Question about Microsoft Xbox 360 Console
The door wont open and it seems to be in test mode at all times
    Problem Solver:
  • 10 Answers
Try turning your xbox on it's side.
Posted on Dec 02, 2008
Cant get my cd drawer to open i push the button and it wont open try pushing button and pry at the same time and nothing happens have emachine T3508
with your computer power turned off, use a straight mini-kabob pin (or sturdy paper clip) to manually let out the DVD drive tray. There is a little hole under the drive tray door that accepts this kind of tool device. Another option is to massage the door while trying to eject the DVD drive tray. This method requires your computer to be turned on and by selecting the proper drive (E:) from the My Computer in Start Menu, you then "Eject" and can push in on the door and on the corners, enabling the DVD drive tray to open.
Feb 02, 2010 | Computers & Internet
Drive door stuck and wont open
You can always try getting a jumbo paperclip, unbending it once, and inserting it into the small circular hole on the front of your drive. If your drive doesn't have the hole, then you'll have to probably take it to a repair shop.
Good Luck!
Jan 23, 2010 | Sony (DRU720A) DVD±RW Dual Layer...
The center light on the power button flashes none stop, the door wont open properly and wont load the game up to play and now the door wont open... what seem to be the problem in your guess
The console is not recognizing the DVD drive. Did you change it recently? If so you must swap the PCB from your original drive into the replacement drive in order for it to be recognized.
Jan 20, 2010 | Microsoft Xbox 360 Console
CD Rom Drive door wont open
you will have to take the top off and do a little testing. the button could be off on the pcb or the drive may be a little stubborn. put a paperclip in the drive release hole and then try the button a few times. if it works, its just a stubborn drive , if it doesn't, the pcb may need a reflow. i have seen a few with cold solder joints.
not really hard to fix.
Aug 16, 2009 | Alesis MasterLink ML-9600
Tray wont open and tuner seems not to work
Disc tray belt that opens door has too much slack and need to be replaced,$2 item,belt size 1.9.To get tray open use your knuckles and tap on TOP of cabinet just above disc door while pushing open button.When open you will see the tiny belt that operates door to the right,use twizzers to remove an replace.Make sure new belt is seated properly in tracks if not tray won't move.
Jul 30, 2009 | iLO DVDR04
Dvd won't open program
Does your dvd drive opens other dvd's if it does, that means your dvd has gone bad but if your dvd drive fails to play any dvd's than it's a problem with your dvd drive.
Best way to test it would be to insert a new empty dvd and see if your dvd drive opens it.
Jul 26, 2009 | Dell Computers & Internet
Wont work
right click on dvd drive on my computer then eject the dvd drive,,,,,,,after that
open bios setting and check device configuration
Jul 02, 2009 | Dell Inspiron 1501 PC Notebook
Door wont open on the RSQ E500 player. seems to freeze when open button is pressed
I found the drive mechanism to be stuck. Also there was a little oxidation on the pins on the drive tray plug. Solution was to move the lever underneath and to the front of the drive to free the mechanism, and remove and clean the pins on the plug. Worked fine after that
Nov 08, 2008 | RSQ NEO-E500 DVD Player
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
Microsoft Xbox 360 Console Logo
81 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
