Question about Tally Office Equipment & Supplies
I keep getting paper motion flt error with tally 6050
5 Suggested Answers
gadget850
SOURCE: Tally T6100
You lost the sensor calibrations. Grab the service manual. Do the four fault clear, enable tech access mode and calibrate paper motion, paper out and platen.
Posted on Jun 02, 2008
  • 39 Answers
SOURCE: ERROR MESSAGE BLK 1CHKSUM FLT on tally t6045 printer
BLK 1 means your black toner cartridge, and I believe the chksum error may have something to do with the memory file. Check out No. 6 under Unrecoverable errors on this sheet.
http://www.tallygenicom.com/support/technotes/3400/error.htm
This is problably something to be sent in for maintenance.
For this error these are the recomendations:
(Try cycling power; initilizing printer. If error persists, maintenance
service is indicated.)
Posted on Apr 27, 2009
  • 29 Answers
SOURCE: tally 6050 shows paper motion fault
paper movement problem.pls check the paper movement is proper or not and check the paper motion sensor it was lie in the LHS sprocket
Posted on Nov 21, 2010
SOURCE: how to rectifity paper motion flt problem
paper motion fault for libi t6100
Posted on Dec 18, 2010
All my tractors are okay but my printer still giving me a paper motion error?
you need to clean paper motion sensor first,
check its connection on logic board
clean the connector of sensor,
if you can then please post u r problems with printer model then i can explain it more.
Mar 21, 2011 | Tally T6218 Matrix Printer
Problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
problem for lipi 6312 tally genicom line printer my printer shows an error (hammer voltage 1)
Apr 20, 2010 | Tally T6218 Matrix Printer
Tally 6050 shows paper motion fault
Feb 16, 2010 | Tally Line Matrix T6090 Printer
Apr 27, 2009 | Tally Line Matrix T6045 Printer
Error on tally genicom 6312
found this on Tally Genicom's Website about your device.
Technical Services Note
MT6xx/T6xxx (All) Paper Motion Faults 11 May 1995
T645.039
If you are having problems with recurring Paper Motion Faults that don’t seem to stay
fixed by doing the paper motion sensor calibration, try the following:
· Check the back of the form along the left side to ensure there are no black (dark) areas
in the area of the tractor drive holes. (If there are, this is probably the problem. If not,
proceed on down this list.)
Clean the sensor on the upper left tractor then run the calibration routine again. If it’s
not better yet, continue.
With Tech Access ON, do the following:
Go into DIAG - Meters - Paper Motion and monitor the sensor reading with paper
installed and removed. If the reading with paper installed is in the 300 to 350 mVolt
range, change the sensor (even if it seems to run the calibration alright). A more
normal reading would be something greater than 600 mVolts for the MT691/6092 and
1000mVolts or greater in the 645/661. Don’t forget to recalibrate the sensor. If it’s
not fixed yet, try this next step.
Run a configuration printout and then do the following:
1. Clear the NV Ram (Tech Access feature ON)
2. Calibrate the Paper Motion and Paper Out sensors
3. Restore the configuration based on the print-out you just ran
http://www.tallygenicom.com/support/technotes/tnote/d5639.pdf
my site: www.techvisitor.com
Jul 01, 2008 | TallyGenicom 6312 Matrix Printer
Tally T6100
May 23, 2008 | Tally Line Matrix T6050 Printer
Need part numbers to order parts
the problem is with sensor calibration,activate the TECH-ASSES
mode pressing ENTER + LF switch simonteniously,than calibrate the paper motion .
upadhyay
 girish
Jul 20, 2007 | Tally Line Matrix T6090 Printer
Paper motion fault
This info is from the Maint. Manual for T6212/T6215/T6218.
gp+3ytmzowxemaaaaaelftksuqmcc
xotihxffu1saaaaasuvork5cyii=Sensor is located below the upper left tractor item 99 below. Clean it and make sure the V is facing your holes in the paper. If that isn't the problem? see below how to meter sensors procedures...
0tzegsr+ic4n46ssuqv4el30qgpfj8tqefx2f8bvlqvvrw0muuaaaaasuvork5cyii=imeb+a4pe3uaaaaasuvork5cyii=
ak0nfwmwb8waaaaasuvork5cyii=
Jan 24, 2007 | Tally T6218 Matrix Printer
102 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
