Question about Broan-NuTone Rangemaster RMDD3004 Stainless Steel Kitchen Hood
Broan kitchen hood - frenetic chimney
Hi
We have a RMDD3004 bron hood. Yesterday evening, al of a sudden the chimney went crazy, rising and going down over and over again. The control button did not seem to work.
I tried to reset it by cutting off the power with the breaker... no change.
And of course... warranty has expired 2 weeks ago...
Any help to fix this would be very welcome.
Thanks!
Flo.
  • 38 Answers
It can be 2 things.
1. The motor that elevates the fan is turning a tad to much. Just by stepping on the floor near it could cause it to go up/down constantly.
2.Or what i had seen was the wires that go to the switch dont have enough slack, and are just making contact to the switch causing it to think somone is pushing the button constantly.
There is way too many steps involved to type out.
Posted on Feb 08, 2009
My Broan range hood keeps going up and down. Will not stop. I unplugged it and plugged back in but keeps going up and down. The hood is almost 2 yrs old. Pls help. Thank you.
This sounds like something has got into the track area and is setting off the safety. they are designed to stop raising or lowering if they meet any resistance and anything in the track area will cause it to happen in both directions
Jun 26, 2011 | Broan-NuTone Best by Broan DD01 Series...
Lights on hood fan will not shut off.
It sounds like your switch is getting stuck internally. It most likely needs to be replaced.
Here is a break down of your unit. http://parts.broan-nutone.com/broan/Shop?DSP=30200&PCR=1:1000&IID=QS330AA&imagesequence=
Also, you can order parts directly from Broan, here. http://parts.broan-nutone.com/broan/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=QS330AA
Hope this helps you somewhat, please post back if you need more help.
Mar 07, 2011 | Broan-NuTone Allure III QS330SS Kitchen...
Broan elite hood vent has blinking light that won't reset with power off/on. What gives?
I turned both the light and fan on then pushed the filter button. After a loud beep the filter light reset went off. This worked for me.
Jan 21, 2011 | Broan-NuTone Broan Elite E661...
I have a Broan 2736 Eclipse downdraft blower system. When I push the button the downdraft rises but then immediately goes back down
Gail was spot on. That worked for me until the unit would go up and/or down on its own. The problem was traced to the double microswitch called the 'Lower Switch Bracket Assembly' ($24. thru Lowes ). To replace these switches is not for the faint of heart as it is deep within the assembly. A good weekend mechanic can look at the exploded parts diagram and see what / where. Found grease residue on- and slightly within- the microswitchs due to Broan not properly design shielding and protecting these critical switches from grease. Did not find any ghosts, however.
Nov 08, 2010 | Broan-NuTone 273603 Kitchen Hood
I just had a Broan Elite E662 hood installed and it is blowing out instead of pulling air in. I held a tissue up to the filter and it does not pull it up...rather it blows it down. Was something done...
It sounds like the fan blade may be installed upside down, or the entire motor/fan assembly is upside down. Typically, these small motors aren't reversible, so you should check the blade first.
Dec 13, 2009 | Broan-NuTone Broan Elite RM605404 Kitchen...
Suddenly became very noisy, unit has only been
Sounds like fan has become faulty - suggest contact manufacturer directly
Aug 07, 2009 | Broan-NuTone Intermediate Whispaire ...
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Broan-NuTone Rangemaster  RMDD3004 Stainless Steel Kitchen Hood Logo
174 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Dan Phillips
Level 1 Expert
Phil Lovisek
Phil Lovisek
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
