Question about Lexmark Office Equipment & Supplies
I have replaced both my color and black cartrigages for my x2500 printer, restarted the computer, and it is still giving me an empty cartrigage message
    Scholar:
  • 81 Answers
Is this a pc or mac?
for windows general make sure you folowed these steps:
  1. Click Start, Programs, Lexmark Series.
  2. Click Lexmark Control Panel.
  3. Click Print Cartridge installation.
  4. Depending on which cartridges you are using and which printer model you have, select Install Color Cartridge or Install Black Cartridge or Install Photo Cartridge.
  5. Carefully remove the tape covering the printhead of the print cartridge. Important: Be sure to remove all of the tape. Do not touch the copper area on the back of the cartridge.
  6. Insert the print cartridge into the print cartridge carrier.
  7. Push the cartridge back until it clicks into place.
    • If the print cartridge moves loosely in the carrier, it is not locked into place. Repeat step 7.
  8. Click the appropriate Cartridge Installed option in the printer software.
    • If you choose to install a new print cartridge, you will be prompted to align your print cartridges. The printer will print a page with a bi-directional alignment pattern. Follow these steps to align the cartridges:
      1. On the printed test page, locate the number under the Bi-directional Alignment pattern that comes closest to forming a straight line.
      2. Enter the number as the Bi-directional Alignment setting in the Alignment Cartridge screen.
      3. Click OK.
  9. Close the front cover of the printer.
Posted on Dec 01, 2008
PRINTER 5440, POOR PRINT QUALITTY HAS GONE FROM GREAT TO BARELY LEGIBLE, FAIRLY NEW CARTRIGAGES
Depending on the age of the printer, the service staion may need to be cleaned. The service station is where the cartridges "park" when they are not in use. Over time ink can collect in this area and therefore the ink cartridges do not get a thorough cleaning. I would go to HP's website and look for cleaning instructions for your printer model. Hope this helps
Sep 30, 2010 | HP Deskjet 5440 InkJet Photo Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    How to refilling cartrigage
    check this
    http://www.youtube.com/watch?v=MPi2GqJg5QM
    Feb 25, 2010 | HP DeskJet F380 All-In-One Printer
    How do I get the cartrigage holder to stop so I can change the ink cartigage
    Normally by opening the flap the machine should default to the change cartridge position
    Dec 25, 2009 | Office Equipment & Supplies
    White vertical lines, incomplete print-out...
    you need to use the printer jet cleaning software to clean cartrigages or you may be getting low in ink
    Oct 30, 2009 | HP Inkjet 2300 Printer
    Align print cartrigages won't turn off
    You have a problem in one or both cartridges. Try to change it.
    Sep 28, 2009 | HP PSC 2210 All-In-One InkJet Printer
    Continue to get "empty" messages after replacing both ink cartidg
    hi... try these steps
    >unplug power adaptor and plug it back in
    >try to identify whick cartridge is giving u trouble..black or colour by inserting carts one by one
    >if sam ething happens..contact tech support on 800-332-4120..printer would be replaced
    Feb 12, 2009 | Lexmark X2500 All-In-One Printer
    Ink cartridge missing
    you can tell me plz which printer use u .......i hope u use both color & black ink cartridge.....go to printer
    setup .......???????if your black ink empty you change your near pc Or printer vender........
    Oct 16, 2008 | Lexmark X2500 All-In-One Printer
    Black Ink Cartridge error
    i ended up putting a color and black cartridge in and everything is fine.
    Mar 27, 2008 | Lexmark X2500 All-In-One Printer
    126 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
