Question about Epson Stylus CX6000 All-In-One InkJet Printer
MY epson cx6000 picks up several pieces of paper at a time when printing
  • Epson Master
  • 5,568 Answers
Having dealt with hundreds of printers while still in business, I found many models that were a tad fussy about paper quality.
The cheapest paper is often not very smooth and tends to stick together more than partial or pure rag paper. Another item that can cause problems is the edge quality; if the paper was sheered poorly, it has a slight lip that can cause it to hold on the the neighboring sheet.
Finally, if you always remember to fan the paper, and better yet, from both ends before loading the tray, it will break the surface adhesion between sheets.
Posted on Dec 01, 2008
My epson stylus cx6000 has stopped printing black. I've cleaned the print head, changed the cartridge and it still won't print black. What else can I do?
Be sure you are using genuine epson ink. Epson printers are "smart" and will not allow generic ink to work properly. Even after you replace a generic with a genuine it may take several print outs and alignments to get it to print again.
May 05, 2011 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus CX6000 inkjet printer. Problem: Print head assembly jammed while traveling from left to right. Now it won't move, so can't print. I'm handy, can I do something? Or do I need a service...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 21, 2010 | Epson Stylus CX6000 All-In-One InkJet...
The Black is not printing, even after cleaning the head several times
With the EPSON'S you must "Genuine" Epson Cartridges. It does not print good with Generic.
I went thru 2 sets of cartridges, trying to clean the heads alot of times. Finally, had to buy another one.
If you are using generic, change back and see what happens and try again. If not , Good Luck.
:0(
Nov 18, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson Stylus CX6000 Won't Load Paper.
hmmm am afriad if u had a warrant for it just take it back to them and get a new one...plastic staffs are hard to fix.
Nov 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson C88+ printer paper issue
There may be a small piece of paper still stuck in the mechanisms.
Aug 19, 2009 | Office Equipment & Supplies
IT'S AN EPSON STYLUS CX6600 NOT 6000. I'M SORRY IF I TYPED IT INCORRECTLY. AL
Don't worry about the model, same instructions
Clean the machine, the rollers also and follow these steps to clear out any paper jams it might have
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 03, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Epson stylus cx6600 alll in one roller crimps and stops paper from rolling. My computer says it is working properly. It all started with a paper jam, which I cleared, hit "color" and thus my problem.Ally
alternative :
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
