Question about Peg Perego Vespa Scooter
Routing cables I am now in the process of doing a ground-up re-assembly of a '79 P200E and despite having taken pictures and labelled parts properly, I find myself at a loss regarding the routing of new rear cables, specifically which frame holes the two gear cables, clutch cable, throttle cable and rear brake cable go through. There is a circular hole inside the rear fender front at the bottom - right hand side. I have the wiring to the rear brake/taillight coming out of that. I have also routed the two gear cables, clutch cable and rear brake cable through that hole. Is that correct? Then behind the right hand side cover there are two small holes below the large air intake hole. I have routed the throttle cable through the higher of these two holes (circular). Is that correct? I have nothing routed through the lower hole (oblong) so I must have done something wrong. I have looked through my Haynes workshop manual but there are no pictures showing exactly how the cables enter the frame from the back. Any help you can provide would be appreciated. Thanks Nick Pratt
3 Suggested Answers
  • 7 Answers
SOURCE: MY JCL 49.5 CC 050A scooter will not start and it was fine!
try to clean the carburator, and change the filters to.
Posted on Oct 20, 2010
rockmeister
  • 2047 Answers
SOURCE: During mmaintenance my 1981 Vespa
Hello there, sorry but there is no easy way to take out the screw. The only way you can get the screw out is by opening up the entire engine as the screw is very unlikely to have fallen straight to the base of the engine. You would have to drain out the oil then dismantle the entire engine to locate the screw. Although you might be lucky that the screw falls out in the process of draining the oil but this is quite unlikely. After draining the oil if it does not come out you would need to open up the entire engine. And make sure you do not for any reason start the unit until the throttle stop screw has been removed as that could be fatal to the engine. Sorry for any inconveniences.
Thank you for visiting FixYa.
Posted on Sep 11, 2011
Where are the ground connections in 2001 olds silhouette
There are too many to count.
Starting in about 1985, when cars & trucks began to have plastic and fibreglas parts, separate ground wires ran from every electrical part to the "universal" ground wires, that ran all over the vehicle.
Have a knowledgeable mechanic show you these.
God bless your efforts.
Jan 01, 2018 | Cars & Trucks
Hpcolorlaserjet 2700 showing 79error
Check the grounding of your power oulets. If there is equilizing current trough the ground shield of the interconnecting cable, the information can be transferred with errors. Then the printer cannot process it and gives the 79 error. But HP recommends:
A critical hardware error has occurred.
  1. Turn the printer off and then on.
  2. Reseat the firmware DIMM.
  3. Reseat the formatter.
  4. Replace the firmware DIMM.
  5. Replace the formatter.
Oct 09, 2014 | Cell Phones
How simple is it to change a alternator belt on subaru svx?
  1. Removing the Serpentine Belt
    • 1 Park your Subaru on a level surface and open the hood.
    • 2 Disconnect the ground (black) battery cable using a wrench. This will prevent the cooling fan from activating.
    • 3 Locate the serpentine belt routing diagram in your engine compartment and compare it to the actual routing of the installed belt. Make sure the routing on the label matches the actual routing. If they do not match or there is no label, note the actual routing on a piece of paper for later reference.
    • 4 Locate the belt tensioner pulley on your Subaru model. If the tensioner is equipped with a squared hole, use a large breaker bar with a 1/2-inch (13 mm) drive. Otherwise, use a ratchet and socket of the proper size on the tensioner pulley center bolt.
    • 5 Rotate the tensioner pulley away from the belt to release the belt tension.
    • 6 Pull the belt off of one of the pulleys and slowly release the tensioner pulley back into position. Do not let the tensioner pulley snap back or you may damage an internal component.
    • 7 Finish removing the serpentine belt from the rest of the pulleys and the engine compartment.
    Installing the New Serpentine Belt
    • 1 Match the old belt to the new one and make sure they are of the same length and configuration. It is normal for the new belt to be slightly shorter since the old one has been stretched through use.
    • 2 Route the new serpentine belt through all of the pulleys except the tensioner pulley. Use the diagram on the engine compartment or your notes, as a reference, to properly route the belt.
    • 3 Insert the large breaker bar into the square hole or the ratchet and socket into the tensioner pulley center bolt.
    • 4 Rotate the tensioner pulley in the same direction you did to release the belt tension.
    • 5 Slide the serpentine belt onto the tensioner pulley.
    • 6 Release the tensioner pulley back into position.
    • 7 Look at all the pulleys and make sure the serpentine belt is properly seated on each one. Otherwise, release the belt tension and adjust the belt.
    • 8 Connect the ground (black) battery cable using the wrench.
Oct 18, 2011 | 1992 Subaru SVX
JI am having trouble finding a clutch cable routing diagram for my 95 kawasaki zx6e. The cable that is in now, isn't installed properly.
TRIAL AND ERROR. THE PROCESS IS TO MAKETHECABLE IBN A STRAIGHT A LINE AS POSSIBLO........GET YER TEA MADE AN YER SPANNERS OUT
Mar 10, 2011 | kawasaki Zx600e1 Ninja Zx6e Motorcycle...
I need an Idler pulley or the pulley that runs air conditioner belt as well as the belt for the power steering
OK.
If your idler pulley is bad then unbolt it and while you're at it replace the power steering belt.
REMOVAL & INSTALLATION Because serpentine belts use a spring loaded tensioner for adjustment, belt replacement tends to be somewhat easier than it used to be on engines where accessories were pivoted and bolted in place for tension adjustment. Basically, all belt replacement involves is to pivot the tensioner to loosen the belt, then slide the belt off of the pulleys. The two most important points are to pay CLOSE attention to the proper belt routing (since serpentine belts tend to be "snaked'' all different ways through the pulleys) and to make sure the V-ribs are properly seated in all the pulleys. Although belt routing diagrams have been included in this section, the first places you should check for proper belt routing are the labels in your engine compartment. These should include a belt routing diagram which may reflect changes made during a production run.
  1. Disconnect the negative battery cable for safety. This will help assure that no one mistakenly cranks the engine over with your hands between the pulleys, and that the cooling fan cannot activate while servicing the belt(s). NOTE: Take a good look at the installed belt and make a note of the routing. Before removing the belt, make sure the routing matches that of the belt routing label or one of the diagrams in this book. If for some reason a diagram does not match (you may not have the original engine or it may have been modified), carefully note the changes on a piece of paper.
  2. For tensioners equipped with a 1⁄2 in. (13mm) square hole, insert the drive end of a large breaker bar into the hole. Use the breaker bar to pivot the tensioner away from the drive belt. For tensioners not equipped with this hole, use the proper-sized socket and breaker bar (or a large handled wrench) on the tensioner idler pulley center bolt to pivot the tensioner away from the belt. This will loosen the belt sufficiently that it can be pulled off of one or more of the pulleys. It is usually easiest to carefully pull the belt out from underneath the tensioner pulley itself.
  3. Once the belt is off one of the pulleys, gently pivot the tensioner back into position. DO NOT allow the tensioner to snap back, as this could damage the tensioner's internal parts.
  4. Now finish removing the belt from the other pulleys and remove it from the engine. To install:
  5. While referring to the proper routing diagram (which you identified earlier), begin to route the belt over the pulleys, leaving whichever pulley you first released it from for last.
  6. Once the belt is mostly in place, carefully pivot the tensioner and position the belt over the final pulley. As you begin to allow the tensioner back into contact with the belt, run your hand around the pulleys and make sure the belt is properly seated in the ribs. If not, release the tension and seat the belt.
  7. Once the belt is installed, take another look at all the pulleys to double check your installation.
  8. Connect the negative battery cable, then start and run the engine to check belt operation.
  9. Once the engine has reached normal operating temperature, turn the ignition OFF and check that the belt tensioner arrow is within the proper adjustment range. Fig. 1: Often the underhood label will display the serpentine drive belt routing 88231p43.gif
    Fig. 2: Relieve the belt tension by pivoting the automatic tensioner away from the belt, then remove the belt 88231p44.gif
    Fig. 3: Verifying serpentine belt alignment in the pulley 79244g60.gif
    Fig. 4: Fig. 1 Accessory V-belt routing — Tracker 1.6L engine with A/C 93024g03.gif
    Fig. 5: Fig. 2 Accessory V-belt routing — Tracker 1.6L engine with A/C and P/S 93024g04.gif
    Fig. 6: Fig. 3 Accessory V-belt routing — Tracker 1.6L engine with P/S 93024g05.gif
Jun 26, 2010 | 2000 Chevrolet Tracker
Belt replacement diagram 2000 mazda mpv
    Fig. 4: Fig. 1 Accessory V-belt routing (alternator) — Mazda MPV 3.0L engine 79244g67.gif
    Fig. 5: Fig. 2 Accessory V-belt routing (power steering) — Mazda MPV 3.0L engine 79244g66.gif
    Fig. 6: Fig. 3 Accessory V-belt routing (A/C compressor) — Mazda MPV 3.0L engine 79244g65.gif
Jul 08, 2010 | 2000 Mazda MPV
Shorted Touch Screen on GE Spacemaker JVM2070? How do I fix it?
These ovens are nightmares when they fail out of warranty...
The touch screen assembly is not meant to be be taken apart for repairs, only replaced. And the assembly runs about $455 (just part cost!), depending on your full model number suffix.
Add to that the $79 to visit the home, plus $75-90 to actually do the work, plus whatever parts markup, and you'd be better off replacing the microwave.
If you insist on the same model, you might try eBay. They appear there often.
Good luck.
Apr 27, 2010 | GE JVM2070 Microwave Oven
I have a brother DCP-135c printer. the magenta ink not printing
The process to get to the print head will take you approx. 1 hour. Without being trained on it, there is a high failure rate upon completion.
The Scanner assembly needs to be taken off. Harness Cables for the Scanner need to be removed.The Upper Case Assembly needs to be taken off. Printhead casing and printhead tubing calbes need to be removed, printhead mainboard needs to be removed, and then you have access to the printhead.
Thanks
Dec 19, 2009 | Brother MFC 420CN All-In-One InkJet...
96 sunfire belt diagram ...serpentine
10171018 <-part # for a belt routing label.
there should already be a belt routing label under the hood or on your core support with a picture :}
Aug 26, 2009 | 1996 Pontiac Sunfire
I get the message I/O error occurred, process aborted.
First of all, you do not need Finepix viewer.
Make sure the USB cable is properly connected to camera and PC.
Ensure that you have installed the driver for the s5000 if you do not have Windows XP.
Then select "view"
and the pictures taken should be copied to any photo prgram you select.
or try a different cable if this does not work.
Jan 18, 2009 | Fuji FinePix S5000 Digital Camera
Peg Perego Vespa Scooter Logo
71 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Marvin
Marvin
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
