Question about Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
I have a new electrolux el7025a-r and it keeps cutting off while I am vacuuming. I am using the small powerhead on hard floors and I have checked the hoses for blockages and the bag is new. I can not figure out why it keeps turning off in the middle of a job.
    Scholar:
  • 55 Answers
The wands are notorious for going out on that unit. One or both probably need to be replaced. Try to get it done under warranty if you still have the receipt, but they shouldn't cost you too much if you can't.
Good Luck
Posted on Dec 01, 2008
Powerhead on vacuum shuts off after about 5-10 seconds of use. What is cause?
There are several possibilities, some of which you seem to have already checked.
1) The filters are clogged. System will cut out quickly if there is little or no airflow, to prevent overheating.
2) There is a clog somewhere besides the filter. Run through the checking for clogs steps in the manual, page 6. (
https://www.dyson.com/parts/u/user-guide/medialibrary/9118C278B029492DA662A45A70F187B0.ashx )
3) There is a small, Hall-Effect sensor near the filter that detects that the filter is in place and seated properly. If it is faulty, or the filter ISN'T seated properly, it cuts the power. Replacing that is beyond the scope of what I can safely advise on.
4) There are temperature sensors for the unit. If it's too cold, or too hot, no power. Too hot means the system thinks the battery is overheating, which can be dangerous. If the temp sensor is bad, that could do it too. This is also past what I can really help you on.
Good Luck!
Apr 20, 2015 | Dyson DC21 Motorized Power Floor Tool
Electrolux EL7055 powerhead not working
Have you tried testing the continuity in the hose, wand, and power nozzle? You can also try putting the hose directly in to the power nozzle. If you still need help with you electrolux vacuum try contacting evacuumstore.com
Nov 17, 2013 | Vacuums
Remove bottom of electrolux prolux upright vacuum. Hose is clogged.
You shouldn't have to remove disassemble the powerhead.
Lay vacuum on it's front. Between the tank and the powerhead is a black flex hose. Pull the end straight out from the powerhead. Then unscrew the tube from the tank using a clockwise turn. Remove the tube and visually check for clogs and splits. Clear or replace as needed.
If there's a clog in the powerhead behind the brush, this can be cleared using a wooden spoon handle or similar object.
If there's no clog in either place, there's a couple other possibilities. First, turn the vacuum back upright, open the hose flap, turn vacuum on, and place hand over opening to check for suction.
If there's a lack of suction, the bag needs replaced, the afterfilter beneath the bag needs cleaned, or the motor needs replaced.
If there is suction, put a coin in the opening inside the port and to the right as you're viewing the front of the vacuum. The coin should drop to the floor. A clog in thes section is unusual, but can happen.
If there is still no suction, take the vacuum to the nearest authorized Aerus Electrolux store for free diagnosis.
http://www.aerushome.com/storelocator/
Mar 11, 2011 | Electrolux Vacuums
We have two of these vacuums and both of them have experienced the same problems. First the floor heighth adjustment doesn't work and now neither one will pick up on either carpet or floor when in the...
Did you check the powerhead for obstructions? With a bend in the tube just below where the hose connects, this is a common spot for clogs. To check, detach hose and drop a coin in the hole. If it doesn't drop through, a blockage is present. Use the handle of a wooden spoon to push clog back through to brush. It can be removed with long-nose pliers from there.
For height adjustment, check for debris that may be preventing the nozzle from raising and lowering. There may be something inside the powerhead preventing it as well.
The manual can be found at the following site. On the left side of the page, under the image, click on the Use and Care Manual button.
http://www.abt.com/product/20743/Electrolux-EL5035A.html
Jan 21, 2011 | Electrolux Oxygen 3 Upright Vacuum Cleaner...
Hi I have an electrolux vacumm cleaner, super J model. My problem is that the powerhead only works if the switch is in the off position. vacumm motor works in the on position, opposite of each other. Can...
Looks like there's an interchanged wires in your vacuum. Both the motor and the powerhead must go together. Check it up. Leave the
motor wiring connection intact. Just tinker and check the powerhead
wiring connection .
Sep 25, 2009 | Electrolux UltraLux 2000 Bagged Canister...
I need a new hose for my Electrolux central vac
Do you need a new powerhead too or only the hose? If you need a new powerhead than I would recommend looking at the Imperium Pro Elite Attachment set. It is an excellent quality powerhead and hose. If you only need a new hose than you will need to contact the Aerus because they will be probably be the only company who can sell you a hose that wil be compatible with your powerhead. Their website is http://www.aerusonline.com/products/
Jan 21, 2009 | Electrolux Central Vacuum
Powerhead Keeps Shutting Off
Open up the power head and check the toothed corners where the power head sits - it sounds like thread has caught up at the sides which can only be removed by opening up the powerhead to clean it.
Nov 14, 2008 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux Epic 6500 Powerhead Motor
Call an Aerus Electrolux dealer in your area.
Jan 29, 2008 | Electrolux Epic 6500 Vacuum
EL5 (large) powerhead
There is a no filter safety device part #1130912-01, maybe the new filter isn't in quite like it should be or this device has gone bad. Also check the brush roll and make sure it turns easily, if not then that could be the cause.
Nov 27, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Won't start.
There is a reset button at the back of the powerhead. The user manual can be downloaded from the electrolux website, although I didn't find it very useful. There was some info on how to change the powerhead drive belt.
Oct 01, 2007 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum Logo
258 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
