Question about Linksys Wireless-G WRT54GS Router (e125894)
Wireless shows connection,but will not connect.
Windows Vista Sp1 laptop wired works well, however, wireless will not connect with Internet or to Mail server, even though wireless shows connected with excellent signal strength.
I am wondering if router wireless is defective.
I have used "NETWORK MAGIC" assist setup several times with no success.
    Scholar:
  • 80 Answers
This kind of problem occur due to dhcp disable in the wireless router for the security purpose. So try to give the ip adress manually by right clicking on the wireless and give the ip adress of the same range in which your network in working e.g 192.168.1.0 is the range of your ip addresses so please select the ip which is not been used by any other computer and than in default gateway enter the ip address of you wireless router and you will be able to access the internet on your system.
Posted on Dec 03, 2008
Reinstalled wp on Gateway 400vtx and now the wired internet connection drops out in about 1 min and I get noe connection on the wireless.
Thank you for your kind words, we try very hard to resolve people's problems so a solution can be reached.
Apr 06, 2012 | Gateway 400VTX-3501335 Notebook
I have a laptop running vista ultimate 32 bit version and i am having problems connecting to the internet. It says I am connected but will browse the internet. Are the troubleshooting steps the same as...
The steps are the same though the menus and screens you go through to do them are a bit different from XP. Pretty much all the software steps you can do are covered by the troubleshooter in vista and 7 though, so if you have ran that without a solution, then the likelyhood that it's a setting in windows causing the issue is fairly low.
First I would confirm that your connection is actually working. If you are attempting to connect the laptop with wireless it is not uncommon for routers to stop responding correctly to wireless clients, or even for the wireless portion of a router to die while wired connections still work perfectly. Try plugging the laptop in with a wire and see if you still have the same problem. If wired worked but wireless did not, then unplug your router, wait about 30 seconds and plug it back in. Retry the wireless and if it still does not work then a replacement router will be required to use wireless, though you could get a second cable and use it wired until you do replace it.
Aug 25, 2011 | Microsoft Windows Vista Ultimate Edition
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
My toshiba laptop does not work on a lan. The icon
When you look at the Manage Network Connections link on the Network and Sharing Center you do not see
Local Area Connection?
Do you see Wireless Network connection?
You need to check the device manager to see if the card has been disabled.
It should show two entries with no red or yellow marks. One for wireless (WLAN) and one for wired (Ethernet)
Apr 11, 2010 | Computers & Internet
Unable to connect two wireless laptop for internt sharing
Make sure your computers are set to DHCP instead of static.
Sep 04, 2009 | Dell Inspiron 6400 Notebook
Acer 6930 wireless won't connect anymore.
Hi acording your describle, you need do
1) please check the bios first, to set wireless to enable
2) check windows right buttom bar is there a wireless icon show there and click to see any detect wireless signal, if nothing to detect
3) check or compare to other laptop wireless configuration, check any incorrect setting.
4) if all sense ok, you need check the wireless card and wireless antenna wire connection, open a samll cover at back of laptop, there is a MINI PCI slot with a wireless card, take out and clean the card pins then put back.
5) still trouble please change another wireless card (same model)
it should be fix.
hope help you to fix it, please take a rating le me know how much helped you, thanks. for any question in any time please !
May 17, 2009 | Acer Aspire 6930-6455 Notebook PC
Sharing printer
May your printer doesn't fit to your operating system because Windows Vista is one of the complicated OS and hard to find installer or software to fit it in. Try to Replace your operating system that same as your brother have. maybe it can fix your problem!
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Sharing printer between vista and xp os
Hi have a nice day.
I think tranfering your job to desktop first, and then sending to printer, is a solution for now.
Feb 22, 2008 | Microsoft Windows Vista Ultimate Edition
Linksys Wireless-G WRT54GS Router (e125894) Logo
146 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
