Question about Gateway Computers & Internet
I can not get my laptop to charge where you plug in to the laptop it seems to be hard to make contact. Some times I can move the insert around and it will charge.
    President:
  • 2,110 Answers
The socket inlaptop having some problem try to take to nearest service center..
Posted on Dec 01, 2008
I have to move around the power plug to keep the power charge on. The power jack get worned out and want to fix it. I need acces to it. How could I open the case?
I would recomend having a pro do this. The Compaq has panels to get to the memory, Hard drive and most replaceable parts but getting to the power plug could be a real pain. One thing you might
try is taking a jewlers screwdriver and VERY GENTLY push up on the bottom contact bending it up
slightly to give it better contact with the power supply but be very careful not to make it worse than it already is. This assumes it uses a power supply with a standard coaxial ac/dc converter type plug.
May 11, 2011 | HP Compaq Presario CQ60Z Notebook
I got a compaq c36 it was working fine but now it wont switch on or anything do you now what it could be
1. Plug the laptop into AC power.
2. Take out the battery.
3. Try a different outlet.
4. Look for the light that indicates that the AC adapter is plugged in. If that light isn't on, try plugging and unplugging the AC power jack and moving it around until the light shows its connected. If no light comes on, its possible you have a bad DC jack or the AC adapter needs to be replaced.
5. If the indicator light is on and the laptop won't power on, then it's possible you have a bad switch board or stuck button. Make sure no buttons are stuck. Conversely, push hard on the power button and move it around in order to make sure you're making good contact.
6. If you know the battery has a charge, unplug the AC adapter and connect the battery. If it turns on, then you can be sure you have a bad DC jack or a bad AC adapter.
Mar 01, 2011 | Computers & Internet
Hi i have this problem i dont know if its bad or not but every night i turn off my lap top and let it charge over night then this morning when i log on to my user my battery says 4% plugged in, not...
This can be a couple of things. The battery, the charger, the internal charging circuit, or the connector.
The battery is not that old but just enough that you could see problems depending on how you use or charge. If you drained it a lot or never used it on the battery this can happen. If the battery was the problem then you would see very short run times when it was fully charged. For example it may run down in say 10-15 minutes or less. The battery may still be under warranty. If you feel a hot spot on the bottom of the laptop after charging overnight this usually means the battery has a problem. The heat is from the charging circuit working pretty hard.
The adapter or charger can be bad but rather rare for it to happen. Usually they work or they don't. Again should be under warranty.
The internal charging circuitry can be having a problem. Not common at all but it happens. Again will be covered by warranty.
Last is the charging plug. This is the connector where the adapter plugs into the laptop. If the plug has been damaged or is loose it won't charge properly. The way to check this is to plug the adapter in and then gently move it around if the plug moves or doesn't feel secure then this has a problem. Usually when this happens the lights on the laptop may flash off and on as it makes proper contact. This may be covered under warranty. When it isn't they will say it is user abuse.
It may take you a bit of watching to see what the problem is. It could be a one time thing ie the connector wasn't plugged in right. It can be a bad battery. Batteries can go quickly but normally they fail fairly slowly over time. You need to check if you have warranty. All of this should be covered on a ~18 month old laptop but you may only have had a 1 year oem warranty.
If you have to pay for anything a battery is $40-$80, a power adapter about $50. The charging circuit requires a new mainboard and the plug depending on the model either requires a new mainboard as its built in or the plug is a seperate piece which can run from $5 to about $100. The battery and the plug are the most common cause for this type of problem.
Sep 05, 2010 | HP Computers & Internet
Dell inspirion 1501 laptop, not charging battery light showing red, have bought a new mains adaptor but still not charging
Does the back dc jack seem loose when you have the ac adapter plugged into it? Wiggle the cord right where it plugs into the laptop. If it moves around then most likely the dc jack on the inside has one of it's 3 points of contact broken. This means that someone would need to re-solder that contact or put a whole new jack into the laptop. Another thing to try is replacing the battery. Sometimes they won't charge because they are bad. Another thing to try is take the battery out, plug it into the adapter, turn it on, get into windows, shut down, put battery back in, turn on. See if that resets the battery and makes it charge.
Apr 30, 2010 | Dell Computers & Internet
No connection with the DC Jack on Gateway 3550GZ
It's time to take the computer to a qualified technician, for proper trouble-shooting & repair, because there are very-few "user-repairable" parts inside a laptop/notebook computer.
Jan 20, 2010 | Gateway 3550GZ Notebook
Help, Toshiba Satellite M35X-S111 laptop has stoped charging the battery. The light stays orange no matter how long its pluged up. You have to move the plug around to get it to power, I had it checked by...
what is the age of the laptop?
How old is the battery?
Try this...
1. Check/test the battery
2. Test the charger.
One of these seems to be the problem...
Jeff
Oct 25, 2009 | Toshiba Satellite M35X-S111 Notebook
HP Pavilion dv2020us laptop battery won't charge
How is your power supply? does it seem like you have to wiggle your cord that connects to computer to make it recieve power?...Many laptops power supply become loose over time form moving the cord around..when it does, the battery has a hard time getting electric power to recharge. Also, you my have other problems with your lithium internal battery that powers your cmos.
Check to see if your power supply is loose and go from there. the power supply is the little hole where you connect the cord to the laptop.
let me know what the status is
Apr 10, 2009 | HP Pavilion dv6000z Notebook
My Laptop will NOT charge! What do I do?
It is obviously not charging. Either the battery is defective, the power adapter is not getting power, the adapter itself is defective, you're not using correct adapter or power outlet is no good.
Try to see if theres any light at the laptops jack where you connect the power, if not theres no power getting in.
Try to remove and insert the battery again.
Make sure all power connections are secured
Try removing the battery and just plug it the power adaptor to isolate the problem.
Try another power outlet
If plug in to power strip, try resetting strip by turning off and on
If none of these work then you may have a defective jack in your laptop.
Jan 12, 2009 | Compaq Evo N610C Notebook
Power supply malfunction?
Remove the battery and try the cord again. Complete with the moving it around. It sounds like you have already diagnosed the loose DC plug adaptor, but the battery could have gone terminal.
Apr 17, 2008 | HP Compaq Presario V2000 Notebook
Dell latitude D600 battery charge light flashing
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Computers & Internet Logo
16 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
