard the line in option remains greyed out don't know why.even reinstalling the drivers of sound card does not work any recommendations.
    Scholar:
  • 121 Answers
If the mic is greyed out, then it's not available. Are you sure that you have installed everything for the sound card? In most cases, sound cards come with their own software that you can install along with the hardware...Sometimes the extra software is needed even when the sound is integrated with the motherboard. I would check the manufacturer's website to make sure that you have all the necessary software.
Posted on Mar 28, 2007
Microphone is not working
Note that the microphone is not listed individually in Device Manager because it works through your sound card. Perform the steps in the following sections in order, and then test to determine if your issue is resolved after each section.
NOTE: The microphone should be selected as the recording device in the Volume Control tool(sndvol32.exe).
To verify this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type sndvol32.exe, and then click OK.
  3. Click Properties on the Options menu.
  4. In the Adjust volume for box, click Recording.
  5. Click OK.
  6. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording.
Check Your Hardware loadTOCNode(2, 'moreinformation'); If your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer.
Jul 23, 2011 | Sony VAIO VGN-NR310E/S Laptop
My speakers work but my mic does not. I cant see any hardware for my mic
  1. In the Open box, type sndvol32.exe, and then click OK.
  2. Click Properties on the Options menu.
  3. In the Adjust volume for box, click Recording.
  4. Click OK.
  5. In the Microphone box, verify that the Select check box is selected.
All the properties listed on the Playback section of the Volume control are independet of the recording settings. So you could record through the microphone by selecting it on the recording section, and mute it on the playback section. Then, you could record sound, but wouldn't hear it through the speakers while you are recording. Check Your HardwareIf your microphone has never worked, or if it has stopped working, first check the physical connection of the microphone. Verify that it is firmly plugged into the microphone port instead of the headphone or speaker port. If you are not sure which port is correct, you can check the sound card to see if it is marked (sometimes with a picture of a microphone), you can use a process of elimination, check the documentation that came with your hardware, or contact the hardware manufacturer. Sound Recorder
  1. Run the Sound Recorder tool: Windows 95Click Start, point to Programs, point to Accessories, point to Multimedia, and then click Sound Recorder. Windows 98Click Start, point to Programs, point to Accessories, point to Entertainment, and then click Sound Recorder.
  2. After Sound Recorder is running, click Record (the circle on the right side), and then speak into the microphone. If it is plugged into the correct jack, the line on the display should move up and down. If it does not move, sound is not making it through your microphone. If the line does move, press Stop, press Rewind, and then press Play to listen to your recording. If this works, but it does not work in your program, view the "Using the Microphone in Programs" section in this article.
  3. Still Cannot Record
If you cannot record a .wav file after you follow the steps in the previous section, there may be a problem with your microphone property settings. To check these settings:
  1. Double-click the Speaker icon on the taskbar, and then verify that the Microphone slider is at the top and that the Mute check box is not selected. If Mute is selected, click to clear the check box.
  2. Select Properties from the Options Menu. Select Recording and click OK. Verify that theSelected check box under Microphone is checked, and that the Microphone slider is at the top.
  3. Try recording a .wav file again.
Jan 19, 2011 | HP (400745-001) Sound Card
Microphone not detecting sound in sound recorder
1. Right click the sound icon in the system tray
2. Click "Adjust audio properties"
3. Go to the "Voice" tab at the top
4. Ensure that a device is selected for the section "Voice Recording"--ensure the appropriate device is seleted--most likely ti will just be one option --make sure it is selected
Dec 19, 2009 | Dell Inspiron 1520 Motherboard
Feedback sound
If moving the microphone doesn't work then suspect "microphonics" where a loose electronics component is vibrating and acting as a microphone. Could be cable. Unplug all microphone cables, still feedback? Right click speaker icon, sound properties, temporarily disable computer sound input devices. If still feedback then analog section of sound card (or motherboard sound chip) or your speaker system.
Oct 15, 2009 | Altec Lansing Multimedia Computer Speakers
I have a P5GD1- vm motherboard.when I use a microphone I cann't have my voice neither to voice chat nor to record it. I mean I cann't sent my voice or record it using mic. my microphone is ok and I have...
hai
check that the line in and the microphone in or the rear pink in is unmuted. This is a general issue. Try doing this through volume mixer recording and playback section
Oct 11, 2009 | ASUS P5GD1-VM Motherboard
Plug in Microphone not working in Dell Inspiron Laptop
Sounds like the sound card on your laptop may be bad. Your laptop may have an integrated sound card on the motherboad or a seperate sound card. As part of the motherboard you have to get a new motherboard. First check your drivers and go through the trouble shooting section.
Apr 23, 2009 | Dell Inspiron 1501 Notebook
My Microphone is not working
Simply enable the microphone and check the audio control tab to see if the microphone is not mute....sodeep
Dec 12, 2008 | Asrock 775i65G Motherboard
Microphone port not working
in advanced settings there would be options for microphone boost and something else...disable both...i dont know the reason why this happens but mic doesnt work with those options enabled....
Dec 05, 2007 | ASUS A8N-VM Motherboard
My mic has stopped workin again !st time i had my motherboard replaced and had sound driver uninstalled and reinstalled then it worked.now its gone again works abit when wiggled in socket I uninstalled...
If it works when you wiggle it in the socket, it's not a driver issue. It's either a problem on the motherboard again, or a short in your microphone cable. As replacing a microphone is a lot easier than replacing the motherboard again, I'd suggest finding another microphone, plugging it in and seeing if that fixes it. If it doesn't, I'm afraid it's the motherboard.
Aug 27, 2007 | Dell Inspiron 6400 Notebook
ASUS A8N-VM Motherboard Logo
63 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
