Question about Glyph GT 050Q (GT050Q1F250) 250 GB Hard Drive
My computer does not show glyph drive aftwer its connected
I plug in my glyph drive to my computer , i hear a deing sound but it doesn't show up in disk c or anywhere - what do i do ?
  • WishingJosh May 11, 2010
    is it newly purchased? or have you been using it for a while?
SOURCE: my computer does not show glyph drive aftwer its connected
I had not created even a primary partition for my Glyph drive which I needed to do. So I created a new partition and seleected the maximum size for it which was all 500GB of the drive, since I dont want any real divisions of the drive; then I selected quick format. This is actually on the Glyphtech.com questions on how to format the drive, it will telll you about this step of creating a primary partition (or even more partitions if you want them).
Posted on Feb 19, 2009
Help! Glyph PortaGig 50 won't show up!!
Control Panel, Computer Management, Disk Management. Check that your Glyph is present. If it is present, does it have a drive letter assigned? If not Right Click and Assign Drive Letter.
If drive not present you should check power and data connections.
Dec 16, 2013 | Glyph PortaGig 50 External USB 20 Hard...
My glyph harddrive dont show up on my mac why?
If the hard drive was formatted on a PC computer in NTFS file format then the MAC will not recognise this hard drive.
If you want to transfer data between the PC and MAC then you need to format the hard drive with a PC in FAT32 file format. The MAC can read and write to a FAT32 formatted hard drive
Aug 08, 2012 | Glyph GT 050Q Hard Drive
PC won't see my glyph drive after I have installed Mac Drive 8
Take it back to where you bought it, and exercise the warranty, to get it replaced or repaired.
May 07, 2010 | Glyph GT 050Q Hard Drive
My glyph is not loading and i did nothing wrong or weird to it, i want to smash it now!
Did you format the Glyph tabletop harddrive? If you didn't format it, it won't work.
Your Operating System is not stated, so let me give you an example using Windows XP. (Home or Pro doesn't matter)
Power cord plugged into the Glyph harddrive, and plugged into a surge protector, 6-pin Firewire cable, or 9-pin Firewire cable from Glyph to computer plugged in, Glyph power turned on, computer on, Windows loaded,
1.Left-click on Start, then Right-click on My Computer. Left-click on Manage, in the small fly-out menu.
2.In the Computer Management window, under Storage, click on Disk Management. The Write Signature wizard will pop up.
3.Use the wizard to write a signature to the new drive. The drive must be named. Name it what you want. (Drive 2; My Drive; Storage 2: Your name;
whatever you wish)
This drive must be named, or Windows won't be able to find it.
4.Now I suggest just making one partition, and it will be the Primary partition. Do this by selecting the Maximum Size. (Partitioning: Think of your harddrive as a large room. A Partition is a wall, dividing the room into two rooms. This time you won't be dividing the room. You will use the whole room. 250 GigaBytes of it) Choose -> NTFS.
Follow the instructions, let it format the harddrive.
You should be good to go now.
I have added this link, to a PDF file download of the
-> Glyph GT 050Q Quick Guide <-
http://www.glyphtech.com/docs/610021%20GT%20050Q%20Quick%20Guide.pdf
Jun 05, 2009 | Glyph GT 050Q (GT050Q1F250) 250 GB Hard...
Computer will not recognize my 120G Glyph Netdrive when connected
check for the power and data slot sometimes wires are loosely connected also try to find appropriate driver as per the make of hard drive
May 08, 2009 | Glyph NetDrive (ndfw1b-80) 80 GB Hard...
Feb 19, 2009 | Glyph GT 050Q (GT050Q1F250) 250 GB Hard...
Glyph drive wont boot
you could try a program like disk warrior or disk rescue, or you could try giving Glyph a call, they have pretty good warranty coverage.
Nov 17, 2008 | Glyph GT 050Q Hard Drive
My glyph is not seen on my mac
If the drive is connected via firewire, power the drive. If the drive powers and you can place your hand on it and feel it "spinning", and still it does not mount. Try a different FW cable. If still no mounting action, place your ear on the drive to hear any grinding or clicking. If the drive sounds to be operating normal, open disk utility.. Hard drive/Applications/Utilities/Disk Utility The drive should appear in the left pane under your computers hard drive. You should see the button to MOUNT it on the top right. Hope this works
Oct 01, 2007 | Glyph GT 050Q 400 GB FireWire 400 (1394a)...
Computers & Internet Logo
Top Glyph Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Juriy Hawrylak
Juriy Hawrylak
Are you a Glyph Computer and Internet Expert? Answer questions, earn points and help others
