Question about Power Up Power-Up USB 2.0 Media Kit with built-in Webcam & 3 Port USB Hub
Power-Up USB 2.0 Media Kit drivers - Power Up Power-Up USB 2.0 Media Kit with built-in Webcam & 3 Port USB Hub
Drive
Posted on Aug 05, 2009
My HP tower is no longer in existence, how can I extract data from HP Personal Media Drive? Is there a place I can send this to or is there a company close by, all I need to do is be able to insert this...
http://www.ebay.com.au/itm/120738767650?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649 AU $8.40 Buy it Now + postage AU $0.96 you could get this on Ebay if you dont have an account you will need to create one https://scgi.ebay.com/ws/eBayISAPI.dll?RegisterEnterInfo Add Email adress Add Bank Acc Add Credit Card also add your postal adress also add a paypal account On Ebay summary page you will see on left a paypal link When you get to the paypal login page at the bottom you will see new to paypal sign up tab Paypal to create an account Paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress be very specific when you type in the search Always ask questions ? Before you make a purchase and keep the email /s for security reasons if the item arrives and its not as described. You will even see the pictures of your item so you cant make a mistake and get them home delivered. or you might be able to find one closer for local pick up
USB 2.0 To SATA IDE 3.5 2.5 Hard Drive with an Adapter Cable
http://www.youtube.com/watch?v=iE8t5IGr0e4
http://www.ebay.com.au/itm/USB-2-0-to-SATA-IDE-2-5-3-5-Hard-Drive-HDD-Adapter-/330612048804?pt=AU_Laptop_Accessories&hash=item4cfa0383a4 USB 2.0 to SATA IDE 2.5 3.5 Hard Drive HDD Adapter Kit AU $7.46 free postage worldwide You would have to remove the hard drive and use a usb sata ide kit you will then have to connect it to your computer using a usb port Once connected to another computer to a usb port and power supply you should get a message found new hardware and it should install the drivers it should show on your computer or you might have to install it manually click start click on computer to open you should see this drive If you dont. Click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a Yellow Question / Exclamation Mark? ! or a Red X you will need to update/reinstall drivers right click to reinstall drivers. If you can see your usb drive but its not working ports (com&lpt) right click update driver Once you see this drive just click on it to open and copy all or any data you want and save it to another usb drive or get one of these http://www.ebay.com.au/itm/NEW-2-5-SATA-USB-2-0-external-HDD-enclosure-case-AU-/221010079433?pt=LH_DefaultDomain_15&hash=item33753a2ec9 NEW!2.5" SATA TO USB 2.0 external HDD enclosure case AU
i have used this method with the hard drive adapter and it works
if you need more help with this post a reply
Hope this helps.
Dec 19, 2012 | Computers & Internet
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
How do i download music from windows media player to my micro sd card
hello there are two way u can do that, get a usb card reader and follow any of this process
1. put the micro sd card into the card reader and plug it to your computer then your system will see the card automatically, then open your window media player and the player will detect the card and you will synchronise musics from your windows media player libery to the card.
2. you can copy the music direct from your music folder in your computer and paste it on the micro sd card.
take care
rate this
Jun 04, 2010 | PNY 4GB microSD High Capacity Mobile Media...
My Sanza Fuze 8gb will not turn on. I charged it completely on my computer late last week and shut it off. Today I tried to turn it on several times. Also tried to press the "on" button for 10-20...
First thing to do is: Try other USB ports on your computer. A USB port on the back of a PC usually has better power output. Try a different cable if there's one available, to rule out if you have a bad cable. Try another computer. If none of the above works: Then-Check and refresh the drivers in Windows, for a Portable Device. 1 - Connect your Sansa player to the PC 2 - Check under Device Manager -> 1. Right-click My Computer, and select Manage. NOTE: The player should show up on the Device Manager's right pane as: 1. USB Mass Storage device (if the player is set to MSC) 2. Portable Device (if the player is set to MTP mode.)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers. Then - Refresh the drivers 1. Right-click the entry with the error mark, select Uninstall. 2. On the top menu, click Action then select Scan for hardware changes.
If your BRAND NEW Sansa player is NOT recognized by the computer when plugged in: This may be caused by one of the following: 1. Minimum system requirements were not met. 2. Corrupted drivers. 3. Computer restrictions, Vista or 7 authorizations. 4. Power issue, plug your player into the back of the computer.
Next be sure you are using Windows Media player : Version 10 or 11 Download and install the latest Windows Media Player if it's not installed.
If all this has failed - Refresh the drivers again.
If all that does not work - Manually add the hardware driver. 1. Connect the Sansa player in MTP mode 2. Manually install the device driver through Windows device manager in control panel. Install the Device as a Portable Device.
Feb 11, 2010 | SanDisk Sansa Fuze MP3 Player
Cannot be recognised on my USB ports
The CD supplied does not have drivers on it. This is a flash player so your PC should recognise it automaticaly.
If this is not happening, please try installing an MTP Porting Kit via the microsoft.com website.
Jul 14, 2009 | Samsung YP-S3JAB Digital Media Player
I need a usb charge cable
Go to Wall-Mart and buy the starter kit . You can use other models than your own. They all have the same power adapter in the back of them
The starter kit comes with usb power adapter armband, Carrying case and a wall charger with it.
Jan 07, 2009 | RCA OPAL M4001 MP3 Player
Computer Won't Let Me Access the Device
hey there!
please do the following one by one
unplug the power cable going into the power supply. wait for a while and plug it back
install software with updated drivers. check to make sure you have the most recent motherboard drivers.download if necessary.plenty of sites available
update your windows media player
get Windows XP Service Pack 1 or Service Pack 2 if possible
goto Start Menu->Control Panel->System and then clicking the Hardware tab and going to Device Manager. in Device Manager you could delete all entries with "USB" in the name and reboot. let Windows redetect the USB devices.
uninstall your usb drivers and download the latest ones available and reinstall your usb drivers.
Dec 05, 2008 | Apple iPod nano
I have 3in1 USB 2.0 to IDE & SATA Cable but nothing to show me how to use this kit
SATA 3.5" 2.5" IDE 3 IN 1 TO USB 2.0 CABLE ADAPTOR KIT
1 external connection kit
1 internal connection kit
The internal connect kit consists of 1 red USB connector cable
and 1 internal white male molex connector to SATA female power connector
( 1 yellow wire , 2 black wires , 1 red wire )
the external connect kit
consists of a 3 pin power adaptor (with a tiny plug to save space) feeding a power supply which powers either IDE thru a Molex connector or SATA through a supplied adaptor. Supplied also are data connectors to link the IDE or SATA hard drive with a USB port. Use this adaptor set to retrieve data from a hard drive when it is not mounted in a computer.
Selah :-)
Sep 14, 2008 | Computers & Internet
Sansa e250-MTP Driver
MTP driver kit is located here.
MICROSOFT
Best of Luck.
Nov 08, 2007 | SanDisk Sansa e250 MP3 Player
Power Up Power-Up USB 2.0 Media Kit with built-in Webcam & 3 Port USB Hub Logo
1,240 people viewed this question
Top Power Up Computers & Internet Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Power Up Computer and Internet Expert? Answer questions, earn points and help others
