When i turn on car, all cluster instriments flash off and on, and
when I am driving car dies.
Ign switch located on your steering column. My car did the exact same thing. changed and problem went away. 89$ autozone
Might be the crank signal sensor, try turning your key to the on position and all the lights on the dash should flicker on and off leave the it in the on position and go to the passenger side fuse panel and take out fuse 4A, the fuse for the CRANK SIGNAL , BCM, CLUSTER. if your dash stops blinking then its probably your crank sensor.
While driving my dash lights all light up and the car stalls. Happened while turning a corner today and then no steering and brakes. First the
Anti-lock brake, traction control, service engine soon lights came on.
might be the crank signal sensor
Car shuts off
When I turn the signal switch the car dies
